Trying to mimic apache alias. Running into rewrite issues
This is a long shot. I’ve been stuck on this for 8 hours or so and I can’t seem to figure out the issue. I have an angular frontend which i want to connect to my api-platform backend. I have a LAMP stack that is working wonderfully, however, I want to play around with vulcan so i have been exploring caddy+frankenphp.
My LAMP stack is setup like so:
angular is at site.[com] (/app/angular/public)
api-platform is at site.[com]/api. ( alias to /app/api/public)
This is what my vhost looks like and it works fine.
	ServerName site.com
	DocumentRoot "/app/angular/public"
	<Directory /app/angular/public>
		Options Indexes ExecCGI SymLinksIfOwnerMatch FollowSymlinks MultiViews
    	AllowOverride All
    	Require all granted
	</Directory>
	Alias "/api" "/app/api/public"
  	<Directory "/app/api/public">
	    Options Indexes FollowSymlinks MultiViews
    	AllowOverride All
    	Require all granted
  	</Directory>
  ## Logging
</VirtualHost>
When I try to convert this to a CaddyFile equivalent I’m running into an issue with my api side of things. My CaddyFile below serves up the angular site just fine. When I try to access site.com/api I’m getting a symfony error No route found for “GET site.com/api/”, which is strange because on my LAMP stack this works, I’m thinking this is a rewrite issue and I can’t seem to figure out the problem.
//CaddyFile
site.com {
    # Serve Angular frontend from this path
    tls /certs/certificate.crt /certs/private.key
    //I also tried handle_path, same results.
    handle /api/* {
        root * /app/api/public
        try_files {path} /index.php
        php_server
        root * /app/angular/public
        try_files {path} /index.html
If I modify the caddy file to the following, my API serves up fine at site.[com].
site.com {
        php_server
Anyone have any ideas as to whats causing my problem?
Try adding redir to your configuration:
site.com {
    redir /api /api/
    # your other configuration settings
Thanks for the reply. I tried the redir and it didn’t work unfortunately.
I did, however, make a bit of progress. The only way I could get it working (without modifying my index.php) was to setup a reverse proxy.
site.com {
    root * /app/angular/dist/site.com/browser
    # Now proxy all /api/* requests to the backend
    handle_path /api/* {
        reverse_proxy http://127.0.0.1:8081 {
            header_up X-Real-IP {http.request.remote}
            header_up X-Forwarded-For {http.request.remote}
            header_up X-Forwarded-Proto {http.request.scheme}
            header_up X-Forwarded-Prefix /api
    	@notFileOrDir {
    		not {
    			file {
    				try_files {path}
    	rewrite @notFileOrDir /index.html
:8081 {
    vulcain
        php_server
