`unexpected end of JSON input` while `terminating lock maintenance` when acquiring ACME certificate
While acquiring a certificate, I sometimes observe a hard failure that puts Caddy into a state in which it can’t proceed to acquire a certificate. The log is always related to a corrupted/malformed JSON file that fails to parse.
I’m aware that this particular failure mode has appeared a few times in the forums; but I’m raising it separately after doing some digging for the following reasons:
  • I’m on 2.9.1, which follows some of the atomic file locking fixes that went into 2.9.0. I’ve observed the failure on fresh hosts without any state leftover from < 2.9.0 versions.
  • The failures I’ve caught do not occur under extenuating circumstances like a full disk where you might expect something like a failed fsync() to write out a corrupt and/or empty file.
  • I haven’t observed this failure mode associated with something like a hard-kill (like sending a -9/SIGKILL) that might bailout during a write.
I can watch Caddy recover if I restart it after observing one of these failures - I haven’t caught a relevant log line yet, but I would assume that it’s doing something like re-initializing state and clearing out the invalid JSON file.
I’ll also note that I’ve been able to catch the invalid JSON files and they’re just empty (not half-written or structurally corrupted JSON).
So yeah, kind of a mystery! I can help debug/provide additional information, but one of the frustrating parts of this bug is that it isn’t 100% reproducible. It’s fairly easy to try and cause it, as it just needs to trigger an ACME acquisition with TLS enabled and a valid hostname configured. But it doesn’t occur consistently.
My short-term mitigation plan is to write a small sidecar to observe Caddy’s log output and trigger a throttled restart when the JSON parsing failure occurs, but it’d be great to get to the bottom of it.
Mar 26 16:33:12 caddytest.rock.associates caddy[841]: {"level":"info","ts":1743006792.1017861,"msg":"[ERROR] Keeping lock file fresh: unexpected end of JSON input - terminating lock maintenance (lockfile: /var/lib/caddy/.local/share/caddy/locks/issue_cert_caddytest.rock.associates.lock)"}
Version 2.9.1 with following plugins:
  • caddy-ratelimit
  • A custom module that shouldn’t impact this code path (I’m generating CSP headers dynamically)
Running as a system service in NixOS 24.11.
  • NixOS 24.11
    • (systemd service)
(I added the escaped newlines)
ExecStart=/nix/store/sbdvablkfxw9izl7ap288f2a9mq6xg7r-caddy-2.9.1/bin/caddy \
  run \
  --config /etc/caddy/caddy_config \
  --adapter caddyfile \
  --resume
(trimmed; I don't suspect this impacts the issue)
# /etc/systemd/system/caddy.service
# caddy.service
# for your installation.
Type=notify
ExecStart=/nix/store/sbdvablkfxw9izl7ap288f2a9mq6xg7r-caddy-2.9.1/bin/caddy run --environ --config /etc/caddy/Caddyfile
ExecReload=/nix/store/sbdvablkfxw9izl7ap288f2a9mq6xg7r-caddy-2.9.1/bin/caddy reload --config /etc/caddy/Caddyfile --force
# /nix/store/1hphahky29dwgz99jxiz28gvdby96qcm-system-units/caddy.service.d/overrides.conf
StartLimitBurst=10
StartLimitIntervalSec=14400
Upholds=caddy-merge.service
X-Reload-Triggers=/nix/store/3akl771clx1vz5s9xplx367grpg77dyx-X-Reload-Triggers-caddy
Environment="LOCALE_ARCHIVE=/nix/store/fiinrcd99rnhgq9jws1pc9dk3dwzgmfd-glibc-locales-2.40-66/lib/locale/locale-archive"
Environment="PATH=/nix/store/9m68vvhnsq5cpkskphgw84ikl9m6wjwp-coreutils-9.5/bin:/nix/store/vc2d1bfy1a5y1195nq7k6p0zcm6q89nx-findutils-4.10.0/bin:/nix/store/qjsj5vnbfpbg6r7jhd7znfgmcy0arn8n-gnugrep-3.11/bin:/nix/store/3ks7b6p43dpvnlnxgvlcy2jaf1np37p2-gnused-4.9/bin:/nix/store/b5zj299v99y1r8l0s9j7k8fzv1xapcw2-systemd-256.10/bin:/nix/store/9m68vvhnsq5cpkskphgw84ikl9m6wjwp-coreutils-9.5/sbin:/nix/store/vc2d1bfy1a5y1195nq7k6p0zcm6q89nx-findutils-4.10.0/sbin:/nix/store/qjsj5vnbfpbg6r7jhd7znfgmcy0arn8n-gnugrep-3.11/sbin:/nix/store/3ks7b6p43dpvnlnxgvlcy2jaf1np37p2-gnused-4.9/sbin:/nix/store/b5zj299v99y1r8l0s9j7k8fzv1xapcw2-systemd-256.10/sbin"
Environment="TZDIR=/nix/store/l6mypzy4rvkxd5kwzs18d88syirislib-tzdata-2024b/share/zoneinfo"
EnvironmentFile=-/etc/default/caddy
ExecReload=
ExecReload=/nix/store/vpj6cl8k27n0ygyqjkcqdiqg46qa99vq-reload-caddy/bin/reload-caddy
ExecStart=
ExecStart=/nix/store/sbdvablkfxw9izl7ap288f2a9mq6xg7r-caddy-2.9.1/bin/caddy run --config /etc/caddy/caddy_config --adapter caddyfile --resume
LogsDirectory=caddy
NoNewPrivileges=true
PrivateDevices=true
ProtectHome=true
ReadWritePaths=/var/lib/caddy
Restart=on-failure
RestartPreventExitStatus=1
RestartSec=5s
StateDirectory=caddy
(This is really long and, I don't suspect, includes the reason for failure). I include JSON here because I'm making a lot of API calls over the API.
    "apps": {
        "http": {
            "servers": {
                "srv0": {
                    "listen": [
                        ":443"
                    "logs": {
                        "default_logger_name": "log0"
                    "protocols": [
                        "h1",
                        "h2",
                        "h2c"
                    "routes": [
                            "handle": [
                                    "body": "Forbidden",
                                    "handler": "static_response",
                                    "status_code": 403
                            "match": [
                                    "client_ip": {
