Trouble with reverse proxy
1. Output of caddy version:
Ubuntu Server 22.04.1 LTS
sudo service caddy [start/stop/restart/status]
or
sudo systemctl [start/stop/restart/status] caddy
I tried both
/etc/caddy/Caddyfile
# domain name.
proxmox.mlarboul.eu {
        root * /usr/share/caddy
        reverse_proxy 192.168.0.21:8006
truenas.mlarboul.eu {
        reverse_proxy 192.168.0.150
cloud.mlarboul.eu {
        reverse_proxy 192.168.0.14
So I am very new to the world of self hosting. A friend told me this afternoon about caddy and how convenient it was compare to nginx especially for the ssl certificate part.
So I decided to try.
I would like to expose 3 applications interfaces: Proxmox, Nextcloud and Truenas.
Those services use to be reachable with Nginx, but not operational due to SSL.
For now, only Truenas is reachable (and working perfectly). But for Proxmox and Nextcloud, it seems that the page isn’t working.
Nextcloud error message from Brave and Firefox browser:
This page isn’t working
cloud.mlarboul.eu redirected you too many times.
Try clearing your cookies.
ERR_TOO_MANY_REDIRECTS
Proxmox error message from curl -v https://cloud.mlarboul.eu command:
*   Trying 80.236.34.5:443...
* Connected to cloud.mlarboul.eu (80.236.34.5) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*  CAfile: /etc/pki/tls/certs/ca-bundle.crt
*  CApath: none
* SSL connection using TLSv1.3 / TLS_CHACHA20_POLY1305_SHA256
*  subject: CN=cloud.mlarboul.eu
*  start date: Oct 20 15:35:31 2022 GMT
*  expire date: Jan 18 15:35:30 2023 GMT
*  subjectAltName: host "cloud.mlarboul.eu" matched cert's "cloud.mlarboul.eu"
* Using Stream ID: 1 (easy handle 0x55fb7f390e00)
> GET / HTTP/2
> Host: cloud.mlarboul.eu
> user-agent: curl/7.79.1
> accept: */*
< HTTP/2 301
< content-type: text/html
< date: Thu, 20 Oct 2022 19:09:50 GMT
< location: https://cloud.mlarboul.eu:443/
< server: Caddy
< server: nginx
< content-length: 162
<html>
<head><title>301 Moved Permanently</title></head>
<body>
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx</center>
</body>
</html>
* Connection #0 to host cloud.mlarboul.eu left intact
Proxmox error message from Brave and Firefox browser:
proxmox.mlarboul.eu is currently unable to handle this request.
HTTP ERROR 502
Proxmox error message from curl -v https://proxmox.mlarboul.eu command:
* Connected to proxmox.mlarboul.eu (80.236.34.5) port 443 (#0)
* ALPN, offering h2
*  CApath: none
*  subject: CN=proxmox.mlarboul.eu
*  start date: Oct 20 15:45:32 2022 GMT
*  expire date: Jan 18 15:45:31 2023 GMT
*  subjectAltName: host "proxmox.mlarboul.eu" matched cert's "proxmox.mlarboul.eu"
* Using Stream ID: 1 (easy handle 0x55a58484ae00)
> GET / HTTP/2
> Host: proxmox.mlarboul.eu
> accept: */*
< HTTP/2 502
< server: Caddy
< content-length: 0
< date: Thu, 20 Oct 2022 19:05:05 GMT
* Connection #0 to host proxmox.mlarboul.eu left intact
Domain names are correct because if I change the IP address of the reverse proxy using Truenas IP, it works perfectly…
And as I said I am very new, so I haven’t try a lot of things…
Obviously caddy is working like a charm but I jsut don’t know how ton configure it properly.
This config makes proxmox, truenas and nextcloud work perfectly
        reverse_proxy 192.168.0.21:8006 {
                        tls_insecure_skip_verify
cloud.mlarboul.eu {
        reverse_proxy 192.168.0.16:443 {
You shouldn’t have both root+file_server AND reverse_proxy in the same site, if you’re just trying to proxy to another server.
Remove the root and file_server stuff. That’s just an example config, and you’re meant to replace it with either your own static site’s location, or with a proxy, but not keep both.
Looks like Caddy is working correctly, and proxying to your Nginx app. But Nginx (or the underlying app behind Nginx) is triggering a redirect because it thinks it’s not being served over HTTPS.
This isn’t a problem with Caddy. You’ll need to dig into your app’s configuration to figure out what’s going on there.
Enabling this makes Caddy proxy over HTTPS instead of HTTP, and throws away all security. There’s no benefit to this. It just adds overhead to every request by making an additional TLS handshake to your backend. You can remove this config and proxy to your backend’s HTTP port instead of the HTTPS port.
