Trying to mask url / make it shorter
Trying to mask url, im using caddy as reverse proxy for oracle apex app.
So this works normaly like this and i can access my app with url like example.com/ords/r/ws/app/login
Thing is this part is always gonna be same example.com/ords/r/ws/app/ but part after like login or home is dynamic url and im trying to mask url or make it shorter like example.com/login to lead to example.com/ords/r/ws/app/login in background.
Tried to reverse proxy like
reverse_proxy 127.0.0.1:8080/ords/r/ws/app/ but the app itself doesn’t work like that, also tried using strip_prefix but i feel thats wrong to use.
So im out of ideas what i can try.
Not sure what’s proper syntax for this so im gonna skip
Running binary from github
OS: Oracle Linux 9.6
ARCH: amd64
Run caddy as systemd service
systemctl start caddy
example.com {
You probably want one of these:
For example:
	reverse_proxy 127.0.0.1:8080 {
		rewrite /ords/r/ws/app{uri}
:8080 {
	respond "Backend will see: {uri}"
$ curl http://localhost
Backend will see: /ords/r/ws/app/
$ curl http://localhost/login
Backend will see: /ords/r/ws/app/login
Adjust to your needs.
This indeed does what i asked for now got different issue (could be on ords end not exactly caddy) but location is returning what i need so marked it as answer, thank you!