                                        "ranges": [
                                            "174.126.31.196"
                            "handle": [
                                    "handler": "headers",
                                    "response": {
                                        "set": {
                                            "X-Frame-Options": [
                                                "deny"
                                    "handler": "subroute",
                                    "routes": [
                                            "handle": [
                                                    "handler": "vars",
                                                    "root": "/srv/assets"
                                            "group": "group11",
                                            "handle": [
                                                    "routes": [
                                                            "handle": [
        "handle_response": [
        "match": {
        "status_code": [
        2
        "match": {
        "status_code": [
        401
        "routes": [
        "handle": [
        "headers": {
        "Location": [
        "/login?redirect_to=/grafana"
        "status_code": 302
        "status_code": 302
        "handler": "reverse_proxy",
        "headers": {
        "request": {
        "set": {
        "X-Forwarded-Method": [
        "{http.request.method}"
        "X-Forwarded-Uri": [
        "{http.request.uri}"
        "rewrite": {
        "method": "GET",
        "uri": "/-net/api/v0/user/me"
        "upstreams": [
        "dial": "127.0.0.1:3000"
                                                            "match": [
        "not": [
        "header": {
        "Cookie": [
        "*grafana_session*"
        "header": {
        "Cookie": [
        "*oauth_state*"
        "header": {
        "Cookie": [
        "*__Host-nonce*"
                                                            "handle": [
        "upstreams": [
        "dial": "127.0.0.1:3001"
                                            "match": [
                                                    "path": [
                                                        "/grafana*"
                                            "group": "group11",
                                            "handle": [
                                                    "routes": [
                                                            "handle": [
        "upstreams": [
        "dial": "127.0.0.1:5556"
                                            "match": [
                                                    "path": [
                                                        "/dex*"
                                            "group": "group11",
                                            "handle": [
                                                    "routes": [
                                                            "handle": [
        "handler": "rate_limit",
        "rate_limits": {
        "remote_host": {
        "key": "{http.request.remote.host}",
        "max_events": 500,
        "window": 20000000000
        "upstreams": [
                                            "match": [
                                                    "path": [
                                                        "/ok",
                                                        "/-net/api/v0/admin_message_bus",
                                                        "/-net/api/v0/all_sync_connections",
                                                        "/-net/api/v0/api_keys",
                                                        "/-net/api/v0/api_keys/*",
                                                        "/-net/api/v0/automerge_document",
                                                        "/-net/api/v0/backups/stream",
                                                        "/-net/api/v0/client_config",
                                                        "/-net/api/v0/client_config/*",
                                                        "/-net/api/v0/client_config/device/*",
                                                        "/-net/api/v0/collection",
                                                        "/-net/api/v0/collection/*",
                                                        "/-net/api/v0/controller/*",
                                                        "/-net/api/v0/device",
                                                        "/-net/api/v0/device/*",
                                                        "/-net/api/v0/device/auth_decision",
                                                        "/-net/api/v0/device/auth_decision/*",
                                                        "/-net/api/v0/device/network_control/interface_manager",
                                                        "/-net/api/v0/device_group",
                                                        "/-net/api/v0/device_group/*",
                                                        "/-net/api/v0/device_group/*/list",
                                                        "/-net/api/v0/dns_block_list",
                                                        "/-net/api/v0/dns_block_list/*",
                                                        "/-net/api/v0/group",
                                                        "/-net/api/v0/group/*",
