Hey everyone,
Having a bit of trouble getting Caddy to correctly proxy to an Alltube DL page I have set up. If I access the page on LAN, it works fine, and if I set up a forward to access it directly from the web it also works fine.
However, when proxying it through Caddy, it doesn’t load the images or CSS or anything on the page, I just get a blank white page with generic text.
This is what the section of my Caddyfile originally looked like, and this works fine with most of my other pages which are all also proxying through non-standard ports:
https://mydomain.net:555
proxy / http://192.168.2.5/ {
tls /etc/letsencrypt/live/mydomain.net/fullchain.pem /etc/letsencrypt/live/mydomain.net/privkey.pem
However, with this one, I get the above problem. I did determine what the issue actually was. If I click on the unloaded image and get the URL, it tries to load mydomain.net/img instead of mydomain.net:555/img. So, I removed transparent, and now I at least get the header image to load, but nothing else on the page does, so presumably it’s still not loading something, like CSS, but I’m not sure how to troubleshoot this.
It may be relevant (I don’t know) that the header image, without transparent included, does load, but it loads as an http link rather than https.
I setup an error.log but it never wrote anything to it. The default page for Alltube DL is just index.php, not sure if it’s an issue with that or my Caddy configuration.
