Caddy v2.2.1
Run it as a service with caddy.service and systemctl on localhost
Ubuntu 20.04 (LTS) x64, systemctl
I’m trying to just get a “hello world” to show up.
curl http://localhost
curl https://localhost
caddy.service
GNU nano 4.8 /etc/systemd/system/caddy.service
# caddy.service
# for your installation.
localhost
respond "Hello, world!"
https shows error. http shows nothing, just a return
curl https://localhost shows:
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: https://curl.haxx.se/docs/sslcerts.html
how to fix it, please visit the web page mentioned above.
and curl http://localhost show nothing
Tried reloading after config changes: sudo systemctl reload caddy
Following tutorials here: Install — Caddy Documentation and Caddyfile Quick-start — Caddy Documentation
