Unable to Issue or Renew SSL Certificates in Caddy with ZeroSSL
Hello,
I’m facing a major issue while trying to create or renew SSL certificates for my domains.
I’m using Caddy + ZeroSSL + Redis.
My goal is to issue SSL certificates for my domains and then redirect them to a destination page.
However, when the number of domains becomes too large, it leads to an error where SSL certificates cannot be issued, renewed, or even accessed for those domains.
I have tried deleting the SSL certificates and reissuing them, but it still doesn’t work.
Could you please help me with this issue?
2025-10-26T04:45:34.577721-10:00 cadb caddy[3030]: {“level”:“error”,“ts”:1761489934.576983,“logger”:“tls.on_demand”,“msg”:“renewing certificate on-demand failed”,“subjects”:[“mydomain”],“not_after”:1760918400,“error”:“[mydmain] Renew: context canceled”}
v2.10.0
Ubuntu 24.04.2 LTS
        acme_ca https://acme.zerossl.com/v2/DV90
        email myemail
        acme_eab {
                key_id my_id
                mac_key "my_key"
        storage redis {
                address 127.0.0.1:6379
        on_demand_tls {
                ask http://localhost:5555/check
        order rate_limit first
        @www {
                host www.*
        handle @www {
                redir https://{host[4:]}{uri} permanent
        rate_limit {
                log_key
                zone http_redirects {
                        key {remote_ip}-{host}
                        events 20000 # Increased for production
                        window 15m # More reasonable window
        @acme_challenge path /.well-known/acme-challenge/*
                redir https://{host}{uri} permanent
:443 {
                on_demand # This is crucial for your 50k domains
        rate_limit {
                log_key
                zone https_general {
                        events 1000
                        window 15m
                zone tls_ops {
                        events 1000
                        window 2h
                        match {
                redir https://mydomains/domain/{host} permanent
How many is “too large”? Also, which plan are you using with ZeroSSL?
Hi @timelordx
I’m using Premium Plan.
Thousands of Domains.
This is during on-demand TLS?
Context-canceled usually means that the client disconnected before the renewal finished.
We can only guess though since even though the help template asks for “full log output” you only gave us 1 line.
2025-10-27T15:45:38.526834-10:00 cadb validation-service[39427]: 2025/10/27 15:45:38 Received request: /check?domain=mydomain
2025-10-27T15:45:38.526893-10:00 cadb validation-service[39427]: 2025/10/27 15:45:38 ✅ Domain mydomain is a main domain. SSL ALLOWED (no further checks).
2025-10-27T15:45:38.526999-10:00 cadb caddy[57775]: {"level":"debug","ts":1761615938.5268958,"logger":"tls.permission.http","msg":"response from permission endpoint","remote":"172.176.156.33:4509","domain":"mydomain","url":"http://localhost:5555/check?domain=mydomain","status":200}
2025-10-27T15:45:38.527837-10:00 cadb caddy[57775]: {"level":"debug","ts":1761615938.5276668,"logger":"tls.handshake","msg":"did not load cert from storage","remote_ip":"172.176.156.33","remote_port":"4509","server_name":"mydomain","error":"no matching certificate to load for mydomain: file does not exist"}
2025-10-27T15:45:38.528635-10:00 cadb caddy[57775]: {"level":"info","ts":1761615938.5277138,"logger":"tls.on_demand","msg":"obtaining new certificate","remote_ip":"172.176.156.33","remote_port":"4509","server_name":"mydomain"}
2025-10-27T15:45:38.530812-10:00 cadb caddy[57775]: {"level":"info","ts":1761615938.53064,"logger":"tls.obtain","msg":"acquiring lock","identifier":"mydomain"}
2025-10-27T15:45:38.530934-10:00 cadb caddy[57775]: {"level":"info","ts":1761615938.5308938,"logger":"tls.obtain","msg":"lock acquired","identifier":"mydomain"}
2025-10-27T15:45:38.531779-10:00 cadb caddy[57775]: {"level":"info","ts":1761615938.5311756,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"mydomain"}
2025-10-27T15:45:38.531884-10:00 cadb caddy[57775]: {"level":"debug","ts":1761615938.5315301,"logger":"events","msg":"event","name":"cert_obtaining","id":"39d0c246-fff3-41ee-9d35-a269b5448ea3","origin":"tls","data":{"identifier":"mydomain"}}
2025-10-27T15:45:38.531924-10:00 cadb caddy[57775]: {"level":"debug","ts":1761615938.5317488,"logger":"tls","msg":"created CSR","identifiers":["mydomain"],"san_dns_names":["mydomain"],"san_emails":[],"common_name":"","extra_extensions":0}
2025-10-27T15:45:38.533111-10:00 cadb caddy[57775]: {"level":"info","ts":1761615938.5329268,"logger":"http","msg":"waiting on internal rate limiter","identifiers":["mydomain"],"ca":"https://acme.zerossl.com/v2/DV90","account":"andy@impire.com"}
2025-10-27T15:48:38.528327-10:00 cadb caddy[57775]: {"level":"error","ts":1761616118.528195,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"mydomain","issuer":"acme.zerossl.com-v2-DV90","error":"context canceled"}
2025-10-27T15:48:38.528447-10:00 cadb caddy[57775]: {"level":"debug","ts":1761616118.5283246,"logger":"events","msg":"event","name":"cert_failed","id":"7cd4a873-3db8-4268-a1ca-c81572e892cf","origin":"tls","data":{"error":{},"identifier":"mydomain","issuers":["acme.zerossl.com-v2-DV90"],"renewal":false}}
