Trying to rewrite a HTTP query to a path
    I want to rewrite an URL who contain http query to another URL who replace the query by a path.
    I have a URL like this:
    /main/view/servers.php?server_digest=$1 and I want to rewrite it to /main/view/servers/server_digest. I tried this:
    1 - rewrite /main/view/servers/* /main/view/servers.php?server_digest=$1
    2 - rewrite /main/view/servers/(.) /main/view/servers.php?server_digest=$1
    3 - rewrite /main/view/servers/(.) /main/view/servers.php?server_digest={query}
I have the same problem with others path
  1. Error messages and/or full log output:
mars 23 16:23:24 dedicated-server-05 caddy[1160708]: {"level":"info","ts":1679585004.800531,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
mars 23 16:23:24 dedicated-server-05 caddy[1160708]: {"level":"info","ts":1679585004.8013365,"logger":"tls","msg":"finished cleaning storage units"}
mars 23 17:08:15 dedicated-server-05 systemd[1]: Stopping Caddy...
mars 23 17:08:15 dedicated-server-05 caddy[1160708]: {"level":"info","ts":1679587695.005596,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
mars 23 17:08:15 dedicated-server-05 caddy[1160708]: {"level":"warn","ts":1679587695.0056965,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
mars 23 17:08:15 dedicated-server-05 caddy[1160708]: {"level":"info","ts":1679587695.0058038,"logger":"tls.cache.maintenance","msg":"stopped background certificate maintenance","cache":"0xc0004fd3b0"}
mars 23 17:08:15 dedicated-server-05 caddy[1160708]: {"level":"info","ts":1679587695.0058901,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
mars 23 17:08:15 dedicated-server-05 caddy[1160708]: {"level":"info","ts":1679587695.0058987,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
mars 23 17:08:15 dedicated-server-05 systemd[1]: caddy.service: Succeeded.
mars 23 17:08:15 dedicated-server-05 systemd[1]: Stopped Caddy.
mars 23 17:08:15 dedicated-server-05 systemd[1]: caddy.service: Consumed 21.450s CPU time.
mars 23 17:08:15 dedicated-server-05 systemd[1]: Starting Caddy...
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: caddy.HomeDir=/var/lib/caddy
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: caddy.Version=v2.6.4 h1:2hwYqiRwk1tf3VruhMpLcYTg+11fCdr8S3jhNAdnPy8=
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: runtime.GOOS=linux
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: runtime.GOARCH=amd64
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: runtime.Compiler=gc
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: runtime.NumCPU=4
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: runtime.GOMAXPROCS=4
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: runtime.Version=go1.20
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: os.Getwd=/
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: LANG=fr_FR.UTF-8
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: NOTIFY_SOCKET=/run/systemd/notify
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: HOME=/var/lib/caddy
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: LOGNAME=caddy
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: USER=caddy
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: INVOCATION_ID=aa5207771d544422a3ef36f39b0ce784
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: JOURNAL_STREAM=8:804662657
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.040275,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"warn","ts":1679587695.044272,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.046815,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.0472965,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000446d20"}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.0528343,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.0529838,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.0530102,"logger":"tls","msg":"finished cleaning storage units"}
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.0530236,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
mars 23 17:08:15 dedicated-server-05 systemd[1]: Started Caddy.
mars 23 17:08:15 dedicated-server-05 caddy[1417654]: {"level":"info","ts":1679587695.0542378,"msg":"serving initial configuration"}
(END)
No error appears in the logs.
  1. Caddy version:
  2. How I installed and ran Caddy:
    official installation methods found at Install — Caddy Documentation.
Debian 11 (bullseye) x86_64
systemctl start caddy
:1080 {
    header / Cache-Control "no-cache, no-store, must-revalidate"
    root * /usr/share/nginx/dark-utilities.com
    #tls /etc/nginx/ssl/dark-utilities.com.pem /etc/nginx/ssl/dark-utilities.com.key {
    #    protocols tls1.3
    php_fastcgi unix//run/php/php8.1-fpm.sock
    rewrite / /main.html
    rewrite /referral/* /referral.html?referral=$1
    rewrite /recovery /recovery.php
    rewrite /abuse /abuse.html
    rewrite /privacy /privacy.html
    rewrite /terms /terms.html
    rewrite /main/manager /main/manager.php
    rewrite /main/premium /main/premium.php
    rewrite /main/api-access /main/api-access.php
    rewrite /main/rules /main/rules.php
    rewrite /main/referral /main/referral.php
    rewrite /main/post-exploitation /main/post-exploitation.php
    rewrite /main/tickets /main/tickets.php
    rewrite /main/documentation /main/documentation.php
    rewrite /main/advertisement /main/advertisement.php
    rewrite /main/admin/tickets /main/admin/tickets.php
    rewrite /main/admin/members /main/admin/members.php
    rewrite /main/admin/referral /main/admin/referral.php
    rewrite /main/admin/settings /main/admin/settings.php
    rewrite /main/view/tickets/* /main/view/tickets.php?ticket_uid=$1
    rewrite /api/v1/api-access /api/v1/api-access.php
    rewrite /api/v1/report /api/v1/report.php
    rewrite /api/v1/nodes-status /api/v1/nodes-status.php
    rewrite /api/v1/miners-status /api/v1/miners-status.php
    rewrite /api/v1/builds /api/v1/builds.php
    rewrite /api/v1/science /api/v1/science.php
    rewrite /api/v1/servers/evaluate/* /api/v1/servers-folder/evaluate.php?server_digest=$1
    rewrite /api/v1/servers/give/* /api/v1/servers-folder/give.php?server_digest=$1
    rewrite /api/v1/servers/shell-stdout/* /api/v1/servers-folder/shell-stdout.php?server_digest=$1
    rewrite /api/v1/servers/* /api/v1/servers.php?server_digest=$1
    rewrite /api/v1/servers /api/v1/servers.php
    rewrite /api/v1/webhooks/* /api/v1/webhooks.php?query=$1
    rewrite /api/v1/manager/attacks /api/v1/manager-folder/attacks.php
    rewrite /api/v1/manager /api/v1/manager.php
    rewrite /api/v1/tickets/reply/* /api/v1/tickets-folder/reply.php?ticket_uid=$1
    rewrite /api/v1/tickets/* /api/v1/tickets.php?ticket_uid=$1
    rewrite /api/v1/tickets /api/v1/tickets.php
    rewrite /api/v1/admin/tickets /api/v1/admin/tickets.php
    rewrite /api/v1/admin/members/* /api/v1/admin/members.php?user=$1
    rewrite /api/v1/admin/members /api/v1/admin/members.php
    rewrite /api/v1/admin/referral /api/v1/admin/referral.php
    rewrite /api/v1/users/wallet /api/v1/users-folder/wallet.php
    rewrite /api/v1/users/two-factor /api/v1/users-folder/two-factor.php
    rewrite /api/v1/users/api /api/v1/users-folder/api.php
    rewrite /api/v1/auth/two-factor /api/v1/auth/two-factor.php
    rewrite /api/v1/referral /api/v1/referral.php
    rewrite /api/v1/@me /api/v1/@me.php
    rewrite /api/v1/premium /api/v1/premium.php
    rewrite /api/v1/ssh-auto-link /api/v1/ssh-auto-link.php
    rewrite /api/v1/vector-map /api/v1/vector-map.php
    rewrite /api/v1/notifications /api/v1/notifications.php
    route /auth/login {
        try_files {path} /auth/login.php?{query}
    route /auth/logout {
        try_files {path} /auth/logout.php
    route /auth/two-factor {
        try_files {path} /auth/two-factor.php
    route /main/vendor/* {
        rewrite * /error_files/401.html
        header Content-Type text/html
    handle_errors {
        @404 expression {http.error.status_code} == 404
        @401 expression {http.error.status_code} == 401
        route @401 {
        route @404 {
            rewrite * /error_files/404.html
Simple path matchers don’t support regular expressions. You’re looking for a named matcher using the path_regexp matcher. See the docs:
I believe this should fit what you are looking for.
Not sure what you meant by storing it but this is an example for it by responding with the path and server_digest query
rewrite /main/view/servers.php /main/view/servers/server_digest?{query}
handle /main/view/servers/server_digest {
	respond "Query: {query.server_digest}, Path: {uri}"
Please read the docs. It explains how to use regexp capture groups:
In that case, this should fit your needs, the rewritten path does still have the query string and I’m not sure how to remove it but it should work fine. You can remove the handle directive if needed
rewrite /main/view/servers.php /main/view/servers/server_digest/{query.server_digest}
handle /main/view/servers/server_digest/* {
	respond "Path: {uri}"