                                                        "/-net/api/v0/group/*/set_membership",
                                                        "/-net/api/v0/group/*/list",
                                                        "/-net/api/v0/kvs/*/contents",
                                                        "/-net/api/v0/license",
                                                        "/-net/api/v0/license/*",
                                                        "/-net/api/v0/messages",
                                                        "/-net/api/v0/messages/*",
                                                        "/-net/api/v0/oidc_ok",
                                                        "/-net/api/v0/oidc_finish",
                                                        "/-net/api/v0/oidc_start",
                                                        "/-net/api/v0/ok",
                                                        "/-net/api/v0/organization",
                                                        "/-net/api/v0/organization/config",
                                                        "/-net/api/v0/organization/config/telemetry",
                                                        "/-net/api/v0/organization/config/support_enabled",
                                                        "/-net/api/v0/organization/controller",
                                                        "/-net/api/v0/organization/controller/*",
                                                        "/-net/api/v0/organization/controllers",
                                                        "/-net/api/v0/organization/dns/*",
                                                        "/-net/api/v0/organization/ipv4",
                                                        "/-net/api/v0/organization/ipv4/*",
                                                        "/-net/api/v0/organization/ipv6",
                                                        "/-net/api/v0/organization/ipv6/*",
                                                        "/-net/api/v0/platform",
                                                        "/-net/api/v0/policy",
                                                        "/-net/api/v0/policy/*",
                                                        "/-net/api/v0/policy/resource/*",
                                                        "/-net/api/v0/policy/resource_group/*",
                                                        "/-net/api/v0/route_exclusion",
                                                        "/-net/api/v0/route_exclusion/*",
                                                        "/-net/api/v0/site",
                                                        "/-net/api/v0/site/*",
                                                        "/-net/api/v0/site/*/bgp_config",
                                                        "/-net/api/v0/site/*/range",
                                                        "/-net/api/v0/site/*/range/*",
                                                        "/-net/api/v0/status",
                                                        "/-net/api/v0/sync_connections",
                                                        "/-net/api/v0/tasks",
                                                        "/-net/api/v0/tasks/*",
                                                        "/-net/api/v0/tasks/*/run_once",
                                                        "/-net/api/v0/telemetry/sample",
                                                        "/-net/api/v0/telemetry/submit",
                                                        "/-net/api/v0/user/*",
                                                        "/-net/api/v0/users",
                                                        "/-net/api/v0/openapi.json",
                                                        "/-net/setup",
                                                        "/-net/setup/*",
                                                        "/-net/swagger-ui"
                                            "group": "group11",
                                            "handle": [
                                                    "routes": [
                                                            "handle": [
        "status_code": 421
                                            "match": [
                                                    "path": [
                                                        "/-net*"
                                            "group": "group11",
                                            "handle": [
                                                    "routes": [
                                                            "handle": [
        "handler": "rewrite",
        "strip_path_prefix": "/sos"
        "match": {
        "status_code": [
        2
        "match": {
        "status_code": [
        401
        "routes": [
        "handle": [
        "headers": {
        "Location": [
        "/login?redirect_to=/"
        "status_code": 302
        "status_code": 302
        "headers": {
        "request": {
        "set": {
        "rewrite": {
        "method": "GET",
        "upstreams": [
        "upstreams": [
        "dial": "127.0.0.1:911"
                                            "match": [
                                                    "path": [
                                                        "/sos*"
                                            "group": "group11",
                                            "handle": [
                                                    "routes": [
                                                            "handle": [
        "routes": [
        "handle": [
        "response": {
        "set": {
        "Cache-Control": [
        "no-cache, must-revalidate"
        "group": "group9",
        "handle": [
        "uri": "/index.html"
                                                            "match": [
        "not": [
        "file": {
        "try_files": [
        "{http.request.uri.path}"
                                                            "handle": [
        "asset_path": "/srv/assets",
        "csp_directives": {
        "base-uri": [
        "'self'"
        "connect-src": [
        "'self'",
        "https:",
        "wss:"
        "frame-ancestors": [
        "'none'"
        "object-src": [
        "'none'"
        "handler": "cspdynamic"
        "handler": "file_server",
        "hide": [
        "/nix/store/pk8wsmw1wn6jc6z2nvxs65v9msqa8w52-Caddyfile-formatted/Caddyfile"
                            "match": [
                                    "host": [
                                        "caddytest.rock.associates"
                            "handle": [
                                    "upstreams": [
                            "match": [
                                    "path": [
                                        "/-net/api/v0/ok"
                                    "host": [
                                    "path": [
                                        "/-net/api/v0/ok"
        "pki": {
            "certificate_authorities": {
                "local": {
                    "install_trust": false
        "tls": {
            "automation": {
                "on_demand": {
                    "permission": {
                        "endpoint": "http://127.0.0.1:3000/assigned_address",
                        "module": "http"
                "policies": [
                        "issuers": [
                                "module": "acme"
                        "subjects": [
                        "issuers": [
                                "module": "internal"
                        "subjects": [
                        "issuers": [
                        "on_demand": true
    "logging": {
        "logs": {
            "default": {
                "exclude": [
                    "http.log.access.log0"
                "level": "ERROR"
            "log0": {
                "encoder": {
                    "fields": {
                        "request>headers>X-Bt-Signature": {
                            "filter": "delete"
                        "request>headers>X-Bt-Signer": {
                            "filter": "delete"
                        "request>headers>X-Bt-Sync-Psk": {
                            "filter": "delete"
                        "request>uri": {
                            "actions": [
                                    "parameter": "oidc_finish",
                                    "type": "hash"
                            "filter": "query"
                    "format": "filter",
                    "wrap": {
                        "format": "json"
                "include": [
                "writer": {
                    "output": "stderr"
N/A
Edits: spelling and grammar.
just to confirm, this is a single instance of caddy, right?
sort of similar to Empty lockfile, likely previous process crashed or storage medium failure; treating as stale · Issue #232 · caddyserver/certmagic · GitHub
That’s correct; just a single instance of Caddy.
Re: the link, it does look similar, although I’m not using anything exotic for my host’s storage, just a mid-level EC2 instance.
Thanks for the report @tylerjl – I appreciate the detail and the investigation. Someone posted the link in our maintainer Slack and @elee pointed out that we aren’t using the atomicfile for the active locking, which is what this error pertains to.
Active locking is what updates the lock file every ~1s while it being actively held. It’s possible that somehow an error is eluding us? :thinking: Or something. Somehow, the file ends up empty.
We’ll look into it some more! I might have more questions later or want you to try a patch or add some debug lines or something.
Thanks @matt, I appreciate it. I’ll watch for any patches to test out to debug further.
As a small note, I finished writing a very small python sidecar service that essentially tails the Caddy logs from journald and restarts Caddy if it ever encounters logs from Caddy that indicate the locked-up error state. This is, of course, a pretty ugly hack, but I’ve observed it fix the wedged state at least once, so it appears to work.
if you know how to compile caddy from source with a go replace directive to a fork of a dependency, you can try this this branch GitHub - elee1766/certmagic at file-lock-changes (File lock changes by elee1766 · Pull Request #337 · caddyserver/certmagic · GitHub)
it uses the atomic file stuff used for writing certs for the lock as well.
Thanks @elee, I’ll try and find some time to test this out. I’m current custom-compiling Caddy for my own modules so it shouldn’t be too hard to get in some other customizations. I appreciate it!
