I am trying to let Caddy to listen on a unix socket file, and use cloudflared to expose the socket to internet. But I can’t find any documentation describing how to let Caddy “trust” connection from unix socket (like from network port as trusted_proxies
I am using this echo server to inspect the request being sent to upstream, caddy is listening on /run/container-sockets/caddy/caddy.socket
and proxies /echo
to the echo server.
1月 20 19:06:56 epyc-server podman[2852822]: 2024-01-20 19:06:56.297418551 +0800 CST m=+0.057713766 image pull 4437922cacc5203f315d4e8104019a728795aa8be87f155bca9a03d9fe85c670 quay.io/karuboniru/caddy-cloudflare:latest
1月 20 19:06:56 epyc-server podman[2852822]: 2024-01-20 19:06:56.504779651 +0800 CST m=+0.265074856 container create bc2269819990dbb4795f06776141439de4df25af8c46dc06eeb4a06f15ca6965 (image=quay.io/karuboniru/caddy-cloudflare:latest, name=systemd-caddy, org.opencontainers.image.url=https://caddyserver.com, org.opencontainers.image.title=Caddy, io.containers.autoupdate=registry, org.opencontainers.image.description=a powerful, enterprise-ready, open source web server with automatic HTTPS written in Go, org.opencontainers.image.version=v2.7.6, org.opencontainers.image.documentation=https://caddyserver.com/docs, org.opencontainers.image.source=https://github.com/caddyserver/caddy-docker, org.opencontainers.image.licenses=Apache-2.0, io.buildah.version=1.33.2, PODMAN_SYSTEMD_UNIT=caddy.service, org.opencontainers.image.vendor=Light Code Labs)
1月 20 19:06:57 epyc-server podman[2852822]: 2024-01-20 19:06:57.078085741 +0800 CST m=+0.838380976 container init bc2269819990dbb4795f06776141439de4df25af8c46dc06eeb4a06f15ca6965 (image=quay.io/karuboniru/caddy-cloudflare:latest, name=systemd-caddy, org.opencontainers.image.description=a powerful, enterprise-ready, open source web server with automatic HTTPS written in Go, org.opencontainers.image.licenses=Apache-2.0, org.opencontainers.image.title=Caddy, io.buildah.version=1.33.2, org.opencontainers.image.url=https://caddyserver.com, io.containers.autoupdate=registry, org.opencontainers.image.version=v2.7.6, PODMAN_SYSTEMD_UNIT=caddy.service, org.opencontainers.image.vendor=Light Code Labs, org.opencontainers.image.documentation=https://caddyserver.com/docs, org.opencontainers.image.source=https://github.com/caddyserver/caddy-docker)
1月 20 19:06:57 epyc-server podman[2852822]: 2024-01-20 19:06:57.083795188 +0800 CST m=+0.844090403 container start bc2269819990dbb4795f06776141439de4df25af8c46dc06eeb4a06f15ca6965 (image=quay.io/karuboniru/caddy-cloudflare:latest, name=systemd-caddy, org.opencontainers.image.version=v2.7.6, PODMAN_SYSTEMD_UNIT=caddy.service, io.containers.autoupdate=registry, org.opencontainers.image.source=https://github.com/caddyserver/caddy-docker, org.opencontainers.image.vendor=Light Code Labs, org.opencontainers.image.description=a powerful, enterprise-ready, open source web server with automatic HTTPS written in Go, org.opencontainers.image.documentation=https://caddyserver.com/docs, io.buildah.version=1.33.2, org.opencontainers.image.licenses=Apache-2.0, org.opencontainers.image.url=https://caddyserver.com, org.opencontainers.image.title=Caddy)
1月 20 19:06:57 epyc-server systemd[1]: Started caddy.service - Caddy.
