Trying to geo block part of website
I’m trying to geoblock the landing page of my website outside of my country and leave the path /shares/* open to all countries.
For that purpose I’m using caddy-maxmind-geolocation module. I’m able to geoblock but everything is geoblocked even with the configuration I currently have.
    dynamic_dns {
            provider cloudflare {$CLOUDFLARE_API_TOKEN}
            domains {
                    dotflow.cc transfer
    acme_dns cloudflare {$CLOUDFLARE_API_TOKEN}
    crowdsec {
        api_url http://crowdsec:8080
        api_key {$CROWDSEC_API_KEY}
        ticker_interval 15s
(logging) {
                        roll_size 10MiB
                        roll_keep 1
example.com {
    import logging
    route {
        crowdsec
    @mygeofilter {
      maxmind_geolocation {
        db_path "/usr/share/GeoIP/GeoLite2-Country.mmdb"
        allow_countries PT
    handle /shares/* {
        reverse_proxy 192.168.1.16:9998
        reverse_proxy @mygeofilter 192.168.1.16:9998
I don’t have the MaxMind module installed, so this is just a guess rather than me knowing exactly what I’m doing. But can you try the following?
example.com {
    import logging
    route {
        crowdsec
    handle /shares/* {
           allow_countries PT
This is what I get and caddy won’t start:
INF ts=1741728082.7687137 msg=using config from file file=/etc/caddy/Caddyfile
Error: adapting config using caddyfile: parsing caddyfile tokens for 'handle': unrecognized directive: maxmind_geolocation - are you sure your Caddyfile structure (nesting and braces) is correct?, at /etc/caddy/Caddyfile:62
Edit:
Sorry for the confusion but it was actually working as I had before in my initial message, but I misunderstood how the “wildcard” * works in there apparently.
I thought
/shares/*
would include all subpaths under /shares, so if I had /shares/whatever/ it’d still fall under the allow all countries. But what was happening is that only /shares/ was being allowed to all countries.
Now the question is, how does it work and how can I have it be all subpaths under /share/ ?
I’ve tried so many things but I can’t get it to work, only
example.com/shares
is unblocked, everything else is blocked, even
example.com/shares/something
is also blocked.
From my understanding if you leave path empty after “handle” it defaults to * which means it’ll handle the whole domain and I think that’s what is happening to everything other than
/shares
Is there a way to handle just the root?
path matching is exact unless you use astrisk (wildcard). We typically recommend doing something like this to ensure consistency when handling sensitive edges:
redir /prefix /prefix/
handle /prefix/* # etc...
I’ve tried using / to handle root host access but it won’t work for a reason I don’t understand.
If I do
        handle /shares* {
        handle / {
everything except for /shares/ gets blocked everywhere, including my own country, /shares/whatever/ can’t be accessed anywhere either.
Only /shares/ becomes accessible, everything else gets blocked in all countries including mine.
This is very confusing to me.
Edit:
Also, if I do
        handle /shares* {
then everything except for /shares/ gets blocked outside of my country, the geoip filter works and everything is accessible in my country. Problem is I have links that are generated with /share/whatever that I’d need being accessed all over the world and with either of these setups they’re not.
What I’m trying to achieve is:
block example.com/ everywhere except for my country
and:
allow example.com/shares/* in the whole world
It is solved, I was missing some paths for the webserver to make it function, that’s why it was not showing when I added the / to it.
The paths were working as intended, it was just me being a noob. :head_shaking_vertically:
This made it work:
example.com {
    import logging
    route {
        crowdsec
    @allowpt {
        allow_countries PT
    handle / {
        reverse_proxy @allowpt 192.168.1.16:9998
    handle /build* {
    handle /api* {
    handle /shares* {
    handle /get-logo* {
Sorry for bothering you guys with my lack of experience… and thanks for the help. :+1:
Thank you for posting the final solution!
