Two certs, one wildcard
I want SSL for mail.example.com to be handled automatically by Caddy and get a certificate in the default way, but I want everything else (*.example.com), to use a manually specified local cert.
Currently, Caddy is ignoring the defined host (mail.example.com), and just using the wildcard certificate from the section directly below it.
If I comment out the wildcard handler altogether, I get what I want, and it pulls a cert for mail.example.com.
How can I handle both situations the way I want? Apologies for redacting my post, but this is production facing and the Caddyfile has some other unrelated sites in it, that I don’t want exposed.
logger=http.auto_https msg=skipping automatic certificate management because one or more matching certificates are already loaded domain=mail.example.com server_name=srv0
Docker Compose
amd64
    image: caddy:latest
      - ./data:/data
      - ./config:/config
      - ./certs:/certs
      - ./logs:/logs
      - 443:443
	email webmaster@example.com
	# auto_https ignore_loaded_certs ## this didn't work either...
mail.example.com { ## this host should get a cert automatically
	reverse_proxy {$HOST}:9002 # Docker Mail Server
*.example.com { ## only the wildcard hosts, should use the manually specified wildcard
	tls /certs/cert.txt /certs/key.txt
	@app1 host app1.example.com
	handle @app1 {
		reverse_proxy {$HOST}:1234 # Etc etc
Any takers?
I can try to take a look at this as soon as my work machine is back online – give it a day or so :slight_smile:
