Trying to use Environment Variables in Caddyfile and failing
Im trying to use environment variables to fill trusted_proxies but not having any luck
My Caddyfile is as follows:
        {$CADDY_GLOBAL_OPTIONS}
Running the following I get an error
/srv # CADDY_GLOBAL_OPTIONS="servers {\ntrusted_proxies static 127.0.0.1/8\n}" caddy adapt
2025/10/23 21:44:27.468 INFO    using adjacent Caddyfile
Error: parsing caddyfile tokens for 'servers': wrong argument count or unexpected line ending after 'static', at Caddyfile:3
If I change my Caddyfile to be
        servers {
then run
/srv # caddy adapt
2025/10/23 21:45:48.093 INFO    using adjacent Caddyfile
2025/10/23 21:45:48.094 WARN    caddyfile       Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies    {"file": "Caddyfile", "line": 2}
It works fine
Is there something Im missing about how to include envs into Caddyfiles?
I’ve tried this with both “\n” and no “\n”
Of note it also works with:
/srv # CADDY_GLOBAL_OPTIONS="debug" caddy adapt
2025/10/23 21:52:42.770 INFO    using adjacent Caddyfile
{"logging":{"logs":{"default":{"level":"DEBUG"}}}}
and
/srv # CADDY_GLOBAL_OPTIONS="debug\
> " caddy adapt
2025/10/23 21:54:01.754 INFO    using adjacent Caddyfile
but not
> trusted_proxies 127.0.0.1/8\
> }" caddy adapt
2025/10/23 21:55:01.759 INFO    using adjacent Caddyfile
Error: parsing caddyfile tokens for 'servers': wrong argument count or unexpected line ending after '127.0.0.1/8}', at Caddyfile:3
v2.10.2
Docker
	respond "Alive!"
$ CADDY_GLOBAL_OPTIONS='servers {
}' caddy adapt
2025/10/24 23:41:07.665	INFO	using adjacent Caddyfile
{"apps":{"http":{"servers":{"srv0":{"listen":[":80"],"routes":[{"handle":[{"body":"Alive!","handler":"static_response"}]}],"trusted_proxies":{"ranges":["127.0.0.1/8"],"source":"static"}}}}}}
2025/10/24 23:41:07.667	WARN	caddyfile	Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies	{"file": "Caddyfile", "line": 8}
}' caddy run
$ jq . autosave.json
  "apps": {
    "http": {
      "servers": {
        "srv0": {
          "listen": [
            ":80"
          "routes": [
              "handle": [
                  "body": "Alive!",
                  "handler": "static_response"
          "trusted_proxies": {
            "ranges": [
              "127.0.0.1/8"
            "source": "static"
You can also do:
export CADDY_GLOBAL_OPTIONS="$(cat <<'EOF'
servers {
EOF
$ docker run -d \
  -v "$PWD/Caddyfile:/etc/caddy/Caddyfile" \
  -e CADDY_GLOBAL_OPTIONS="$CADDY_GLOBAL_OPTIONS" \
  caddy:latest
or in docker-compose.yaml:
  CADDY_GLOBAL_OPTIONS: |
    servers {
Thanks!
Those work! I still cant get my specific setup to work but thats because im trying to set what you’ve done in the Dockerfile as an ENV setting and for whatever reason it doesnt translate but thats something I’ll have to work around
