I am trying to setup Authentik to reverse proxy to Kavita Reader. Kavita Reader has a functionality where if the /login endpoint is hit with the query argument apiKey=USER_API_KEY, then you are automatically logged in. My goal is to have the API key of the user injected as an additional header by Authentik (currently X-Test-Key
), then have Caddy rewrite the URL from /
to login?apiKey=API_KEY
The Authentik header injection part works, but the Caddy rewrite rule keeps seeing the value of the header as empty string. But, in the logs, it appears to be present.
Part 1: https://pastebin.com/stETyYcg
Part 2: https://pastebin.com/PckUQQnX
Docker-compose running on a Synology NAS
docker-compose up -d caddy
With docker-compose:
image: caddy:2
- 80:80
- /volume1/media/docker/caddy/data:/data
- /volume1/media/docker/caddy/config:/config
- /volume1/homes/sean/helios.tailf6f70.ts.net.crt:/tailnet.crt
- /volume1/homes/sean/helios.tailf6f70.ts.net.key:/tailnet.key
- /volume1/homes/sean/swriddle.crt:/swriddle.crt
- /volume1/homes/sean/swriddle.key:/swriddle.key
kavita.swriddle.com {
tls /swriddle.crt /swriddle.key
# Use forward authentication with Authentik to enforce group-based access
forward_auth http://authserver:9000 {
uri /outpost.goauthentik.io/auth/caddy
# Copy headers to pass user info from Authentik to Caddy
copy_headers X-Authentik-Username X-Authentik-Groups X-Authentik-Email X-Authentik-Name X-Authentik-Uid X-Authentik-Jwt X-Authentik-Meta-Jwks X-Authentik-Meta-Outpost X-Authentik-Meta-Provider X-Authentik-Meta-App X-Authentik-Meta-Version X-Test-Key
# Trust the correct IP ranges or IP addresses
trusted_proxies private_ranges
@accessDenied {
not header_regexp X-Authentik-Groups ^Kavita$|^Kavita\||\|Kavita$|\|Kavita\|
respond @accessDenied "Access denied" 403 {
close
reverse_proxy /outpost.goauthentik.io/* http://authserver:9000
@kavitaPath {
path /
output stdout
rewrite @kavitaPath {path}login?apiKey={http.request.header.X-Test-Key}
reverse_proxy http://kavita:5000
auth.swriddle.com {
reverse_proxy http://authserver:9000
Authentik: https://goauthentik.io
Kavita Reader auto-login: Frequently Asked Questions | Kavita Wiki
