I currently having Caddy running in its own container hosted in our instance of OpenShift. It has a OpenShift route in front of it and then the whole cluster has an Azure WAF. I’m really struggling to get the X-Forwarded-For headers to work, even with trusted proxies set.
I’m monitoring the Caddy container logs and I can see the client IP address I want in the X-Forwarded-For headers, I just can’t seem to convince Caddy that the request is coming through trusted proxies. I’m sure it’s a me issue but can’t see any similar issues on the site!
"level": "debug",
"ts": 1710993658.8185718,
"msg": "upstream roundtrip",
"upstream": "vigilant-server:3000",
"duration": 0.008568237,
"request": {
"remote_ip": "172.19.4.5",
"remote_port": "49426",
"client_ip": "172.19.4.5",
"proto": "HTTP/1.1",
"method": "POST",
"host": "vigilant",
"uri": "/api/auth/refresh",
"headers": {
"X-Forwarded-Host": [
"vigilant"
"Content-Length": [
"0"
"Accept-Encoding": [
"gzip, deflate, br"
"X-Forwarded-Port": [
"443"
"X-Appgw-Trace-Id": [
"6187e389e315137af17f17481f4b325c"
"Sec-Fetch-Site": [
"same-origin"
"Sec-Fetch-Dest": [
"empty"
"Sec-Fetch-Mode": [
"cors"
"User-Agent": [
"Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/17.1.2 Safari/605.1.15"
"X-Original-Host": [
"vigilant"
"Accept": [
"Accept-Language": [
"en-GB,en;q=0.9"
"X-Forwarded-For": [
"37.60.X.Y:64393, 172.19.4.5"
"X-Original-Url": [
"/api/auth/refresh"
"Content-Type": [
"application/json; charset=UTF-8"
"Referer": [
"https://vigilant/?redirect=/profile"
"Origin": [
"https://vigilant"
"X-Forwarded-Proto": [
"https"
"tls": {
"resumed": false,
"version": 771,
"cipher_suite": 49199,
"proto": "",
"server_name": "vigilant"
"headers": {
"Vary": [
"Origin, Accept-Encoding"
"Etag": [
"W/\"45-r8VsLb3uGNauMtcyJtf8PznZRtg\""
"Keep-Alive": [
"timeout=5"
"X-Powered-By": [
"Express"
"Access-Control-Allow-Credentials": [
"true"
"Content-Type": [
"application/json; charset=utf-8"
"Content-Length": [
"69"
"Date": [
"Thu, 21 Mar 2024 04:00:58 GMT"
"Connection": [
"keep-alive"
"status": 403
As you can see the X-Forwarded-For header has the IP address I want but it’s not been moved over to the client_ip. It’s worth saying that the OpenShift route has TLS passthrough on.
I am running the Alpine version of Caddy in your prebuilt Docker image on a Kubernetes cluster.
FROM docker.io/caddy:2.7-alpine
COPY waf/Caddyfile /etc/caddy/Caddyfile
USER 0
RUN adduser -HD -u 1001 -g caddy caddy
RUN chown -R caddy:caddy /usr/bin/caddy /etc/caddy
HEALTHCHECK CMD curl --fail http://localhost:3000/ || exit 1
USER caddy
EXPOSE 3000
CMD ["caddy", "run", "--config", "/etc/caddy/Caddyfile", "--adapter", "caddyfile"]```
c. My complete Caddy config:
http_port 3001
https_port 3000
servers {
trusted_proxies static private_ranges
(good) {
:3001 {
log
reverse_proxy http://vigilant-client:3000
:3000 {
tls /etc/caddy/certs/tls.crt /etc/caddy/certs/tls.key
header +X-Frame-Options DENY
header ?cache-control max-age=3600
header +X-Content-Type-Options nosniff
header +Strict-Transport-Security "max-age=31536000; includeSubDomains"
header -X-Powered-By
header +Content-Security-Policy "default-src 'none'; script-src 'self' 'unsafe-inline'; manifest-src 'self';connect-src 'self'; img-src 'self'; style-src 'self' 'unsafe-inline';base-uri 'self';form-action 'self'; font-src 'self';"
#header +X-Content-Security-Policy default-src 'self'
@internalapi {
import good
path /api/*
@internalui {
import good
path *
output stdout
handle @internalapi {
reverse_proxy https://vigilant-server:3000 {
trusted_proxies private_ranges
tls
tls_insecure_skip_verify
handle @internalui {
respond 403 {
close
This has had me stumped for about four weeks now so any help would be much appreciated!
