Hello Caddy community! (newcomer here)
I am currently trying to implement a webdav server reverse proxied by Caddy. The webdav server is basically a bunch of dufs processes serving files over unix sockets.
I can access the webdav without basic_auth, which is great!
But when I try to add in basic_auth, I always get “Could not connect” errors on my webdav clients (testing in MacOS Finder). I feel like I am using basic_auth as documented, so must be missing something obvious, but spent too much time trying to debug this.
Help? ![]()
I ran the server, tried logging in and then stopped the server. Only 3 messages show up in log file.
2024/11/19 16:35:04.606 e[34mINFOe[0m http.log.access.log0 handled request {"request": {"remote_ip": "127.0.0.1", "remote_port": "65220", "client_ip": "127.0.0.1", "proto": "HTTP/1.1", "method": "OPTIONS", "host": "127.0.0.1:8443", "uri": "/webdav/path1/", "headers": {"Content-Length": ["0"], "Connection": ["close"], "User-Agent": ["WebDAVLib/1.3"], "Accept": ["*/*"]}, "tls": {"resumed": false, "version": 771, "cipher_suite": 49195, "proto": "", "server_name": "127.0.0.1"}}, "bytes_read": 0, "user_id": "", "duration": 0.00078775, "size": 0, "status": 401, "resp_headers": {"Www-Authenticate": ["Basic realm=\"restricted\""], "Server": ["Caddy"], "Alt-Svc": ["h3=\":8443\"; ma=2592000"]}}
2024/11/19 16:35:18.475 e[34mINFOe[0m http.log.access.log0 handled request {"request": {"remote_ip": "127.0.0.1", "remote_port": "65222", "client_ip": "127.0.0.1", "proto": "HTTP/1.1", "method": "OPTIONS", "host": "127.0.0.1:8443", "uri": "/webdav/path1/", "headers": {"Accept": ["*/*"], "Content-Length": ["0"], "Connection": ["close"], "User-Agent": ["WebDAVLib/1.3"]}, "tls": {"resumed": false, "version": 771, "cipher_suite": 49195, "proto": "", "server_name": "127.0.0.1"}}, "bytes_read": 0, "user_id": "", "duration": 0.000053459, "size": 0, "status": 401, "resp_headers": {"Server": ["Caddy"], "Alt-Svc": ["h3=\":8443\"; ma=2592000"], "Www-Authenticate": ["Basic realm=\"restricted\""]}}
2024/11/19 16:35:19.606 e[34mINFOe[0m http.log.access.log0 handled request {"request": {"remote_ip": "127.0.0.1", "remote_port": "65223", "client_ip": "127.0.0.1", "proto": "HTTP/1.1", "method": "OPTIONS", "host": "127.0.0.1:8443", "uri": "/webdav/path1/", "headers": {"User-Agent": ["WebDAVLib/1.3"], "Accept": ["*/*"], "Authorization": ["REDACTED"], "Content-Length": ["0"], "Connection": ["close"]}, "tls": {"resumed": false, "version": 771, "cipher_suite": 49195, "proto": "", "server_name": "127.0.0.1"}}, "bytes_read": 0, "user_id": "user1", "duration": 1.110079292, "size": 0, "status": 401, "resp_headers": {"Server": ["Caddy"], "Alt-Svc": ["h3=\":8443\"; ma=2592000"], "Allow": ["GET,HEAD,PUT,OPTIONS,DELETE,PATCH,PROPFIND,COPY,MOVE,CHECKAUTH,LOGOUT"], "Dav": ["1, 2, 3"], "Www-Authenticate": ["Digest realm=\"DUFS\", nonce=\"673cbe47ade8053ed9f9016c001f4c526b\", qop=\"auth\"", "Basic realm=\"DUFS\""], "Content-Length": ["0"], "Date": ["Tue, 19 Nov 2024 16:35:19 GMT"]}}
I think from the stdout, these ones are about the failed authentication:
2024/11/19 16:35:17.514 DEBUG http.stdlib http: TLS handshake error from [fe80::1cfa:ba1:43b0:8bec%en0]:52283: tls: client offered only unsupported versions: [301]
2024/11/19 16:35:18.466 DEBUG events event {"name": "tls_get_certificate", "id": "484ae097-77ef-4ad7-ae84-1f690162e23b", "origin": "tls", "data": {"client_hello":{"CipherSuites":[255,49196,49195,49188,49187,49162,49161,49160,49200,49199,49192,49191,49172,49171,49170,157,156,61,60,53,47,10],"ServerName":"127.0.0.1","SupportedCurves":[23,24,25],"SupportedPoints":"AA==","SignatureSchemes":[1025,513,1281,1537,1027,515,1283,1539],"SupportedProtos":null,"SupportedVersions":[771,770,769],"RemoteAddr":{"IP":"127.0.0.1","Port":65222,"Zone":""},"LocalAddr":{"IP":"127.0.0.1","Port":8443,"Zone":""}}}}
2024/11/19 16:35:18.466 DEBUG tls.handshake choosing certificate {"identifier": "127.0.0.1", "num_choices": 1}
2024/11/19 16:35:18.466 DEBUG tls.handshake default certificate selection results {"identifier": "127.0.0.1", "subjects": ["127.0.0.1"], "managed": true, "issuer_key": "local", "hash": "5a7f0d7b69d42a5aa7fe64bfbcc664e19b071fac010bd1ab13ce2fa1e1eab533"}
