Trying to run localhost https with mutiple sites
I can get a config file setup to run one https site in my local domain but not able to configure a file to run two or more.
This works (one website) Caddyfile:
https://192.168.0.23 {
    root * c:\dev\vue-quasar-app\Frontend\dist
    tls internal
This does not work (two websites) Caddyfile:
    tls internal
    @pwa path /pwa/*
    handle @pwa {
    root * C:\dev\QuasarCliVite\dist\pwa
    @quasarapp path /quasarapp
    handle @quasarapp {
https://192.168.0.23/quasarapp
Error: 404 cannot be found, does not resolve to the website.
I just copied the exe to c:\dev\caddy sub dir. Then run via windows cmd prompt:
running windows 11 Version 24H2
C:\dev\caddy>caddy_windows_amd64 run --config Caddyfile
N/A
https://192.168.0.231 {
    tls internal
    @pwa path /pwa/*
    handle @pwa {
    handle @quasarapp {
This does work for a caddy file. However, it’s only one web site. I would like to run multiple.
    tls internal
I cannot replicate. Are you sure the path has an index file?
One is dist\pwa\index.html, the other is Frontend\dist\index.html. If you are up for reproducing, I added the dist to the repositories on github. You can check them out here:
https://github.com/billjenner/QuasarCliVite
Bill
Your app requires mongodb and whtanot. I don’t have these prerequisites handy. At a glance, I see your matcher doesn’t have wildcard * at the end, which means it’ll only match and handle /quasarapp, but nothing under /quasarapp/assets*.
Also, your app has to know that it’s served on a sub-path.
Lastly, it’s not clear if the shared log is from the browser or your own app or something else.
I’ve tried it multiple ways, with an asterisk, without an asterisk. At this point, I’m wondering if the windows version even works with handle or handle_path. I can’t get it to work.
You have to share more and better logs. Share some Caddy logs. Clarify where the already shared logs are from.
URL
https://192.168.0.23/pwa
Caddyfile
	tls internal
    handle_path /pwa/* {
		level DEBUG
Log
    "request": {
        "remote_ip": "192.168.0.23",
        "remote_port": "52006",
        "client_ip": "192.168.0.23",
        "proto": "HTTP/2.0",
        "method": "GET",
        "host": "192.168.0.23",
        "uri": "/pwa",
        "headers": {
                "1"
            "Accept-Language": [
                "en-US,en;q=0.9,da;q=0.8"
            "Sec-Gpc": [
                "1"
            "Sec-Ch-Ua": [
                "\"Chromium\";v=\"136\", \"Google Chrome\";v=\"136\", \"Not.A/Brand\";v=\"99\""
            "User-Agent": [
                "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/136.0.0.0 Safari/537.36"
            "Accept": [
                "text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"
            "Sec-Fetch-Site": [
                "none"
            "Sec-Ch-Ua-Mobile": [
                "?0"
            "Sec-Fetch-Dest": [
                "document"
            "Priority": [
                "u=0, i"
            "Sec-Ch-Ua-Platform": [
                "\"Windows\""
            "Sec-Fetch-Mode": [
                "navigate"
            "Sec-Fetch-User": [
                "?1"
            "Accept-Encoding": [
                "gzip, deflate, br, zstd"
        "tls": {
            "resumed": false,
            "version": 772,
            "cipher_suite": 4865,
            "proto": "h2",
            "server_name": ""
    "bytes_read": 0,
    "user_id": "",
    "duration": 0,
    "size": 0,
    "status": 0,
    "resp_headers": {
        "Alt-Svc": [
            "h3=\":443\"; ma=2592000"
        "Server": [
            "Caddy"
You’re requesting /pwa, but configured caddy with /pwa/*, so the last slash must exist per your configuration.
