Trying to connect to the admin API on host machine from within a Docker container
I’m trying to send a request from within a Docker container to my Caddy admin api on the host machine on my Ubuntu server. If I just do curl -v http://172.17.0.1 it connects just fine through port 80, but when doing curl -v http://172.17.0.1:2019 it hangs on Trying 172.17.0.1:2019… forever and the connection doesn’t seem to go through, but it also is not refused either. I have added the port to my firewall with ufw allow from 172.17.0.1 proto tcp to any port 2019, also ran iptables -I DOCKER-USER -i docker0 -p tcp --dport 2019 -j ACCEPT and nft add rule ip filter DOCKER-USER iifname "docker0" tcp dport 2019 accept
Running lsof -iTCP:80 -sTCP:LISTEN:
COMMAND    PID  USER   FD   TYPE  DEVICE SIZE/OFF NODE NAME
caddy   242000 caddy   22u  IPv6 2048423      0t0  TCP *:http (LISTEN)
Running lsof -iTCP:2019 -sTCP:LISTEN:
caddy   242000 caddy   15u  IPv6 2048411      0t0  TCP *:2020 (LISTEN)
I thought this was due to the Type being IPv6 but that seems to be the case on port 80 as well, so I don’t know. I have tried multiple configurations and nothing seems to work so I’m coming here for some guidance.
Trying 172.17.0.1:2019...
caddy --version
I have installed Caddy via xcaddy (v0.4.5_linux_amd64) with the following command:
xcaddy build --with github.com/darkweak/souin/plugins/caddy --with github.com/ueffel/caddy-brotli --with github.com/darkweak/storages/redis/caddy
Ubuntu 24.04.3 LTS (GNU/Linux 6.8.0-87-generic x86_64)
Running two Docker containers inside, one for WordPress and the other for the React app.
systemctl restart caddy
  remix:
    image: my-image
      - "3060:3000"
      - COOKIE_DOMAIN=.mydomain.com
      - WP_URI=https://mydomain.com/graphql
    restart: always
  wordpress:
    image: wordpress:latest
    extra_hosts:
      - "host.docker.internal:host-gateway"
      - ./wp-content:/var/www/html/wp-content
      - ./uploads.ini:/usr/local/etc/php/conf.d/uploads.ini
      WORDPRESS_DB_HOST: "****"
      WORDPRESS_DB_PORT: ""****"
      WORDPRESS_DB_USER: ""****"
      WORDPRESS_DB_PASSWORD: "****"
      WORDPRESS_DB_NAME: "****"
  carney-network:
    driver: bridge
    driver_opts:
      com.docker.network.driver.mtu: 1400
	email dev@mydomain.com
	admin 0.0.0.0:2019 {
		origins http://127.0.0.1:2019 http://localhost:2019 http://172.17.0.0/16 http://172.18.0.0/16
	# Souin Cache Configuration
	order cache before rewrite
	cache {
		redis {
			url localhost:6379
		ttl 1h
		stale 1h
		key {
			disable_body
			disable_host
			disable_scheme
			disable_vary
			hide
		log_level DEBUG
		allowed_http_verbs GET HEAD POST
		api {
			souin
admin.mydomain.com {
	request_body {
		max_size 5120MB
	# Redirect root to /wp-admin
	@root path /
	redir @root /wp-admin 301
	# Proxy all requests to WordPress
	reverse_proxy localhost:8080
mydomain.com {
	encode br gzip
	@static_assets {
		path_regexp static ^/(assets|lottie)/.*\.(js|css|json)$
	handle @static_assets {
		root * /var/www/static-assets
		# Add caching headers
		header Cache-Control "public, max-age=31536000"
		header Vary "Accept-Encoding"
		file_server {
			precompressed br gzip
	handle /daily-blog* {
		cache {
			ttl 24h
			stale 48h
		reverse_proxy localhost:3060
		cache {
			ttl 7d
			stale 14d
Finally found a solution after 2 days fighting this issue: ufw allow from 172.18.0.1/16 to any port 2019 proto tcp. It turned out I was adding the IP address of the wrong Docker container to it. Gonna leave this here in case someone in the future faces the same issue.