2025-10-27T15:48:38.528492-10:00 cadb caddy[57775]: {"level":"info","ts":1761616118.5284271,"logger":"tls.obtain","msg":"releasing lock","identifier":"mydomain"}
2025-10-27T15:48:38.528885-10:00 cadb caddy[57775]: {"level":"debug","ts":1761616118.5287673,"logger":"http.stdlib","msg":"http: TLS handshake error from 172.176.156.33:4509: [mydomain] Obtain: context canceled"}
2025-10-27T15:49:41.711235-10:00 cadb caddy[57775]: {"level":"debug","ts":1761616181.7109709,"logger":"events","msg":"event","name":"tls_get_certificate","id":"c68a82b1-f1f3-46d5-8615-ac4fb6805c80","origin":"tls","data":{"client_hello":{"CipherSuites":[31354,4865,4866,4867,49196,49195,52393,49200,49199,52392,49162,49161,49172,49171,157,156,53,47,49160,49170,10],"ServerName":"mydomain","SupportedCurves":[19018,29,23,24,25],"SupportedPoints":"AA==","SignatureSchemes":[1027,2052,1025,1283,2053,2053,1281,2054,1537,513],"SupportedProtos":["h2","http/1.1"],"SupportedVersions":[19018,772,771,770,769],"RemoteAddr":{"IP":"116.110.224.215","Port":33557,"Zone":""},"LocalAddr":{"IP":"89.117.19.57","Port":443,"Zone":""}}}}
2025-10-27T15:49:41.711398-10:00 cadb caddy[57775]: {"level":"debug","ts":1761616181.711032,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"mydomain"}
2025-10-27T15:49:41.711493-10:00 cadb caddy[57775]: {"level":"debug","ts":1761616181.7110841,"logger":"tls.handshake","msg":"all external certificate managers yielded no certificates and no errors","remote_ip":"116.110.224.215","remote_port":"33557","sni":"mydomain"}
2025-10-27T15:49:41.711524-10:00 cadb caddy[57775]: {"level":"debug","ts":1761616181.7110927,"logger":"tls","msg":"asking for permission for on-demand certificate","remote_ip":"116.110.224.215","domain":"mydomain"}
2025-10-27T15:49:41.711571-10:00 cadb caddy[57775]: {"level":"debug","ts":1761616181.7111063,"logger":"tls.permission.http","msg":"asking permission endpoint","remote":"116.110.224.215:33557","domain":"mydomain","url":"http://localhost:5555/check?domain=mydomain"}
2025-10-27T15:49:41.712412-10:00 cadb validation-service[39427]: 2025/10/27 15:49:41 Received request: /check?domain=mydomain
2025-10-27T15:49:41.712463-10:00 cadb validation-service[39427]: 2025/10/27 15:49:41 ✅ Domain mydomain is a main domain. SSL ALLOWED (no further checks).
2025-10-27T15:49:41.712595-10:00 cadb caddy[57775]: {"level":"debug","ts":1761616181.712521,"logger":"tls.permission.http","msg":"response from permission endpoint","remote":"116.110.224.215:33557","domain":"mydomain","url":"http://localhost:5555/check?domain=mydomain","status":200}
2025-10-27T15:49:41.713504-10:00 cadb caddy[57775]: {"level":"debug","ts":1761616181.7132726,"logger":"tls.handshake","msg":"did not load cert from storage","remote_ip":"116.110.224.215","remote_port":"33557","server_name":"mydomain","error":"no matching certificate to load for mydomain: file does not exist"}
2025-10-27T15:49:41.713657-10:00 cadb caddy[57775]: {"level":"info","ts":1761616181.7134137,"logger":"tls.on_demand","msg":"obtaining new certificate","remote_ip":"116.110.224.215","remote_port":"33557","server_name":"mydomain"}
2025-10-27T15:49:41.715874-10:00 cadb caddy[57775]: {"level":"info","ts":1761616181.7158551,"logger":"tls.obtain","msg":"acquiring lock","identifier":"mydomain"}
2025-10-27T15:49:41.716179-10:00 cadb caddy[57775]: {"level":"info","ts":1761616181.7160556,"logger":"tls.obtain","msg":"lock acquired","identifier":"mydomain"}
2025-10-27T15:49:41.716355-10:00 cadb caddy[57775]: {"level":"info","ts":1761616181.716271,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"mydomain"}
2025-10-27T15:49:41.716423-10:00 cadb caddy[57775]: {"level":"debug","ts":1761616181.7163215,"logger":"events","msg":"event","name":"cert_obtaining","id":"323f891f-7c14-4f72-8414-85ae9fc993a6","origin":"tls","data":{"identifier":"mydomain"}}
2025-10-27T15:49:41.716546-10:00 cadb caddy[57775]: {"level":"debug","ts":1761616181.7164207,"logger":"tls","msg":"created CSR","identifiers":["mydomain"],"san_dns_names":["mydomain"],"san_emails":[],"common_name":"","extra_extensions":0}
2025-10-27T15:49:41.717797-10:00 cadb caddy[57775]: {"level":"info","ts":1761616181.7177176,"logger":"http","msg":"waiting on internal rate limiter","identifiers":["mydomain"],"ca":"https://acme.zerossl.com/v2/DV90","account":"andy@impire.com"}
The debug log of this issue, please take a look.
BTW, I was try to removed fully the domain in Redis, but It was not renew with new cert.
Thanks
yes. on-demand TLS.
could you please help me to fix it ?
Thanks
That is interesting… upon close inspection, the log lines are out of order:
2025-10-27T15:45:38.531924-10:00 cadb caddy[57775]: {“level”:“debug”,“ts”:1761615938.5317488,“logger”:“tls”,“msg”:“created CSR”,“identifiers”:[“mydomain”],“san_dns_names”:[“mydomain”],“san_emails”:,“common_name”:“”,“extra_extensions”:0}
2025-10-27T15:45:38.533111-10:00 cadb caddy[57775]: {“level”:“info”,“ts”:1761615938.5329268,“logger”:“http”,“msg”:“waiting on internal rate limiter”,“identifiers”:[“mydomain”],“ca”:“https://acme.zerossl.com/v2/DV90",“account”:"andy@impire.com”}
2025-10-27T15:48:38.528327-10:00 cadb caddy[57775]: {“level”:“error”,“ts”:1761616118.528195,“logger”:“tls.obtain”,“msg”:“could not get certificate from issuer”,“identifier”:“mydomain”,“issuer”:“acme.zerossl.com-v2-DV90”,“error”:“context canceled”}
Notice how it goes from 38.53 seconds to 38.52 seconds. Is this a straight copy-paste of the logs?
