Trying to convert Taiga nginx configuration
Hello there ! :slight_smile:
I’m currently installing taiga on one of my servers and I’m quite stuck right now with the configuration.
The configuration looks like this in nginx :
server {
    location / {
        root /home/taiga/taiga-front-dist/dist/;
        try_files $uri $uri/ /index.html;
    location /api {
    location /admin {
    location /static {
        alias /home/taiga/taiga-back/static;
    location /media {
        alias /home/taiga/taiga-back/media;
Now for both proxies (/admin and /api), I know how to do that, and it’s pretty easy using caddy. What troubles me is the multiple location. How can I achieve that using Caddy ? The full configuration file can be found here. I guess that question was already asked a lot of times but I can’t seem to find an explanation :confused:
Could anyone help me ? :slight_smile:
Thanks a lot in advance
Ok, fixed that using two additional subdomains (one for media and one for static)
The configuration file looks like this :
taiga.example.com {
	proxy /api 127.0.0.1:8001 {
                header_upstream Host {host}
		        header_upstream X-Scheme {scheme}
	proxy /admin 127.0.0.1:8001 {
static.taiga.example.com {
	root /home/taiga/taiga-back/static/
media.taiga.example.com {
	root /home/taiga/taiga-back/media/
