1. Output of caddy version
CentOS7
systemctl start caddy
Type=notify
(handle_info_log) {
output file /var/log/caddy/info.log {
roll_size 100MiB
roll_keep_for 30d
format console {
time_format wall
time_local
level INFO
(handle_error_log) {
output file /var/log/caddy/error.log {
roll_size 30MiB
roll_keep_for 30d
format console {
time_format wall
time_local
level ERROR
(handle_errors) {
handle_errors {
rewrite * /{err.status_code}.html
com.exampl.cn {
import handle_errors
import handle_info_log
import handle_error_log
@apk path /apk*
file_server @apk {
root /opt/demo-0springcloud/mobile
@ipa path /ipa*
file_server @ipa {
@videosample path /videosample*
file_server @videosample {
root /opt/demo-0springcloud/video
The different paths to a same project location, how to config? For example , path /apk route to the actual project location mobile, and the path /ipa is same as /apk .
