Trusted_proxies isn't working globally with Cloudflare IP ranges
I’m trying to get real IPs when I’m behind Cloudflare, and to do that, I need to set trusted_proxies. So I set it globally, but I just get a weird error.
Error: adapting config using caddyfile: parsing caddyfile tokens for 'servers': /etc/caddy/Caddyfile:4 - Error during parsing: getting module named 'http.ip_sources.173.245.48.0/20': module not registered: http.ip_sources.173.245.48.0/20
I installed Caddy through Cloudsmith Debian repos, and then I installed GitHub - caddy-dns/cloudflare: Caddy module: dns.providers.cloudflare through caddy add-package github.com/caddy-dns/cloudflare.
Debian 11 Bullseye, running on amd64. No Docker.
caddy reload --config /etc/caddy/Caddyfile
        auto_https disable_redirects
        servers {
                trusted_proxies 173.245.48.0/20 103.21.244.0/22 103.22.200.0/22 103.31.4.0/22 141.101.64.0/18 108.162.192.0/18 190.93.240.0/20 188.114.96.0/20 197.234.240.0/22 198.41.128.0/17 162.158.0.0/15 104.16.0.0/13 104.24.0.0/14 172.64.0.0/13 131.0.72.0/22
#       order listencaddy before respond
(common) {
        tls hi@odyssey346.dev
        @no-ua header !User-Agent
        handle @no-ua {
                respond "Set a user agent" 403
        handle_errors {
                respond "It's dead. {err.status_text}"
import sites/*
The correct syntax is
trusted_proxies static 173.245.48.0/20 #[snip]
That’s because trusted_proxies implements a system that allows plugins (in this case the built-in http.ip_sources.static plugin) to provide the IP prefixes to trust, and it needs to know which one to use.
I mention this because there’s a better plugin for your exact situation: this module allows you to write
trusted_proxies cloudflare
and get the Cloudflare IPs automatically, and it will even auto-update them for you.
You can get a version of Caddy with that plugin from the download page, just search for “cloudflare-ip”. (or you can compile it in yourself, if you prefer)
By the way, you may also want to configure Cloudflare to delete X-Forwarded-For headers because they are easy to spoof by default.