1月 20 19:06:57 epyc-server caddy[2852822]: bc2269819990dbb4795f06776141439de4df25af8c46dc06eeb4a06f15ca6965
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"info","ts":1705748820.2191367,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"warn","ts":1705748820.2263498,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"info","ts":1705748820.2348022,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"info","ts":1705748820.2351968,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000484180"}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"info","ts":1705748820.235819,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"info","ts":1705748820.2358527,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"info","ts":1705748820.243015,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"info","ts":1705748820.2439492,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"info","ts":1705748820.2442906,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"info","ts":1705748820.244374,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"info","ts":1705748820.2443867,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["*.niconi.org"]}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"info","ts":1705748820.247251,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"info","ts":1705748820.247272,"msg":"serving initial configuration"}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"warn","ts":1705748820.2475991,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"77f6d13f-5223-435e-a920-90d4c96246c6","try_again":1705835220.2475965,"try_again_in":86399.999999179}
1月 20 19:07:00 epyc-server systemd-caddy[2852943]: {"level":"info","ts":1705748820.2477596,"logger":"tls","msg":"finished cleaning storage units"}
$ curl --unix-socket /run/container-sockets/caddy/caddy.socket 1.niconi.org/echo/ -H "x-forwarded-for: 1.2.3.4"
"path": "/",
"headers": {
"host": "1.niconi.org",
"user-agent": "curl/8.2.1",
"accept": "*/*",
"accept-encoding": "gzip"
"method": "GET",
"body": "",
"fresh": false,
"hostname": "1.niconi.org",
"ip": "::ffff:10.88.0.225",
"ips": [],
"protocol": "http",
"query": {},
"subdomains": [
"1"
"xhr": false,
"os": {
"hostname": "fbac3204243e"
"connection": {}
# The echo server can handle x-forwarded-for
$ curl 10.88.0.224:8080 -H "x-forwarded-for: 1.2.3.4"
"path": "/",
"headers": {
"host": "10.88.0.224:8080",
"accept": "*/*",
"x-forwarded-for": "1.2.3.4"
"method": "GET",
"body": "",
"fresh": false,
"hostname": "10.88.0.224",
"ip": "1.2.3.4",
"ips": [
"1.2.3.4"
"protocol": "http",
"query": {},
"subdomains": [],
"xhr": false,
"os": {
"connection": {}
Docker image built with
FROM docker.io/library/caddy:builder AS builder
RUN xcaddy build \
FROM docker.io/library/caddy:latest
Running using podman with quadlet, in a selinux confined container. With ports exposed and some unix sockets mounted.
- Fedora release 39 (Thirty Nine)
- podman version 4.8.3
See the container configuration below
Podman quatlet configuration file
After=network-online.target
Wants=network-online.target
[Container]
Image=quay.io/karuboniru/caddy-cloudflare:latest
Secret=Caddyfile,target=/etc/caddy/Caddyfile
Volume=CaddyData:/data:Z,U
Volume=CaddyConfig:/config:Z,U
Volume=/run/container-sockets:/run/container-sockets:idmap
Volume=/run/container-sockets/caddy:/run/container-sockets/caddy:idmap,z
Volume=/media/storage:/mnt/share/storage:ro
SecurityLabelType=container_caddy.process
DropCapability=ALL
AddCapability=CAP_NET_BIND_SERVICE
NoNewPrivileges=true
ReadOnly=true
RunInit=true
PublishPort=80:80/tcp
PublishPort=443:443/tcp
PublishPort=443:443/udp
AutoUpdate=registry
Restart=on-failure
ExecStartPre=mkdir -p /run/container-sockets/caddy
ExecStopPost=rm -rf /run/container-sockets/caddy
&(site) {
handle_path /qbt/* {
reverse_proxy http://systemd-qbittorrent.dns.podman:8080 {
header_down Set-Cookie "path=/" "path=/qbt/ ; SameSite=Strict; Secure"
handle_path /qbtee/* {
reverse_proxy http://systemd-qbittorrenteh.dns.podman:8080 {
header_down Set-Cookie "path=/" "path=/qbtee/ ; SameSite=Strict; Secure"
handle /cp/* {
reverse_proxy unix//run/container-sockets/cockpit.socket
handle /jellyfin/* {
reverse_proxy http://systemd-jellyfin.dns.podman:8096
handle_path /adguard/* {
reverse_proxy http://systemd-adguardhome.dns.podman:80 {
header_down Location /index.html /adguard/index.html
handle_path /ab/* {
reverse_proxy http://systemd-autobangumi.dns.podman:7892
handle_path /file/* {
file_server browse {
root /mnt/share
basicauth {
!!REDACTED!!
handle_path /echo/* {
reverse_proxy http://systemd-echo.dns.podman:8080
@ward {
path / /css* /js* /img* /api* /fonts* /*/
handle @ward {
reverse_proxy http://systemd-ward.dns.podman:4000
handle /* {
redir {scheme}://{host}{uri}/
*.niconi.org {
dns cloudflare !!REDACTED!!
invoke site
http://*.niconi.org {
bind unix//run/container-sockets/caddy/caddy.socket
invoke site
