I’m going to replace Apache with Caddy.
I need to obtain in Caddy following proxypass configured in Apache (running on porto 80)
ProxyPass /myapp/api http://localhost:1202/api
i.e. i need that everything that starts with myapp/api to be redirected to http://localhost:1202/api/ maintaining all path following “api”, e.g.
http://localhost/myapp/api/mymodule/myresource → http://localhost:1202/api/mymodule/myresource
and so on.
I’m not able to obtaint that. i tried various directives and search also in this community but i was not in the position to find best solution
Caddy v2.7.5
Windows
caddy_windows_amd64.exe fmt --overwrite
caddy_windows_amd64.exe adapt
caddy_windows_amd64.exe run
This is my last try..
route /myapp/api {
uri strip_prefix /api
reverse_proxy localhost:1202
You’re looking for handle_path. But keep in mind:
Thanks, in the end I used following configuration:
# URL applicativo Rest myapp in ascolto sulla porta 1202
handle_path /myapp/* {
redir /myapp/ /api/
reverse_proxy localhost:2002
This doesn’t do anything, because /myapp/ is already stripped away from the request at this point. You can remove that line.
Also, make sure you have handling for other request paths, otherwise Caddy will just write an empty response.
