Unable to access Pihole admin virtual host when using DHCP-Helper
Let me preface with this: I don’t know if this is a Caddy issue or a Pihole/DHCP-Helper issue.
I’m attempting to use Caddy for reverse proxy with HTTPS on my Pihole container. It works fine when I’m using Pihole without DHCP functionality, as I can access the admin control panel. When I restart the container with DHCP-helper, I can no longer access it and get an error.
DHCP-helper is set up with the link in section 5. I used the IP of the server in the DNSmasq config file instead of the external IP (public) since this is only going to be accessible on the local network.
{"level":"info","ts":1717268959.4707103,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"info","ts":1717268959.4760897,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//[::1]:2019","//127.0.0.1:2019","//localhost:2019"]}
{"level":"info","ts":1717268959.4782255,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000526080"}
{"level":"info","ts":1717268959.478618,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1717268959.4786983,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
{"level":"info","ts":1717268959.485951,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
{"level":"info","ts":1717268959.4865696,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1717268959.4869804,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
{"level":"info","ts":1717268959.4874444,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1717268959.4905396,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["pihole-4rknm.duckdns.org","vw-4rknm.duckdns.org"]}
{"level":"info","ts":1717268959.4923618,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1717268959.4925056,"msg":"serving initial configuration"}
{"level":"warn","ts":1717268959.4937022,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"d3dd01f2-1d67-4b5f-9df9-874d1170c2d0","try_again":1717355359.4937005,"try_again_in":86399.999999606}
{"level":"info","ts":1717268959.493777,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"error","ts":1717268978.5501444,"logger":"http.log.error.log0","msg":"dial tcp: lookup pihole on 127.0.0.11:53: no such host","request":{"remote_ip":"192.168.1.63","remote_port":"59235","client_ip":"192.168.1.63","proto":"HTTP/3.0","method":"GET","host":"pihole-4rknm.duckdns.org","uri":"/admin/","headers":{"Dnt":["1"],"Alt-Used":["pihole-4rknm.duckdns.org"],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Mode":["navigate"],"Priority":["u=1"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64; rv:126.0) Gecko/20100101 Firefox/126.0"],"Accept-Encoding":["gzip, deflate, br, zstd"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Site":["none"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,*/*;q=0.8"],"Cookie":[],"Sec-Gpc":["1"],"Accept-Language":["en-US,en;q=0.5"],"Sec-Fetch-User":["?1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h3","server_name":"pihole-4rknm.duckdns.org"}},"duration":0.034172848,"status":502,"err_id":"2zagfanux","err_trace":"reverseproxy.statusError (reverseproxy.go:1267)"}
Built Caddy with
xcaddy build --with github.com/caddy-dns/duckdns
Configured the compose.yaml file and Caddyfile per this guide and caddy.env from this guide.
  • Arch Linux using Linux-LTS kernel, x86_64
  • Docker and Docker Compose
sudo docker compose up -d
  pihole:
    container_name: pihole
    image: pihole/pihole:latest
      DNSMASQ_LISTENING: all
      TZ: America/Boise
      VIRTUAL_HOST: pihole-4rknm.duckdns.org
      WEBPASSWORD: [redacted]
      FTLCONF_LOCAL_IPV4: 192.168.1.60
      DHCP_ACTIVE: true
      DHCP_START: 192.168.1.2
      DHCP_END: 192.168.1.254
      DHCP_ROUTER: 192.168.1.1
      WEBTHEME: default-dark
      - /srv/pihole/etc-pihole:/etc/pihole
      - /srv/pihole/etc-dnsmasq.d:/etc/dnsmasq.d
    #   https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
    cap_add:
      - NET_ADMIN # Required if you are using Pi-hole as your DHCP server, else not needed
    depends_on:
      - dhcphelper
      - caddy
      backend:
          ipv4_address: '172.31.0.100'
  dhcphelper:
    build: /srv/dhcp-helper
    network_mode: "host"
    command: -s 172.31.0.100
    cap_add:
      - NET_ADMIN
  vaultwarden:
    image: vaultwarden/server:latest
    container_name: vaultwarden
      YUBICO_CLIENT_ID: "90318"
      YUBICO_SECRET_KEY: "bbBHnYXExqmGGMWS4C3ooi8nPxE="
      - /srv/vaultwarden/vw-data:/data
    image: caddy:2
      - 443:443
      - 443:443/udp # Needed for HTTP/3.
      - /srv/caddy/caddy:/usr/bin/caddy  # Your custom build of Caddy.
      - /srv/caddy/Caddyfile:/etc/caddy/Caddyfile:ro
      - /srv/caddy/caddy-config:/config
      - /srv/caddy/caddy-data:/data
#      DOMAIN: "https://4rknm.duckdns.org"  # Your domain.
      EMAIL: "rileymotter@protonmail.com"                 # The email address to use for ACME registration.
      DUCKDNS_TOKEN: "efcc5ce9-dd5d-44d4-bb46-f06afdf27481"                   # Your Duck DNS token.
      LOG_FILE: "/data/access.log"
  backend:
    ipam:
      config:
        - subnet: 172.31.0.0/16
# PIHOLE
pihole-4rknm.duckdns.org {
                level INFO
                output file {$LOG_FILE} {
                        roll_size 10MB
                        roll_keep 10
        # Use the ACME DNS-01 challenge to get a cert for the configured domain.
                dns duckdns {$DUCKDNS_TOKEN}
        # This setting may have compatibility issues with some browsers
        # (e.g., attachment downloading on Firefox). Try disabling this
        # if you encounter issues.
        encode zstd gzip
        reverse_proxy pihole:80
# VAULTWARDEN
vw-4rknm.duckdns.org {
                level INFO
                        roll_size 10MB
                        roll_keep 10
        encode zstd gzip
        reverse_proxy vaultwarden:80
I would rather use the IP address instead of the hostname “pihole”.
Your logfile clearly states that this is the issue with “no such host”:
The IP address, in this case, 172.31.0.100? It gives me:
"msg":"dial tcp 172.31.0.100:80: i/o timeout","request"
Edit: I think I figured it out. I needed to create a custom network so that Caddy and Pihole could communicate with each other. Since specifying ONLY network: backend, Caddy couldn’t see it anymore.
I changed my file to reflect the following:
  pihole:
      TZ: America/Boise
      DHCP_ACTIVE: true
    cap_add:
    depends_on:
      - dhcphelper
      - caddy
      backend:
      caddy_net: {}
  dhcphelper:
    cap_add:
      - NET_ADMIN
  backend:
    ipam:
      config:
  caddy_net:
    external: true
Apologies for forgetting a basic concept. Thanks for the assistance, Monviech.