I don’t know if that’s significant, but either way, the context is being canceled like… less than a hundredth of a second after it started?
What I’m getting from this is the client is immediately disconnecting.
Can you point us to an endpoint we can connect to so that we can reproduce the behavior?
I resend the full log of this case.
The API checkpoint will return 200 OK if the domain in the whitelisted domains file.
Summary
2025-10-30T20:52:03.552936-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.5527737,“logger”:“events”,“msg”:“event”,“name”:“tls_get_certificate”,“id”:“e462177d-d765-401c-806a-a3dc9e3727ee”,“origin”:“tls”,“data”:{“client_hello”:{“CipherSuites”:[4865,4867,4866,49195,49199,52393,52392,49196,49200,49162,49161,49171,49172,156,157,47,53],“ServerName”:“``oynf.com``”,“SupportedCurves”:[4588,29,23,24,25,256,257],“SupportedPoints”:“AA==”,“SignatureSchemes”:[1027,1283,1539,2052,2053,2054,1025,1281,1537,515,513],“SupportedProtos”:[“h2”,“http/1.1”],“SupportedVersions”:[772,771],“RemoteAddr”:{“IP”:“203.119.65.147”,“Port”:64105,“Zone”:“”},“LocalAddr”:{“IP”:“89.117.19.57”,“Port”:443,“Zone”:“”}}}}
2025-10-30T20:52:03.552990-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.5528889,“logger”:“tls.handshake”,“msg”:“choosing certificate”,“identifier”:“``oynf.com``”,“num_choices”:1}
2025-10-30T20:52:03.553014-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.5529027,“logger”:“tls.handshake”,“msg”:“default certificate selection results”,“identifier”:“``oynf.com``”,“subjects”:[“``oynf.com``”],“managed”:true,“issuer_key”:“acme.zerossl.com-v2-DV90”,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”}
2025-10-30T20:52:03.553025-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.5529146,“logger”:“tls.handshake”,“msg”:“matched certificate in cache”,“remote_ip”:“203.119.65.147”,“remote_port”:“64105”,“subjects”:[“``oynf.com``”],“managed”:true,“expiration”:1760918400,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”}
2025-10-30T20:52:03.553036-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893523.552934,“logger”:“tls”,“msg”:“certificate needs renewal based on ARI window”,“subjects”:[“``oynf.com``”],“expiration”:1760918400,“ari_cert_id”:“D2vmS845R672fpAeefAwkZLIX6M.AK0wmaPiaOv1l3CqkZNThh0”,“next_ari_update”:1760937037.5656383,“renew_check_interval”:600,“window_start”:1759622399,“window_end”:1759795199,“selected_time”:1759641802,“renewal_cutoff”:1759641202}
2025-10-30T20:52:03.554265-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.5541778,“logger”:“tls”,“msg”:“asking for permission for on-demand certificate”,“remote_ip”:“203.119.65.147”,“domain”:“``oynf.com``”}
2025-10-30T20:52:03.554286-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.554202,“logger”:“tls.permission.http”,“msg”:“asking permission endpoint”,“remote”:“203.119.65.147:64105”,“domain”:“``oynf.com``”,“url”:“`` ````` http://localhost:5555/check?domain=oynf.com”\`\`} ``` 2025-10-30T20:52:03.555400-10:00 cadb validation-service[8236]: 2025/10/30 20:52:03 ✅ Domain ``oynf.com`` allowed ``` ``` 2025-10-30T20:52:03.555555-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.5554986,“logger”:“tls.permission.http”,“msg”:“response from permission endpoint”,“remote”:“203.119.65.147:64105”,“domain”:“``oynf.com``”,“url”:“`` ````` http://localhost:5555/check?domain=oynf.com","status”:200\` }` 2025-10-30T20:52:03.555586-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893523.5555212,“logger”:“tls.on_demand”,“msg”:“attempting certificate renewal”,“remote_ip”:“203.119.65.147”,“remote_port”:“64105”,“server_name”:“oynf.com”,“subjects”:[“oynf.com”],“expiration”:1760918400,“remaining”:-975123.554154688,“revoked”:false} 2025-10-30T20:52:03.560339-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893523.5598216,“logger”:“tls.renew”,“msg”:“acquiring lock”,“identifier”:“oynf.com”} 2025-10-30T20:52:03.560374-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893523.5602639,“logger”:“tls.renew”,“msg”:“lock acquired”,“identifier”:“oynf.com”} 2025-10-30T20:52:03.561622-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893523.5615172,“logger”:“tls.renew”,“msg”:“renewing certificate”,“identifier”:“oynf.com”,“remaining”:-975123.561511448} 2025-10-30T20:52:03.561653-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.5616,“logger”:“events”,“msg”:“event”,“name”:“cert_obtaining”,“id”:“c7f1bba3-0159-4df7-ab41-10d352969aa4”,“origin”:“tls”,“data”:{“forced”:false,“identifier”:“oynf.com”,“issuer”:“acme.zerossl.com-v2-DV90”,“remaining”:-975123561511448,“renewal”:true}} 2025-10-30T20:52:03.561859-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.5617986,“logger”:“tls”,“msg”:“created CSR”,“identifiers”:[“oynf.com”],“san_dns_names”:[“oynf.com”],“san_emails”: [ ]`,“common_name”:“”,“extra_extensions”:0}` 2025-10-30T20:52:03.562953-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893523.5629141,“logger”:“http”,“msg”:“waiting on internal rate limiter”,“identifiers”:[“oynf.com”],“ca”:“ ````` https://acme.zerossl.com/v2/DV90",“account”:"andy@impire.com”\`\` ```}` ``` 2025-10-30T20:52:03.568740-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.568522,“logger”:“events”,“msg”:“event”,“name”:“tls_get_certificate”,“id”:“03938603-cd56-483b-885e-426f022735ff”,“origin”:“tls”,“data”:{“client_hello”:{“CipherSuites”:[4865,4867,4866,49195,49199,52393,52392,49196,49200,49162,49161,49171,49172,156,157,47,53],“ServerName”:“oynf.com”,“SupportedCurves”:[4588,29,23,24,25,256,257],“SupportedPoints”:“AA==”,“SignatureSchemes”:[1027,1283,1539,2052,2053,2054,1025,1281,1537,515,513],“SupportedProtos”:[“h2”,“http/1.1”],“SupportedVersions”:[772,771],“RemoteAddr”:{“IP”:“203.119.65.147”,“Port”:64106,“Zone”:“”},“LocalAddr”:{“IP”:“89.117.19.57”,“Port”:443,“Zone”:“”}}}} ``` ``` 2025-10-30T20:52:03.570850-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.5707626,“logger”:“tls.handshake”,“msg”:“choosing certificate”,“identifier”:“oynf.com”,“num_choices”:1} ``` ``` 2025-10-30T20:52:03.570859-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.5707805,“logger”:“tls.handshake”,“msg”:“default certificate selection results”,“identifier”:“oynf.com”,“subjects”:[“oynf.com”],“managed”:true,“issuer_key”:“acme.zerossl.com-v2-DV90”,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} ``` ``` 2025-10-30T20:52:03.570867-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.570793,“logger”:“tls.handshake”,“msg”:“matched certificate in cache”,“remote_ip”:“203.119.65.147”,“remote_port”:“64106”,“subjects”:[“oynf.com”],“managed”:true,“expiration”:1760918400,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} ``` ``` 2025-10-30T20:52:03.570889-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893523.5708117,“logger”:“tls”,“msg”:“certificate needs renewal based on ARI window”,“subjects”:[“oynf.com”],“expiration”:1760918400,“ari_cert_id”:“D2vmS845R672fpAeefAwkZLIX6M.AK0wmaPiaOv1l3CqkZNThh0”,“next_ari_update”:1760937037.5656383,“renew_check_interval”:600,“window_start”:1759622399,“window_end”:1759795199,“selected_time”:1759641802,“renewal_cutoff”:1759641202} ``` ``` 2025-10-30T20:52:03.571830-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893523.571743,“logger”:“tls.on_demand”,“msg”:“certificate has expired, but is already being renewed; waiting for renewal to complete”,“remote_ip”:“203.119.65.147”,“remote_port”:“64106”,“subjects”:[“oynf.com”],“expired”:1760918400,“revoked”:false} ``` ``` 2025-10-30T20:52:06.197044-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893526.1967335,“logger”:“events”,“msg”:“event”,“name”:“tls_get_certificate”,“id”:“08ccedb0-2e58-4f79-95b8-52ef8a7d290f”,“origin”:“tls”,“data”:{“client_hello”:{“CipherSuites”:[4865,4867,4866,49195,49199,52393,52392,49196,49200,49162,49161,49171,49172,156,157,47,53],“ServerName”:“oynf.com”,“SupportedCurves”:[4588,29,23,24,25,256,257],“SupportedPoints”:“AA==”,“SignatureSchemes”:[1027,1283,1539,2052,2053,2054,1025,1281,1537,515,513],“SupportedProtos”:[“h2”,“http/1.1”],“SupportedVersions”:[772,771],“RemoteAddr”:{“IP”:“203.119.65.147”,“Port”:64110,“Zone”:“”},“LocalAddr”:{“IP”:“89.117.19.57”,“Port”:443,“Zone”:“”}}}} ``` ``` 2025-10-30T20:52:06.197083-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893526.1969433,“logger”:“tls.handshake”,“msg”:“choosing certificate”,“identifier”:“oynf.com”,“num_choices”:1} ``` ``` 2025-10-30T20:52:06.197128-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893526.1969635,“logger”:“tls.handshake”,“msg”:“default certificate selection results”,“identifier”:“oynf.com”,“subjects”:[“oynf.com”],“managed”:true,“issuer_key”:“acme.zerossl.com-v2-DV90”,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} ``` ``` 2025-10-30T20:52:06.197140-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893526.1970131,“logger”:“tls.handshake”,“msg”:“matched certificate in cache”,“remote_ip”:“203.119.65.147”,“remote_port”:“64110”,“subjects”:[“oynf.com”],“managed”:true,“expiration”:1760918400,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} ``` ``` 2025-10-30T20:52:06.197150-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893526.1970496,“logger”:“tls”,“msg”:“certificate needs renewal based on ARI window”,“subjects”:[“oynf.com”],“expiration”:1760918400,“ari_cert_id”:“D2vmS845R672fpAeefAwkZLIX6M.AK0wmaPiaOv1l3CqkZNThh0”,“next_ari_update”:1760937037.5656383,“renew_check_interval”:600,“window_start”:1759622399,“window_end”:1759795199,“selected_time”:1759641802,“renewal_cutoff”:1759641202} ``` ``` 2025-10-30T20:52:06.198302-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893526.1982508,“logger”:“tls.on_demand”,“msg”:“certificate has expired, but is already being renewed; waiting for renewal to complete”,“remote_ip”:“203.119.65.147”,“remote_port”:“64110”,“subjects”:[“oynf.com”],“expired”:1760918400,“revoked”:false} ``` ``` 2025-10-30T20:52:13.348512-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893533.3482103,“logger”:“tls.cache”,“msg”:“cache full; evicting random certificate”,“removing_subjects”:[“oynf.com”],“removing_hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”,“inserting_subjects”:[“qlti.com”],“inserting_hash”:“edaf9447b5414424c8be0677a5d014edc6a39893f227121de91f6adc91044b3b”} ``` ``` 2025-10-30T20:52:13.348550-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893533.3482456,“logger”:“tls.cache”,“msg”:“removed certificate from