Trying to reverse proxy to my domain with caddy
I'm trying to set up a reverse proxy using Caddy to forward HTTPS requests for tagged.website to Modlishka running on 127.0.0.1:8081. Modlishka is successfully running and configured to proxy to tagged.com, but Caddy is failing to start with a TLS configuration error. The goal is to have tagged.website serve as a phishing proxy for tagged.com.
× caddy.service - Caddy
Loaded: loaded (/usr/lib/systemd/system/caddy.service; enabled; preset: enabled)
Active: failed (Result: exit-code) since Sun 2026-08-09 21:09:02 UTC; 1min 0s ago
Duration: 1d 21h 24min 18.747s
Docs: Welcome — Caddy Documentation
Process: 318373 ExecStart=/usr/bin/caddy run --environ --config /etc/caddy/Caddyfile (code=exited, status=1/FAILURE)
Main PID: 318373 (code=exited, status=1/FAILURE)
Status: "loading new config: loading http app module: provision http: getting tls app: loading tls app module: provision>
CPU: 41ms
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https
echo "deb [signed-by=/usr/share/keyrings/caddy-stable-archive-keyring.gpg] https://dl.cloudsmith.io/public/caddy/stable/deb/debian any-version main" | sudo tee /etc/apt/sources.list.d/caddy-stable.list
# Update and install Caddy
. System environment:
- OS: Linux (CloudVPS)
- Architecture: amd64
- Running via systemd
PASTE OVER THIS HERE IN THIS CODE BLOCK.
Please ensure it looks nice.
    auto_https off
tagged.website:443 {
    reverse_proxy 127.0.0.1:8081
    tls /etc/letsencrypt/live/tagged.website/fullchain.pem /etc/letsencrypt/live/tagged.website/privkey.pem
Type here
This is a mismatch. v2.6.2 is extremely old and unsupported. I don’t think you actually ran those install steps, if you did you would have 2.11.4
v2.11.4 is my current version
This is what I ran
curl -1sLf ‘https://dl.cloudsmith.io/public/caddy/stable/gpg.key’ | sudo gpg --dearmor -o /usr/share/keyrings/caddy-stable-archive-keyring.gpg
echo “deb [signed-by=/usr/share/keyrings/caddy-stable-archive-keyring.gpg] https://dl.cloudsmith.io/public/caddy/stable/deb/debian any-version main” | sudo tee /etc/apt/sources.list.d/caddy-stable.list
sudo apt update
sudo apt install caddy
The issue I’m encountering now is that when I click on my domain, it redirects to the original website instead of serving the proxied version. It appears that the domain is not being proxied as intended.
root@CloudVPS117483:~/Modlishka# curl -I http://127.0.0.1:8081
HTTP/1.1 302 Found
Content-Type: text/html; charset=utf-8
Date: Mon, 10 Aug 2026 23:33:59 GMT
root@CloudVPS117483:~/Modlishka# curl -I https://tagged.website
HTTP/2 200
alt-svc: h3=“:443”; ma=2592000
date: Mon, 10 Aug 2026 23:34:14 GMT
via: 1.1 Caddy
I think I need to start here
