I’m not launching my new business just yet, only a small page for a small market research that we are conducting. The page will be located at foodfix.my/survey.
For now, I haven’t had the time to create a homepage, so I’m looking to reverse proxy my main domain to our instagram page, which i’ve created a page rule via Cloudflare.
On my web browser:
"This page isn't working at the moment
foodfix.my redirected you too many times."
Tried to use a not directive (?) within a named matcher for the reverse proxy directive but it shows the error above when trying to access both foodfix.my and foodfix.my/survey.
Hmm, I don’t think you should reverse_proxy to there, since it just bounces you to instagram. You should probably just use a redir to instagram for now, from Caddy itself.
@excl not path /survey*
redir @excl https://www.instagram.com/foodfixmy/
And then you probably want to use handle_path to serve the static site:
The handle_path directive takes care of stripping the prefix from the path, which matters because Caddy takes the value of root and appends the path to it when looking for files on disk. So if you didn’t strip it, you’d be looking for files in /var/www/html/survey/survey.
Note the * on the path matchers I used, this is important because path matching is exact in Caddy v2, so /survey would only match exactly /survey and nothing below that.
Also, you put your Cloudflare API key in your post so I think you’ll need to regenerate that… it should stay secret.
My goodness! Thanks for the heads up, i’ve regenerated my cloudflare API token and redacted the previous one.
Thanks for your pointers! Only have one page at /survey so I thought that wouldn’t be an issue, but i’ve added it in anyway. Here’s my modified my Caddyfile:
Avoids needing to use that not path matcher. handle and handle_path blocks are mutually exclusive from eachother, and they’re sorted by their path matchers, so this should do the trick.
I’ve just tried that block of code in my Caddyfile - the redirect for my domain now works, but even the /survey path is redirecting to instagram now. In fact, any path that I type at the end of the URL also seem to be redirecting to the instagram page.
The 308 redirect is actually triggered by file_server. The reason is that /survey is actually a directory on disk, so it decides to trigger a redirect to canonicalize the path to /survey/.
This usually works just fine, but since we’re inside of handle_path, the path was stripped so it actually redirects to / instead of /survey/.
So the fix is to add this to your config (you can put it just before the handle_path line, but where you put it doesn’t matter, because the Caddyfile adapter will sort directives):
Also note that 308 redirects are cached by browsers, so you’ll probably need to clear your browser cache for your site for the change to take effect.
Basically, it’s ambiguous to a browser whether you’re looking at a directory or a file, if there’s no trailing / in the URL path. The way browsers calculate relative URLs (like in your <a> tags) is to append the link to the current path, if there’s a trailing slash, but if not then it’ll remove the last path segment to load a file that’s a sibling of the current one.
For example say you’re on /foo/ and you have <a href="bar"> on that page. That’ll link to /foo/bar.
If you’re on /foo and you have <a href="bar">, then the browser will link to /bar.
So Caddy’s file server, since it knows that /survey is actually a directory on disk, will want to redirect /survey to /survey/ typically, so that browsers don’t link to the wrong place. In other words we want to “canonicalize” the URL. Canonicalizing can also be thought of as disambiguate between duplicate page content by triggering redirects so that you land on the “right one”. Another example of that is redirecting www. to a non-www domain, or vice versa, so that people always land on the one you actually want them to use.
So the trouble is since we use handle_path, for a URL of /survey, Caddy will remove /survey from the path before file_server sees it, so it just sees an empty string as the path. And since it will canonicalize the URL, it will then trigger a 308 redirect to path + / (which is just / because the path is empty). And that’s what you saw in your curl -v output.
