Note that I’ve redacted my domain names here … but I can replace them with the correct names if needed.
I have two problems:
- I’m trying to run immich, but I can’t get it working. My caddyfile block is
immich.mysite.net:443 {
reverse_proxy immich:2283
I’ve also tried with port 3001. However, neither work, all I’m getting is a message that “The page isn’t working”, with http error 502.
- I’m also trying to serve my blog, which is a static web site (I use Hugo for it). I want to protect it, of course, with https. But this isn’t sufficient:
mysite.net:443 {
root * /home/me/Docker/blog
The “index.html” file is in the directory shown.
docker logs caddy
, when trying to access immich:
{"level":"error","ts":1714030809.612247,"logger":"http.log.error","msg":"dial tcp: lookup immich on 127.0.0.11:53: no such host","request":{"remote_ip":"157.211.238.17","remote_port":"42068","client_ip":"157.211.238.17","proto":"HTTP/3.0","method":"GET","host":"immich.numbersandshapes.net","uri":"/","headers":{"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Fetch-Site":["none"],"Accept-Language":["en-GB,en-US;q=0.9,en;q=0.8"],"Sec-Ch-Ua-Platform":["\"Linux\""],"Sec-Fetch-User":["?1"],"Accept-Encoding":["gzip, deflate, br"],"User-Agent":["Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36"],"Sec-Ch-Ua":["\"Not_A Brand\";v=\"8\", \"Chromium\";v=\"120\", \"Google Chrome\";v=\"120\""],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-Dest":["document"],"Upgrade-Insecure-Requests":["1"],"Cookie":[]},"tls":{"resumed":false,"version":772,"cipher_suite":4867,"proto":"h3","server_name":"immich.numbersandshapes.net"}},"duration":0.003106129,"status":502,"err_id":"4andu2mxy","err_trace":"reverseproxy.statusError (reverseproxy.go:1267)"}
When trying to access my blog I get an http error 404.
I’m using docker compose, and I’ve specifically used version 2.7.6.
Using docker and docker compose. Up until recently, I used SWAG as my reverse proxy (it’s basically a front end to nginx plus a few extras), but I want to shift to caddy to support an app still in development, which doesn’t work with nginx. The relevant parts of my docker_compose_caddy.yml
file are:
image: caddy:2.7.6
restart: always
- "443:443/udp"
- caddy_net
- /home/me/Docker/Caddy/Caddyfile:/etc/caddy/Caddyfile
- caddy_data:/data
- caddy_config:/config
caddy_net:
external: true
caddy_data:
caddy_config:
Ubuntu 20.04LTS; docker 25.0.1, docker compose 2.24.2
First to start the containers, or restart them if I’ve made any changes to the docker compose file:
docker compose -f docker_compose_caddy.yml up -d
and if I make any changes to the Caddyfile:
docker restart caddy
or
docker compose exec -w /etc/caddy caddy caddy reload
I’m doing everything with docker compose.
Is above enough?
email <my email>
# mealie is working
mealie.mysite.net {
reverse_proxy mealie:9000
# portainer is now working
portainer.mysite.net {
reverse_proxy portainer:9000
# adminer is working
adminer.mysite.net:443 {
reverse_proxy adminer:8080
# not yet working
# blog not yet working
mysite.net:443 {
All the subdomains have an A record defined with my name hosting service (who also provide DNS).
Possibly not relevant
I hope that’s enough information! I’ve done quite a bit of reading, on the Caddy site as well as elsewhere, but something is still eluding me. Many thanks!
