Unable to get module documentation to appear
When I first setup modules/http.handlers.ip2location — Caddy Documentation, my GitHub GitHub - ip2location/ip2location-caddy: Caddy middleware to add geolocation data via headers using IP2Location BIN or IP2Location.io API. · GitHub didn’t have the necessary comments in the codes to enable the parser to read the documentations.
After adding the comments in my codes, I then tagged a new patch version. However, I am still unable to view the documentation in the module page.
Can someone please let me know if my comments are correctly formatted or if there is something else I need to do to make the documentation appear.
It’s probably our mistake. I’m exploring a rewrite of our docs backend. Will try to prioritize it here soon. Sorry about that.
