Two Angular apps on the same VPS?
caddy:2.4.6-alpine and caddy:2.4.5-alpine
with docker compose (see below):
Using Docker (compose)
docker-compose -f docker-compose.yml up -d
version: "3.7"
  vendingdb:
    image: mysql:latest
    container_name: vendingdb
      - vending_db:/var/lib/mysql
      MYSQL_ROOT_HOST: '%'
      MYSQL_ROOT_USER: example
      MYSQL_ROOT_PASSWORD: example
      MYSQL_DATABASE: vendingdb
  vending-app:
    build:
      context: ./
      dockerfile: Dockerfile
    depends_on:
      - vendingdb
      - SPRING_PROFILES_ACTIVE=prod
  vending-ui:
    build: ../frontend
    container_name: frontend_vending
      - caddy_data:/data
      - caddy_config:/config
  caddy_data:
  caddy_config:
  vending_db:
vast.rest {
	encode zstd gzip
	handle /api/* {
		reverse_proxy vending-app:8082
		root * /srv
		try_files {path} index.html
I have a single VPS with two DNS connected to it. I’m already running another instance of mysql (port 3306) + java spring (port 8080) + angular (exposing 80 and 443) and connecting it with Caddy to one of the DNS instances with some test app, which works fine.
Now I’m wondering - is it it even possible to have two “front end” apps running on the same VPS?
I’ve changed the ports for mysql and spring, but what about the ones for angular (80/443)? I am not even sure if this is Caddy’s work or not…
Yes, absolutely. Just make another site block in your config that handles the routes for the other app:
first.example.com {
second.example.com {
Make sure the Caddy container can proxy to the other app, make sure they share a docker network. You can create a docker network externally that you can add both Caddy and the other app to.
You would need to use a different directory for the two apps in Caddy though, for example /srv/first and /srv/second, so that they’re not overlapping volumes in the Caddy container.
Replying before the topic is auto closed, been busy with aws certification lately, but almost done with it and I’ll edit this/add a new comment in the next week (hopefully) with a response if the suggestions worked and what exactly changed in my configurations and docker.
