Unable to utilise xCaddy with Souin and Redis
I am trying to utilise xCaddy with Redis and Souin, I can get go-redis to work, but NOT Redis storage provider.
2025/02/19 20:40:46.514 ERROR   http.handlers.cache     Error during Redis init, did you include the Redis storage (--with github.com/darkweak/storages/redis/caddy or github.com/darkweak/storages/go-redis/caddy)
caddy:2.9.1-builder-alpine
Docker in AWS
Supervisor
# syntax=docker/dockerfile:1.4
# Build Go optimizer service
FROM golang:1.21-alpine AS go-builder
WORKDIR /go/src/optimizer
# Install build dependencies
RUN apk add --no-cache \
    gcc \
    musl-dev \
    vips-dev \
    build-base \
    && rm -rf /var/cache/apk/*
# Copy and build the Go service
COPY optimizer/main.go ./
# Initialize Go module and build with better error handling
RUN set -ex && \
    go mod init optimizer && \
    go get github.com/gofiber/fiber/v2@latest && \
    go get github.com/h2non/bimg@latest && \
    go get github.com/valyala/fasthttp@latest && \
    go mod tidy && \
    CGO_ENABLED=1 GOOS=linux go build -v -o /go/bin/optimizer
# Final stage with Caddy
FROM caddy:2.9.1-builder-alpine AS builder
RUN xcaddy build \
    --with github.com/darkweak/souin/plugins/caddy \
# Install runtime dependencies and supervisord
    vips \
    supervisor \
# Copy Go binary
COPY --from=go-builder /go/bin/optimizer /usr/local/bin/
# Copy config files
COPY supervisord.conf /etc/supervisor/supervisord.conf
# Create directories
RUN mkdir -p /etc/caddy
# Use EXPOSE for documentation
EXPOSE 80 443 3001
# Use supervisor as entrypoint
CMD ["/usr/bin/supervisord", "-c", "/etc/supervisor/supervisord.conf"]
    # Certificate storage configuration
    storage file_system /etc/caddy/certificates
    # Server protocols and keepalive settings
    servers {
        protocols h1 h2 h2c h3
        keepalive_interval 60s
    # Cache configuration
    cache {
        ttl 2h
        redis {
            url 4b96omey8.test.cloud:6385
            Username default
            Password
        cache_name Caddy
        default_cache_control "public, max-age=7200"
        allowed_http_verbs GET HEAD
# Encoding snippet
(encoding) {
    encode zstd
# TLS configuration snippet
(tls) {
        on_demand
        protocols tls1.3
# Headers snippet
(headers) {
    header Cache-Control "max-age=3600"
    header -Server
# Import site configurations
import sites/*
If so, how do you even configure Redis with a Username, and Password?
redis {
   configuration {
or just
redis {
  • Further adding onto this, the only way I can get Caddy to not throw a error is via this configuration:
    cache {
        ttl 2h
        redis {
            configuration {
               InitAddress 4b96omey8.example.cloud:6385
               Username default
               Password mypassword
        cache_name Caddy
However, I still get:
2025/02/19 20:55:14.568 WARN http.handlers.cache You’re running Souin with the default storage that is not optimized and for development purpose. We recommend to use at least one of the storages from GitHub - darkweak/storages: Souin's storages
And I still see
Caddy; hit; ttl=7175; key=GET-https-my-domain.io-/; detail=DEFAULT
not
Caddy; hit; ttl=7175; key=GET-https-my-domain.io-/; detail=REDIS
  • Further context, when building the Docker image, yes Redis is installed properly:
[app builder 2/2] RUN xcaddy build --with github.com/darkweak/souin/plugins/caddy --with github.com/darkweak/storages/redis/caddy
If I replace redis with go-redis, it works fine, go-redis works great.
I’ve confirmed with others using Redis, it is broken, needs to be fixed.
