Tweaking Frakenphp Caddyfile for Laravel Octane
Hey there!
What I’m up to:
I’m attempting to tweak the Caddyfile used with FrankenPHP + Laravel Octane. This is what’s being used:
Is there a way for me to get the final output from the running server?
	{$CADDY_GLOBAL_OPTIONS}
	admin localhost:{$CADDY_SERVER_ADMIN_PORT}
	frankenphp {
		worker "{$APP_PUBLIC_PATH}/frankenphp-worker.php" {$CADDY_SERVER_WORKER_COUNT}
{$CADDY_SERVER_SERVER_NAME} {
		level {$CADDY_SERVER_LOG_LEVEL}
		# Redact the authorization query parameter that can be set by Mercure...
		format filter {
			wrap {$CADDY_SERVER_LOGGER}
			fields {
				uri query {
					replace authorization REDACTED
	route {
		root * "{$APP_PUBLIC_PATH}"
		encode zstd br gzip
		# Mercure configuration is injected here...
		{$CADDY_SERVER_EXTRA_DIRECTIVES}
		php_server {
			index frankenphp-worker.php
			# Required for the public/storage/ directory...
			resolve_root_symlink
The Goals
What I’d like to do is add some protections/cache headers for static assets:
  1. Returning 404 or 401 for dot files and files of specific extensions
  2. Adding cache headers for static files ending in specific extensions
What I’ve Tried
I’m still working my way around the Caddyfile and would love any pointers - here’s what I’ve tried (in diff syntax):
	frankenphp {
		format filter {
			fields {
				uri query {
	route {
		encode zstd br gzip
		php_server {
+		file_server {
+			hide *.bak *.conf *.dist *.fla *.ini *.inc *.inci *.log *.orig *.psd *.sh *.sql *.swo *.swp *.swop */.*
However, after restarting Octane, I can still get “protected” files:
Starting a server:
php -d variables_order=EGPCS artisan octane:start \
    --server=frankenphp --host=0.0.0.0 --admin-port=2019 \
    --port=8080 --caddyfile=./Caddyfile
And sending requests:
curl -i http://0.0.0.0:8080/.env
HTTP/1.1 200 OK
Accept-Ranges: bytes
Content-Length: 4
Etag: "sdya1l4"
Last-Modified: Thu, 23 May 2024 18:00:57 GMT
Server: Caddy
Date: Thu, 23 May 2024 18:11:05 GMT
foo
curl -i http://0.0.0.0:8080/backup.bak
HTTP/1.1 200 OK
Content-Length: 9
Etag: "sdyai99"
Last-Modified: Thu, 23 May 2024 18:10:57 GMT
Server: Caddy
Date: Thu, 23 May 2024 18:11:10 GMT
backups!
./frankenphp --version
# FrankenPHP 1.1.5 PHP  Caddy v2.7.6 h1:w0NymbG2m9PcvKWsrXO6EEkY9Ru4FJK8uQbYcev1p3A=
# Laravel setup w/ Octane
composer create-project laravel/laravel frankentest
cd frankentest
composer require laravel/octane
php artisan octane:install --server=frankenphp
# Copy the Caddyfile stub so we can play with it
cp vendor/laravel/octane/src/Commands/stubs/Caddyfile ./Caddyfile
# Start Frankenphp with the local Caddyfile
MacOS, M3 (ARM) - This is not in Docker but occurs within Docker as well
Whoops, okay - directive order matters. I swapped file_server to be BEFORE php_server and it’s doing the needful.
# stuff omitted
	route {
		encode zstd br gzip
+       file_server {
		php_server {
-       file_server {
-			hide *.bak *.conf *.dist *.fla *.ini *.inc *.inci *.log *.orig *.psd *.sh *.sql *.swo *.swp *.swop */.*
And for completeness, this is working as well for static asset caching (so far, got more tweaks to do!)
route {
		encode zstd br gzip
+        @static {
+            file
+            path *.js *.css
+        # 1 year, similar to h5bp
+        header @static Cache-Control max-age=31536000
        file_server {
		php_server {
FYI, the php_server directive from FrankenPHP is a shortcut for a longer config. See the docs FrankenPHP: the modern PHP app server it shows the long form. I suggest that you use the long-form so that you can configure the file_server that’s built into that directive instead of adding another in front.
Also, your config looks somewhat outdated compared to the current recommendations – using route forces order inside of your config to matter, whereas if you use the order global option, the Caddyfile’s directive sorting will deal with it. Lets you un-indent your config one step too.
An alternate option is to use a matcher+error to reject those files, like this:
@rejected path *.bak *.conf *.dist *.fla *.ini *.inc *.inci *.log *.orig *.psd *.sh *.sql *.swo *.swp *.swop */.*
error @rejected 404
You can present a custom error page with handle_errors if you need to.
Thank you for the pointers, much appreciated!
I may leave the order and route alone for this exact moment, I suspect that’ll be an upstream change (I’ll bring it up to the Laravel team - I’m not yet sure if this configuration I grabbed was created by the Octane team or Frankenphp team).
What’s the best way to reject those files but NOT */.well-known/* ?
Kinda tricky. Could either switch to using a complicated path_regexp (I’ll leave that to you to write if you want), or you could use an expression matcher which allows you to use boolean logic.
@rejected `path('*.bak', '*.conf', '*.dist', '*.fla', '*.ini', '*.inc', '*.inci', '*.log', '*.orig', '*.psd', '*.sh', '*.sql', '*.swo', '*.swp', '*.swop', '*/.*') && !path(' `*/.well-known/*`')`
error @rejected 404
Lovely, thank you!
For anyone watching / the future / my future self, here’s the final thing for now:
	frankenphp {
		format filter {
			fields {
				uri query {
	route {
		encode zstd br gzip
		@static {
			file
			path *.js *.css *.jpg *.jpeg *.gif *.png *.ico *.cur *.gz *.svg *.svgz *.mp4 *.mp3 *.ogg *.ogv *.webm *.htc *.woff2 *.woff
		@staticshort {
			file
			path *.json *.xml *.rss
		# 1 year, similar to h5bp nginx config
		header @static Cache-Control "public, immutable, stale-while-revalidate, max-age=31536000"
		# 1 hour max, gets validated with the origin server
		# https://developer.mozilla.org/en-US/docs/Web/HTTP/Headers/Cache-Control#no-cache
		header @staticshort Cache-Control "no-cache, max-age=3600"
		# Restrict access to dot files and certain file extensions
		@rejected `path('*.bak', '*.conf', '*.dist', '*.fla', '*.ini', '*.inc', '*.inci', '*.log', '*.orig', '*.psd', '*.sh', '*.sql', '*.swo', '*.swp', '*.swop', '*/.*') && !path('*/.well-known/')`
		error @rejected 401
		php_server {
This gets (not totally but pretty close) on par to caching + secure file access to H5BP’s nginx configuration.