cache”,“subjects”:[“oynf.com”],“expiration”:1760918400,“managed”:true,“issuer_key”:“acme.zerossl.com-v2-DV90”,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”,“cache_size”:9999,“cache_capacity”:10000} ``` ``` 2025-10-30T20:52:40.280176-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893560.2800624,“logger”:“events”,“msg”:“event”,“name”:“tls_get_certificate”,“id”:“ed2544a6-abf3-4234-91ad-590efbc464dc”,“origin”:“tls”,“data”:{“client_hello”:{“CipherSuites”:[4865,4867,4866,49195,49199,52393,52392,49196,49200,49162,49161,49171,49172,156,157,47,53],“ServerName”:“oynf.com”,“SupportedCurves”:[4588,29,23,24,25,256,257],“SupportedPoints”:“AA==”,“SignatureSchemes”:[1027,1283,1539,2052,2053,2054,1025,1281,1537,515,513],“SupportedProtos”:[“h2”,“http/1.1”],“SupportedVersions”:[772,771],“RemoteAddr”:{“IP”:“203.119.65.147”,“Port”:64126,“Zone”:“”},“LocalAddr”:{“IP”:“89.117.19.57”,“Port”:443,“Zone”:“”}}}} ``` ``` 2025-10-30T20:52:40.280196-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893560.280165,“logger”:“tls.handshake”,“msg”:“no matching certificates and no custom selection logic”,“identifier”:“oynf.com”} ``` ``` 2025-10-30T20:52:40.280427-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893560.2803724,“logger”:“tls.handshake”,“msg”:“all external certificate managers yielded no certificates and no errors”,“remote_ip”:“203.119.65.147”,“remote_port”:“64126”,“sni”:“oynf.com”} ``` ``` 2025-10-30T20:52:40.280478-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893560.2803843,“logger”:“tls”,“msg”:“asking for permission for on-demand certificate”,“remote_ip”:“203.119.65.147”,“domain”:“oynf.com”} ``` ``` 2025-10-30T20:52:40.280501-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893560.2804117,“logger”:“tls.permission.http”,“msg”:“asking permission endpoint”,“remote”:“203.119.65.147:64126”,“domain”:“oynf.com”,“url”:“ http://localhost:5555/check?domain=oynf.com”\`\` ```}` ``` 2025-10-30T20:52:40.282611-10:00 cadb validation-service[8236]: 2025/10/30 20:52:40 ✅ Domain ``oynf.com`` allowed ``` ``` 2025-10-30T20:52:40.283106-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893560.2830153,“logger”:“tls.permission.http”,“msg”:“response from permission endpoint”,“remote”:“203.119.65.147:64126”,“domain”:“``oynf.com``”,“url”:“`` http://localhost:5555/check?domain=oynf.com","status”:200\`\` }` 2025-10-30T20:52:40.388898-10:00 cadb caddy[9227]: {“level”:“warn”,“ts”:1761893560.3887486,“logger”:“tls”,“msg”:“stapling OCSP”,“error”:“no OCSP stapling for [oynf.com]: parsing OCSP response: ocsp: error from server: unauthorized”,“identifiers”:[“oynf.com”]} 2025-10-30T20:52:40.391869-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893560.3917673,“logger”:“tls.cache”,“msg”:“cache full; evicting random certificate”,“removing_subjects”:[“sqsb.net”],“removing_hash”:“716d3224f26ff9afbbe2b745acd83963ae61df5f25f630ae598d4473ad7bf37d”,“inserting_subjects”:[“oynf.com”],“inserting_hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} 2025-10-30T20:52:40.392015-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893560.391962,“logger”:“tls.cache”,“msg”:“added certificate to cache”,“subjects”:[“oynf.com”],“expiration”:1760918400,“managed”:true,“issuer_key”:“acme.zerossl.com-v2-DV90”,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”,“cache_size”:10000,“cache_capacity”:10000} 2025-10-30T20:52:40.392412-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893560.3920739,“logger”:“events”,“msg”:“event”,“name”:“cached_managed_cert”,“id”:“297d4f91-b7e2-4cb7-95cc-18f8ebc92991”,“origin”:“tls”,“data”:{“sans”:[“oynf.com”]}} 2025-10-30T20:52:40.392430-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893560.3921459,“logger”:“tls.handshake”,“msg”:“loaded certificate from storage”,“remote_ip”:“203.119.65.147”,“remote_port”:“64126”,“subjects”:[“oynf.com”],“managed”:true,“expiration”:1760918400,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} 2025-10-30T20:52:40.392441-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893560.392201,“logger”:“tls”,“msg”:“certificate needs renewal based on ARI window”,“subjects”:[“oynf.com”],“expiration”:1760918400,“ari_cert_id”:“D2vmS845R672fpAeefAwkZLIX6M.AK0wmaPiaOv1l3CqkZNThh0”,“next_ari_update”:1760937037.5656383,“renew_check_interval”:600,“window_start”:1759622399,“window_end”:1759795199,“selected_time”:1759641802,“renewal_cutoff”:1759641202} 2025-10-30T20:52:40.392832-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893560.3927138,“logger”:“tls.on_demand”,“msg”:“certificate has expired, but is already being renewed; waiting for renewal to complete”,“remote_ip”:“203.119.65.147”,“remote_port”:“64126”,“subjects”:[“oynf.com”],“expired”:1760918400,“revoked”:false} 2025-10-30T20:53:33.554472-10:00 cadb caddy[9227]: {“level”:“error”,“ts”:1761893613.5543156,“logger”:“tls.renew”,“msg”:“could not get certificate from issuer”,“identifier”:“oynf.com”,“issuer”:“acme.zerossl.com-v2-DV90”,“error”:“context canceled”} 2025-10-30T20:53:33.554529-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893613.554362,“logger”:“events”,“msg”:“event”,“name”:“cert_failed”,“id”:“012446c3-e277-4410-b0ed-c7fe4b7b0281”,“origin”:“tls”,“data”:{“error”:{},“identifier”:“oynf.com”,“issuers”:[“acme.zerossl.com-v2-DV90”],“remaining”:-975123561511448,“renewal”:true}} 