Been struggling to figure out how to deal with the v2.5 changes to reverse_proxy while using Cloudflare as a cloud proxy service and figured I’d share what’s working for me in hopes that others may find it useful.
in my Caddyfile, i make use of import directive to reference a file:
i run Caddy in a docker container, so i have the /authdb/ volume mounted to the container. on the host itself, i set a cron job to run this script every 30 minutes:
#!/bin/bash
CLOUDFLARE_IPSV4="https://www.cloudflare.com/ips-v4"
FILE_IPV4="/authdb/cloudflare-proxies"
if [ -f "$FILE_IPV4" ] ; then
rm "$FILE_IPV4"
fi
if [ -f /usr/bin/curl ]; then
HTTP_STATUS=$(curl -sw '%{http_code}' -o $FILE_IPV4 $CLOUDFLARE_IPSV4)
if [ "$HTTP_STATUS" -ne 200 ]; then
echo "FAILED. Reason: unable to download IPv4 list [Status code: $HTTP_STATUS]"
exit 1
fi
else
echo "FAILED. Reason: curl wasn't found on this system."
exit 1
fi
sed -i ':a;N;$!ba;s/\n/ /g' $FILE_IPV4
sed -i '1s/^/trusted_proxies /' $FILE_IPV4
exit 0
Now, whenever I re-build my Caddy container, the “cloudflare-proxies” file is mounted with the container and the host updates that file every half hour.
Please note that this alone is incomplete, because Cloudflare does not sanitize the X-Forwarded-For header by default, so even with this, you’re potentially vulnerable to remote IP spoofing. So you must configure Cloudflare to remove the X-Forwarded-For header, then write the header again with the source IP address, to make sure it doesn’t have untrusted values.
There’s instructions here in Authelia’s docs (not yet live on their site, so the source on Github will have to do for now):
Hi! Sorry to hijack this thread but is there any alternative to performing this import every time the reverse_proxy directive is used. It could also be done with a snippet and an arg but I wanted to ask if you know of any other way to have some sort of global trusted_proxies now that realip doesnt seem to work.
being new to caddy the response didn’t quite have enough detail for me to get it working.
So for other newbies, I had to place it in the global section at the top of my Caddyfile.
I also had to to a custom build of caddy to include the trusted proxies cloudflare module. I’ve included my docker file as well.
# Email for Let's Encrypt notifications
email {$EMAIL}
# ACME CA URL allows us to flip between production and staging.
# we default to staging.
acme_ca ${ACME_URL:https://acme-staging-v02.api.letsencrypt.org/directory}
output file /var/log/caddy/all.log
# trigger the cloudflare ip module that periodically fetches
# the list of valid cloud flare proxy IP addresses.
servers {
trusted_proxies cloudflare {
interval 12h
timeout 15s
# we build our own caddy file as we need the cloudflare module.
FROM caddy:2.9.1-builder AS builder
# https://caddyserver.com/docs/modules/dns.providers.cloudflare
RUN xcaddy build \
--with github.com/WeidiDeng/caddy-cloudflare-ip
FROM caddy:2.9.1
COPY config/caddy /etc/caddy
# CMD ["tail", "-f", "/dev/null"]
CMD ["caddy", "run", "--config", "/etc/caddy/Caddyfile", "--adapter", "caddyfile"]
