Context: I have a small Bluesky/ATProto PDS running my fork of the official PDS repo.
The bluesky-social/pds repo on GitHub uses Caddy as part of its setup.
My fork has a few modifications to expose the /srv folder to Docker environment. I made this to serve a static page which can be accessed through my domain, caramelo.social.br. It is currently accessible over web.
I have a second domain, bisca.net.br, which I want to redirect to the same server and receive the same static page in response. Sounds simple, right?
The problem I’m having is: this second domain always returns a SSL error, while the first works fine.
I tried to follow the instructions provided here: Multiple domains, but it didn’t work for me.
curl -vL https://bisca.net.br:
* Trying 191.252.210.214:443...
* Connected to bisca.net.br (191.252.210.214) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* CApath: /etc/ssl/certs
* TLSv1.2 (IN), TLS header, Unknown (21):
* error:0A000438:SSL routines::tlsv1 alert internal error
* Closing connection 0
curl: (35) error:0A000438:SSL routines::tlsv1 alert internal error
docker logs pds --follow:
{"level":30,"time":1767888545803,"pid":7,"hostname":"lf-proto-pds.vps-kinghost.net","name":"pds","req":{"id":12,"method":"GET","url":"/tls-check?domain=bisca.net.br","query":{"domain":"bisca.net.br"},"params":{},"headers":{"host":"localhost:3000","user-agent":"Go-http-client/1.1","accept-encoding":"gzip"}},"res":{"statusCode":400,"headers":{"x-powered-by":"Express","access-control-allow-origin":"*","content-type":"application/json; charset=utf-8","content-length":"78","etag":"W/\"4e-B4TQPtiXf/PDKkAoOJY4fpev3Wc\"","vary":"Accept-Encoding"}},"responseTime":2,"msg":"request completed"}
docker compose exec caddy caddy version:
Debian 12, Linux kernel 6.1.0-41-amd64
Docker version 29.1.3, build f52814d
systemctl start pds.service
cat /etc/systemd/system/pds.service:
Description=Bluesky PDS Service
Documentation=https://github.com/bluesky-social/pds
Requires=docker.service
After=docker.service
Type=oneshot
RemainAfterExit=yes
WorkingDirectory=/pds
ExecStart=/usr/bin/docker compose --file /pds/compose.yaml up --detach
ExecStop=/usr/bin/docker compose --file /pds/compose.yaml down
WantedBy=default.target
compose.yaml:
version: '3.9'
image: caddy:2
network_mode: host
depends_on:
- pds
- type: bind
source: /pds/caddy/data
target: /data
- type: bind
source: /pds/caddy/etc/caddy
target: /etc/caddy
- type: bind
source: /srv
target: /srv
pds:
container_name: pds
image: ghcr.io/bluesky-social/pds:0.4
network_mode: host
- type: bind
source: /pds
target: /pds
env_file:
- /pds/pds.env
watchtower:
container_name: watchtower
image: ghcr.io/nicholas-fedor/watchtower:latest
network_mode: host
- type: bind
source: /var/run/docker.sock
target: /var/run/docker.sock
WATCHTOWER_CLEANUP: true
WATCHTOWER_SCHEDULE: "@midnight"
email lf********@yahoo.com
on_demand_tls {
ask http://localhost:3000/tls-check
*.caramelo.social.br, caramelo.social.br {
root * /srv
on_demand
@pds {
path /xrpc/*
path /.well-known/atproto-did
path /.well-known/oauth-protected-resource
path /.well-known/oauth-authorization-server
path /oauth/*
path /@atproto/*
path /gate/*
reverse_proxy @pds http://localhost:3000
encode
templates
*.bisca.net.br, bisca.net.br {
root * /srv
on_demand
@pds {
path /xrpc/*
path /oauth/*
path /@atproto/*
path /gate/*
encode
templates
Bluesky PDS repo: GitHub - bluesky-social/pds: Bluesky PDS (Personal Data Server) container image, compose file, and documentation · GitHub
My PDS fork: GitHub - luan-u/bsky-pds at caramelo · GitHub