2024/11/19 16:35:18.466 DEBUG tls.handshake matched certificate in cache {"remote_ip": "127.0.0.1", "remote_port": "65222", "subjects": ["127.0.0.1"], "managed": true, "expiration": "2024/11/19 20:51:11.000", "hash": "5a7f0d7b69d42a5aa7fe64bfbcc664e19b071fac010bd1ab13ce2fa1e1eab533"}
2024/11/19 16:35:18.475 DEBUG http.log.error.log0 not authenticated {"request": {"remote_ip": "127.0.0.1", "remote_port": "65222", "client_ip": "127.0.0.1", "proto": "HTTP/1.1", "method": "OPTIONS", "host": "127.0.0.1:8443", "uri": "/webdav/path1/", "headers": {"User-Agent": ["WebDAVLib/1.3"], "Accept": ["*/*"], "Content-Length": ["0"], "Connection": ["close"]}, "tls": {"resumed": false, "version": 771, "cipher_suite": 49195, "proto": "", "server_name": "127.0.0.1"}}, "duration": 0.000053459, "status": 401, "err_id": "r3mi480bu", "err_trace": "caddyauth.Authentication.ServeHTTP (caddyauth.go:89)"}
2024/11/19 16:35:18.478 DEBUG events event {"name": "tls_get_certificate", "id": "008a7a8d-4401-4fad-b1d5-abbd0a3b9543", "origin": "tls", "data": {"client_hello":{"CipherSuites":[255,49196,49195,49188,49187,49162,49161,49160,49200,49199,49192,49191,49172,49171,49170,157,156,61,60,53,47,10],"ServerName":"127.0.0.1","SupportedCurves":[23,24,25],"SupportedPoints":"AA==","SignatureSchemes":[1025,513,1281,1537,1027,515,1283,1539],"SupportedProtos":null,"SupportedVersions":[771,770,769],"RemoteAddr":{"IP":"127.0.0.1","Port":65223,"Zone":""},"LocalAddr":{"IP":"127.0.0.1","Port":8443,"Zone":""}}}}
2024/11/19 16:35:18.478 DEBUG tls.handshake choosing certificate {"identifier": "127.0.0.1", "num_choices": 1}
2024/11/19 16:35:18.478 DEBUG tls.handshake default certificate selection results {"identifier": "127.0.0.1", "subjects": ["127.0.0.1"], "managed": true, "issuer_key": "local", "hash": "5a7f0d7b69d42a5aa7fe64bfbcc664e19b071fac010bd1ab13ce2fa1e1eab533"}
2024/11/19 16:35:18.478 DEBUG tls.handshake matched certificate in cache {"remote_ip": "127.0.0.1", "remote_port": "65223", "subjects": ["127.0.0.1"], "managed": true, "expiration": "2024/11/19 20:51:11.000", "hash": "5a7f0d7b69d42a5aa7fe64bfbcc664e19b071fac010bd1ab13ce2fa1e1eab533"}
2024/11/19 16:35:18.572 DEBUG http.stdlib http: TLS handshake error from [fe80::1cfa:ba1:43b0:8bec%en0]:52285: tls: client offered only unsupported versions: [301]
Installed using homebrew
MacOS 15.1 (24B83)
(Not using Docker)
caddy run --config Caddyfile
Not relevant
http_port 8080
https_port 8443
localhost, 127.0.0.1 {
# Reverse proxies to DUFS webdav (NOTE: removed user-pass info)
basic_auth {
user1 $2a$......
user2 $2a$14$....
# This works with basic_auth, but reverse proxies dont
#respond "Welcome, {http.auth.user.id}" 200
# DAV path 1
redir /webdav/path1 /webdav/path1/
handle /webdav/path1/* {
reverse_proxy unix//tmp/dufs-path1.sock
# Max file uploads/download size
request_body {
max_size 10GB
# Enable logging
output file ./logs/caddy.log
#format json
format console
# Fallback for any otherwise unhandled requests, maybe a 404 if you want
respond "Nope!" 404
DUFS (rust based file server): GitHub - sigoden/dufs: A file server that supports static serving, uploading, searching, accessing control, webdav... · GitHub
6. Additional Info
Steps to recreate (macOS):
brew install dufs
cd /path/to/test/directory
# copy dufs-config.yml as written below
dufs -c dufs-config.yml &
# copy Caddyfile contents
caddy run -c Caddyfile
# In finder, open (cmd+k): https://127.0.0.1:8443/webdav/path1/
# Upon credential request, add user and password as configured
# At this stage, I hope you see the same error
# later you can comment/remove the basic_auth from Caddyfile to confirm if webdav is accessible like I can
dufs-config.yml
# Modify path before testing! (should have perms)
serve-path: '/path/to/share'
bind: '/tmp/dufs-path1.sock'
path-prefix: '/webdav/path1'
hidden:
- '.DS_Store'
- '.DS_Store?'
# User auth taken care by caddy
# just provide files with either rw/ro permissions
auth:
- '@/:rw'
allow-all: false
allow-upload: true
allow-delete: true
allow-search: true
allow-symlink: false
allow-archive: false
enable-cors: false
render-index: false
render-try-index: false
render-spa: false
# DUFS logs become bloated and not useful
log-format: ''
My credentials are correct when entered, since removing the reverse proxies and just having a respond works (when opening in browser).
