I am trying to set up a wildcard certificate for a second level subdomain. However, caddy is unable to retrieve a certificate.
Specifically, I want my DNS server (AdGuard Home) to be able to resolve this using a DNS rewrite, but I don’t want a record in my upstream resolver, Cloudflare. I want to have something like foo.local.zenvoserver.com, which would only be accessible in my own network. I know I can get the same functionality if add the record to Cloudflare and block external IPs from connecting, but I wanted the extra layer of security.
I don’t think this is the same issue as multi-SAN support.
2025-04-14T23:41:38.256080153Z {"level":"error","ts":1744674098.2560134,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.local.zenvoserver.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.local.zenvoserver.com] solving challenges: waiting for solver certmagic.solverWrapper to be ready: timed out waiting for record to fully propagate; verify DNS provider configuration is correct - last error: <nil> (order=https://acme-v02.api.letsencrypt.org/acme/order/2324093527/374233011677) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
2025-04-14T23:41:38.256152489Z {"level":"debug","ts":1744674098.2560446,"logger":"events","msg":"event","name":"cert_failed","id":"2a0a0ba0-9a16-43c9-abe0-c893f9cdf9e1","origin":"tls","data":{"error":{},"identifier":"*.local.zenvoserver.com","issuers":["acme-v02.api.letsencrypt.org-directory"],"renewal":false}}
2025-04-14T23:41:38.256166696Z {"level":"error","ts":1744674098.2560906,"logger":"tls.obtain","msg":"will retry","error":"[*.local.zenvoserver.com] Obtain: [*.local.zenvoserver.com] solving challenges: waiting for solver certmagic.solverWrapper to be ready: timed out waiting for record to fully propagate; verify DNS provider configuration is correct - last error: <nil> (order=https://acme-v02.api.letsencrypt.org/acme/order/2324093527/374233011677) (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":121.81695712,"max_duration":2592000}
v2.9.1
Docker Compose
Unraid 6.12.14 (no Unraid templates used)
I use dockge which just does docker compose up
build:
dockerfile_inline: |
FROM caddy:2-builder AS builder
RUN xcaddy build \
--with github.com/mholt/caddy-l4 \
--with github.com/caddyserver/transform-encoder \
--with github.com/hslatman/caddy-crowdsec-bouncer/http@main \
--with github.com/hslatman/caddy-crowdsec-bouncer/layer4@main \
--with github.com/ueffel/caddy-brotli \
--with github.com/mholt/caddy-ratelimit \
--with github.com/jasonlovesdoggo/caddy-defender
FROM caddy:2
- 443:443
- 443:443/udp
- CROWDSEC_API_KEY=${CROWDSEC_API_KEY}
- CLOUDFLARE_API_TOKEN=${CLOUDFLARE_API_TOKEN}
- /various-mounts-here
- caddy
- crowdsec
security_opt:
- no-new-privileges=true
crowdsec:
image: docker.io/crowdsecurity/crowdsec:latest
container_name: crowdsec
- GID=100
- COLLECTIONS=crowdsecurity/caddy crowdsecurity/http-cve
crowdsecurity/whitelist-good-actors
- BOUNCER_KEY_CADDY=${CROWDSEC_API_KEY}
- crowdsec
security_opt:
external: true
crowdsec:
external: true
crowdsec {
api_url http://crowdsec:8080
api_key {env.CROWDSEC_API_KEY}
(block_world) {
@block not remote_ip private_ranges
abort @block
(cloudflare_whitelist) {
"ranges":
"173.245.48.0/20,
103.21.244.0/22,
103.22.200.0/22,
103.31.4.0/22,
141.101.64.0/18,
108.162.192.0/18,
190.93.240.0/20,
188.114.96.0/20,
197.234.240.0/22,
198.41.128.0/17,
162.158.0.0/15,
104.16.0.0/13,
104.24.0.0/14,
172.64.0.0/13,
131.0.72.0/22"
(cloudflare_only) {
@block not remote_ip private_ranges cloudflare_whitelist
(security_headers) {
Strict-Transport-Security "max-age=31536000; includeSubDomains;"
X-Frame-Options "SAMEORIGIN"
Referrer-Policy "strict-origin"
X-Robots-Tag "noindex, nofollow, nosnippet, noarchive"
(log_settings) {
output file /config/logs/access.log
level WARN
(dns_challenge) {
resolvers 1.1.1.1 1.0.0.1
(crowdsec_bouncer) {
route {
crowdsec
##Logs needed for crowdsec
*.local.zenvoserver.com {
import log_settings
import security_headers
import dns_challenge
import block_world
@foo host foo.local.zenvoserver.com
handle @foo {
reverse_proxy http://192.168.1.254:10022
abort
*.zenvoserver.com {
import log_settings
import cloudflare_only
import crowdsec_bouncer
@bar host bar.zenvoserver.com
handle @bar {
reverse_proxy http://192.168.1.254:20010
abort