2025-10-30T20:53:33.554573-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893613.5544283,“logger”:“tls.renew”,“msg”:“releasing lock”,“identifier”:“oynf.com”} 2025-10-30T20:53:33.555544-10:00 cadb caddy[9227]: {“level”:“error”,“ts”:1761893613.5549667,“logger”:“tls.on_demand”,“msg”:“renewing and reloading certificate”,“remote_ip”:“203.119.65.147”,“remote_port”:“64105”,“server_name”:“oynf.com”,“subjects”:[“oynf.com”],“expiration”:1760918400,“remaining”:-975123.554154688,“revoked”:false,“server_name”:“oynf.com”,“error”:“[oynf.com] Renew: context canceled”} 2025-10-30T20:53:33.555634-10:00 cadb caddy[9227]: {“level”:“error”,“ts”:1761893613.5551267,“logger”:“tls.on_demand”,“msg”:“renewing certificate on-demand failed”,“subjects”:[“oynf.com”],“not_after”:1760918400,“error”:“[oynf.com] Renew: context canceled”} 2025-10-30T20:53:33.555667-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893613.5551403,“logger”:“tls.handshake”,“msg”:“choosing certificate”,“identifier”:“oynf.com”,“num_choices”:1} 2025-10-30T20:53:33.555752-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893613.5551815,“logger”:“http.stdlib”,“msg”:“http: TLS handshake error from 203.119.65.147:64105: [oynf.com] Renew: context canceled”} 2025-10-30T20:53:33.555795-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893613.5551848,“logger”:“tls.handshake”,“msg”:“default certificate selection results”,“identifier”:“oynf.com”,“subjects”:[“oynf.com”],“managed”:true,“issuer_key”:“acme.zerossl.com-v2-DV90”,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} 2025-10-30T20:53:33.555825-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893613.5552077,“logger”:“tls.handshake”,“msg”:“matched certificate in cache”,“remote_ip”:“203.119.65.147”,“remote_port”:“64106”,“subjects”:[“oynf.com”],“managed”:true,“expiration”:1760918400,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} 2025-10-30T20:53:33.555894-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893613.555071,“logger”:“tls.handshake”,“msg”:“choosing certificate”,“identifier”:“oynf.com”,“num_choices”:1} 2025-10-30T20:53:33.555932-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893613.5552557,“logger”:“tls.handshake”,“msg”:“default certificate selection results”,“identifier”:“oynf.com”,“subjects”:[“oynf.com”],“managed”:true,“issuer_key”:“acme.zerossl.com-v2-DV90”,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} 2025-10-30T20:53:33.556349-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893613.5552847,“logger”:“tls.handshake”,“msg”:“matched certificate in cache”,“remote_ip”:“203.119.65.147”,“remote_port”:“64126”,“subjects”:[“oynf.com”],“managed”:true,“expiration”:1760918400,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} 2025-10-30T20:53:33.556379-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893613.5551462,“logger”:“tls.handshake”,“msg”:“choosing certificate”,“identifier”:“oynf.com”,“num_choices”:1} 2025-10-30T20:53:33.556409-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893613.5554001,“logger”:“tls.handshake”,“msg”:“default certificate selection results”,“identifier”:“oynf.com”,“subjects”:[“oynf.com”],“managed”:true,“issuer_key”:“acme.zerossl.com-v2-DV90”,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} 2025-10-30T20:53:33.556441-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893613.5554173,“logger”:“tls.handshake”,“msg”:“matched certificate in cache”,“remote_ip”:“203.119.65.147”,“remote_port”:“64110”,“subjects”:[“oynf.com”],“managed”:true,“expiration”:1760918400,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} 2025-10-30T20:56:47.151918-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.151681,“logger”:“events”,“msg”:“event”,“name”:“tls_get_certificate”,“id”:“cd0cedf9-129d-486e-b9b9-b816fbe326d2”,“origin”:“tls”,“data”:{“client_hello”:{“CipherSuites”:[4865,4867,4866,49195,49199,52393,52392,49196,49200,49162,49161,49171,49172,156,157,47,53],“ServerName”:“oynf.com”,“SupportedCurves”:[4588,29,23,24,25,256,257],“SupportedPoints”:“AA==”,“SignatureSchemes”:[1027,1283,1539,2052,2053,2054,1025,1281,1537,515,513],“SupportedProtos”:[“h2”,“http/1.1”],“SupportedVersions”:[772,771],“RemoteAddr”:{“IP”:“203.119.65.147”,“Port”:59474,“Zone”:“”},“LocalAddr”:{“IP”:“89.117.19.57”,“Port”:443,“Zone”:“”}}}} 2025-10-30T20:56:47.151953-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.1518002,“logger”:“tls.handshake”,“msg”:“choosing certificate”,“identifier”:“oynf.com”,“num_choices”:1} 2025-10-30T20:56:47.151961-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.1518097,“logger”:“tls.handshake”,“msg”:“default certificate selection results”,“identifier”:“oynf.com”,“subjects”:[“oynf.com”],“managed”:true,“issuer_key”:“acme.zerossl.com-v2-DV90”,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} 2025-10-30T20:56:47.151970-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.1518385,“logger”:“tls.handshake”,“msg”:“matched certificate in cache”,“remote_ip”:“203.119.65.147”,“remote_port”:“59474”,“subjects”:[“oynf.com”],“managed”:true,“expiration”:1760918400,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} 