1. The problem Iβm having:
I am trying to add a url with to hit server IP with the reverse-proxy command,
sudo caddy reverse-proxy --from unifi.site.org --to x.x.x.x:8443
2025/05/16 12:12:58.723 WARN admin admin endpoint disabled
2025/05/16 12:12:58.723 INFO http.auto_https server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "proxy", "https_port": 443}
2025/05/16 12:12:58.723 INFO http.auto_https enabling automatic HTTP->HTTPS redirects {"server_name": "proxy"}
2025/05/16 12:12:58.723 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc0002ce880"}
2025/05/16 12:12:58.724 INFO http enabling HTTP/3 listener {"addr": ":443"}
2025/05/16 12:12:58.724 INFO http.log server running {"name": "proxy", "protocols": ["h1", "h2", "h3"]}
Error: loading new config: http app module: start: listening on :80: listen tcp :80: bind: address already in use
β
caddy version is v2.10.0
β
β
curl -1sLf βhttps://dl.cloudsmith.io/public/caddy/stable/gpg.keyβ | sudo gpg --dearmor -o /usr/share/keyrings/caddy-stable-archive-keyring.gpg
curl -1sLf βhttps://dl.cloudsmith.io/public/caddy/stable/debian.deb.txtβ | sudo tee /etc/apt/sources.list.d/caddy-stable.list
sudo apt update
sudo apt install caddy
β
β
disable redirects
auto_https disable_redirects
unifi reverse proxy
unifi.site.org {
reverse_proxy x.x.x.x:8443
β
