Trust X-Forwarded-Host
Latest Caddy:2 docker image
Inside k8s to serve my php application.
Request from outside are handled by a nginx that has a proxy_pass to a traefik that routes the request to my k8s deployment (caddy / php pods).
K8S , Caddy:2 docker image
Paste command here.
    # Debug
    {$DEBUG}
    # HTTP/3 support
    servers {
        protocol {
            experimental_http3
    local_certs
{$SERVER_NAME}
log
route {
    root * /srv/app/public
    push
    php_fastcgi unix//var/run/php/php-fpm.sock
    encode zstd gzip
It looks like the x-forwarded-host is not passed into my php container. I found this documentation → reverse_proxy (Caddyfile directive) — Caddy Documentation
which says that the header i need is not passed unless i set the trusted_proxies.
My problem is that im not sure how i can set it in my configuration, it seems to only be available inside of reverse proxy directive.
There is no actual error message. In the caddy log i can see that x-forwarded-host is now correctly set to the hostname of the nginx ā€œexample.mycompany.deā€.
I tried to add the trusted_proxies to my caddyfile but it says its unknown.
All subdirectives of reverse_proxy are available in php_fastcgi.
The docs mention that:
Since this directive is an opinionated wrapper over a reverse proxy, you can use any of reverse_proxy’s subdirectives to customize it.
I totally missed that part, im sorry ! That did cost me so much time :slight_smile:
Thanks a lot !