2025-10-30T20:56:47.151989-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893807.151855,“logger”:“tls”,“msg”:“certificate needs renewal based on ARI window”,“subjects”:[“oynf.com”],“expiration”:1760918400,“ari_cert_id”:“D2vmS845R672fpAeefAwkZLIX6M.AK0wmaPiaOv1l3CqkZNThh0”,“next_ari_update”:1760937037.5656383,“renew_check_interval”:600,“window_start”:1759622399,“window_end”:1759795199,“selected_time”:1759641802,“renewal_cutoff”:1759641202} 2025-10-30T20:56:47.152557-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.1523523,“logger”:“tls”,“msg”:“asking for permission for on-demand certificate”,“remote_ip”:“203.119.65.147”,“domain”:“oynf.com”} 2025-10-30T20:56:47.152585-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.152385,“logger”:“tls.permission.http”,“msg”:“asking permission endpoint”,“remote”:“203.119.65.147:59474”,“domain”:“oynf.com”,“url”:“````` http://localhost:5555/check?domain=oynf.com”\`\` ```}` ``` 2025-10-30T20:56:47.153863-10:00 cadb validation-service[8236]: 2025/10/30 20:56:47 ✅ Domainoynf.com allowed ``` ``` 2025-10-30T20:56:47.154051-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.1539469,“logger”:“tls.permission.http”,“msg”:“response from permission endpoint”,“remote”:“203.119.65.147:59474”,“domain”:“oynf.com”,“url”:“ http://localhost:5555/check?domain=oynf.com","status”:200\`\` ```}` ``` 2025-10-30T20:56:47.154076-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893807.154007,“logger”:“tls.on_demand”,“msg”:“attempting certificate renewal”,“remote_ip”:“203.119.65.147”,“remote_port”:“59474”,“server_name”:“``oynf.com``”,“subjects”:[“``oynf.com``”],“expiration”:1760918400,“remaining”:-975407.152331931,“revoked”:false} ``` ``` 2025-10-30T20:56:47.155131-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893807.1550434,“logger”:“tls.renew”,“msg”:“acquiring lock”,“identifier”:“``oynf.com``”} ``` ``` 2025-10-30T20:56:47.155266-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893807.1552098,“logger”:“tls.renew”,“msg”:“lock acquired”,“identifier”:“``oynf.com``”} ``` ``` 2025-10-30T20:56:47.156402-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893807.156325,“logger”:“tls.renew”,“msg”:“renewing certificate”,“identifier”:“``oynf.com``”,“remaining”:-975407.156319195} ``` ``` 2025-10-30T20:56:47.156437-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.1563828,“logger”:“events”,“msg”:“event”,“name”:“cert_obtaining”,“id”:“f6036eb7-bdcc-49ad-8206-a868c9b20f72”,“origin”:“tls”,“data”:{“forced”:false,“identifier”:“``oynf.com``”,“issuer”:“acme.zerossl.com-v2-DV90”,“remaining”:-975407156319195,“renewal”:true}} ``` ``` 2025-10-30T20:56:47.156594-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.1565301,“logger”:“tls”,“msg”:“created CSR”,“identifiers”:[“``oynf.com``”],“san_dns_names”:[“``oynf.com``”],“san_emails”: ```[ ]`,“common_name”:“”,“extra_extensions”:0}` ``` 2025-10-30T20:56:47.157383-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.1571403,“logger”:“events”,“msg”:“event”,“name”:“tls_get_certificate”,“id”:“23651464-a871-4b2a-a213-886c78f0cc6c”,“origin”:“tls”,“data”:{“client_hello”:{“CipherSuites”:[4865,4867,4866,49195,49199,52393,52392,49196,49200,49162,49161,49171,49172,156,157,47,53],“ServerName”:“``oynf.com``”,“SupportedCurves”:[4588,29,23,24,25,256,257],“SupportedPoints”:“AA==”,“SignatureSchemes”:[1027,1283,1539,2052,2053,2054,1025,1281,1537,515,513],“SupportedProtos”:[“h2”,“http/1.1”],“SupportedVersions”:[772,771],“RemoteAddr”:{“IP”:“203.119.65.147”,“Port”:59475,“Zone”:“”},“LocalAddr”:{“IP”:“89.117.19.57”,“Port”:443,“Zone”:“”}}}} ``` ``` 2025-10-30T20:56:47.157406-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.1572413,“logger”:“tls.handshake”,“msg”:“choosing certificate”,“identifier”:“``oynf.com``”,“num_choices”:1} ``` ``` 2025-10-30T20:56:47.157416-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.157252,“logger”:“tls.handshake”,“msg”:“default certificate selection results”,“identifier”:“``oynf.com``”,“subjects”:[“``oynf.com``”],“managed”:true,“issuer_key”:“acme.zerossl.com-v2-DV90”,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} ``` ``` 2025-10-30T20:56:47.157427-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.1572676,“logger”:“tls.handshake”,“msg”:“matched certificate in cache”,“remote_ip”:“203.119.65.147”,“remote_port”:“59475”,“subjects”:[“``oynf.com``”],“managed”:true,“expiration”:1760918400,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”} ``` ``` 2025-10-30T20:56:47.157439-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893807.157291,“logger”:“tls”,“msg”:“certificate needs renewal based on ARI window”,“subjects”:[“``oynf.com``”],“expiration”:1760918400,“ari_cert_id”:“D2vmS845R672fpAeefAwkZLIX6M.AK0wmaPiaOv1l3CqkZNThh0”,“next_ari_update”:1760937037.5656383,“renew_check_interval”:600,“window_start”:1759622399,“window_end”:1759795199,“selected_time”:1759641802,“renewal_cutoff”:1759641202} ``` ``` 2025-10-30T20:56:47.157674-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893807.1575754,“logger”:“http”,“msg”:“waiting on internal rate limiter”,“identifiers”:[“``oynf.com``”],“ca”:“`` https://acme.zerossl.com/v2/DV90",“account”:"andy@impire.com”\`\` }` 2025-10-30T20:56:47.157846-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893807.1577506,“logger”:“tls.on_demand”,“msg”:“certificate has expired, but is already being renewed; waiting for renewal to complete”,“remote_ip”:“203.119.65.147”,“remote_port”:“59475”,“subjects”:[“oynf.com”],“expired”:1760918400,“revoked”:false} 2025-10-30T20:57:55.001479-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893875.0011687,“logger”:“tls.cache”,“msg”:“cache full; evicting random certificate”,“removing_subjects”:[“oynf.com”],“removing_hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”,“inserting_subjects”:[“fkek.com”],“inserting_hash”:“f76e7c31ec18a6d59b3a99cabdc6f43ae0c4f3dedb94b423d883f1330ed38764”} 2025-10-30T20:57:55.001648-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893875.0012903,“logger”:“tls.cache”,“msg”:“removed certificate from cache”,“subjects”:[“oynf.com”],“expiration”:1760918400,“managed”:true,“issuer_key”:“acme.zerossl.com-v2-DV90”,“hash”:“c85bd762b5a06a6e21e357101b9c997cf6530fc7157b10caac629de7fdec1e46”,“cache_size”:9999,“cache_capacity”:10000} 2025-10-30T20:58:17.153217-10:00 cadb caddy[9227]: {“level”:“error”,“ts”:1761893897.1529884,“logger”:“tls.renew”,“msg”:“could not get certificate from issuer”,“identifier”:“oynf.com”,“issuer”:“acme.zerossl.com-v2-DV90”,“error”:“context canceled”} 2025-10-30T20:58:17.153264-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893897.1530936,“logger”:“events”,“msg”:“event”,“name”:“cert_failed”,“id”:“fd39ab17-570d-428b-a9c8-3e1a065b3f5f”,“origin”:“tls”,“data”:{“error”:{},“identifier”:“oynf.com”,“issuers”:[“acme.zerossl.com-v2-DV90”],“remaining”:-975407156319195,“renewal”:true}} 2025-10-30T20:58:17.153273-10:00 cadb caddy[9227]: {“level”:“info”,“ts”:1761893897.153176,“logger”:“tls.renew”,“msg”:“releasing lock”,“identifier”:“oynf.com”} 2025-10-30T20:58:17.154043-10:00 cadb caddy[9227]: {“level”:“error”,“ts”:1761893897.1538386,“logger”:“tls.on_demand”,“msg”:“renewing and reloading certificate”,“remote_ip”:“203.119.65.147”,“remote_port”:“59474”,“server_name”:“oynf.com”,“subjects”:[“oynf.com”],“expiration”:1760918400,“remaining”:-975407.152331931,“revoked”:false,“server_name”:“oynf.com”,“error”:“[oynf.com] Renew: context canceled”} 2025-10-30T20:58:17.154070-10:00 cadb caddy[9227]: {“level”:“error”,“ts”:1761893897.1539123,“logger”:“tls.on_demand”,“msg”:“renewing certificate on-demand failed”,“subjects”:[“oynf.com”],“not_after”:1760918400,“error”:“[oynf.com] Renew: context canceled”} 2025-10-30T20:58:17.154103-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893897.153986,“logger”:“http.stdlib”,“msg”:“http: TLS handshake error from 203.119.65.147:59474: [oynf.com] Renew: context canceled”} 2025-10-30T20:58:17.154208-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893897.1541166,“logger”:“tls.handshake”,“msg”:“no matching certificates and no custom selection logic”,“identifier”:“oynf.com”} 2025-10-30T20:58:17.154266-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893897.154194,“logger”:“tls.handshake”,“msg”:“all external certificate managers yielded no certificates and no errors”,“remote_ip”:“203.119.65.147”,“remote_port”:“59475”,“sni”:“oynf.com”} 2025-10-30T20:58:17.154280-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893897.154208,“logger”:“tls”,“msg”:“asking for permission for on-demand certificate”,“remote_ip”:“203.119.65.147”,“domain”:“oynf.com”} 2025-10-30T20:58:17.154292-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893897.1542397,“logger”:“tls.permission.http”,“msg”:“asking permission endpoint”,“remote”:“203.119.65.147:59475”,“domain”:“oynf.com”,“url”:“````` http://localhost:5555/check?domain=oynf.com”\`\` ```}` ``` 2025-10-30T20:58:17.156329-10:00 cadb validation-service[8236]: 2025/10/30 20:58:17 ✅ Domainoynf.com allowed ``` ``` 2025-10-30T20:58:17.157027-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893897.1568277,“logger”:“tls.permission.http”,“msg”:“response from permission endpoint”,“remote”:“203.119.65.147:59475”,“domain”:“oynf.com”,“url”:“ ````` http://localhost:5555/check?domain=oynf.com","status”:200\`\` }` 2025-10-30T20:58:17.157061-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893897.1569183,“logger”:“tls.handshake”,“msg”:“no certificate matching TLS ClientHello”,“remote_ip”:“203.119.65.147”,“remote_port”:“59475”,“server_name”:“oynf.com”,“remote”:“203.119.65.147:59475”,“identifier”:“oynf.com”,“cipher_suites”:[4865,4867,4866,49195,49199,52393,52392,49196,49200,49162,49161,49171,49172,156,157,47,53],“cert_cache_fill”:1,“load_or_obtain_if_necessary”:false,“on_demand”:true} 2025-10-30T20:58:17.157096-10:00 cadb caddy[9227]: {“level”:“error”,“ts”:1761893897.1570115,“logger”:“tls.on_demand”,“msg”:“renewing certificate on-demand failed”,“subjects”:[“oynf.com”],“not_after”:1760918400,“error”:“no certificate available for ‘oynf.com’”} 2025-10-30T20:58:17.157108-10:00 cadb caddy[9227]: {“level”:“debug”,“ts”:1761893897.1570683,“logger”:“http.stdlib”,“msg”:“http: TLS handshake error from 203.119.65.147:59475: no certificate available for ‘oynf.com’”} ```
