I have been trying to stop managing (needing to remember) IPs for applications / services I am running locally. What has happened up until the last week or so is that I spin up an application in a Proxmox LXC and set a static IP for it in my router. Then, in my browser I just use the IP:PORT to get to the service. All of that works but whenever I reopen a browser and I am not restoring previous sessions, then I have to think about what IP and PORT the service is on so I can get back to it.
There was 2 options at that point, I could deploy a dashboard or I could look at using DNS. Given that I have some externally exposed services, I had Caddy and thus it seemed reasonable that I could use it to do something similar for the internal services.
First thing I did was ensure that Pi-Hole had the Conditional Forwarding turned on and pointed to my router and using the same domain “internal” as I used on my router.
Next, I entered a block in my Caddyfile following the same format as with external assets with the exception of the tls directive. For external facing, I use my Cloudflare account and the DNS Challenge. For the internal, I was using tls internal.
I started with sonarr and added the following block to my Caddyfile:
sonarr.internal {
tls internal
reverse_proxy sonarr.internal:8989
output file /var/log/caddy/sonarr.log
format json
level DEBUG
Didn’t work. At this point, I wasn’t sure if the IP was being found (DNS issues) so I started with PiHole and my router. After discussing with the PiHole community, it was indicated that DNS could be ruled out as the IP was being returned.
No logs are created either.
From my Caddy server, I ran a number of test using curl and dig.
curl -vL http://sonarr.internal
* Trying 192.168.1.242:80...
* connect to 192.168.1.242 port 80 failed: Connection refused
* Failed to connect to sonarr.internal port 80 after 1 ms: Couldn't connect to server
* Closing connection 0
curl: (7) Failed to connect to sonarr.internal port 80 after 1 ms: Couldn't connect to server
I found it interesting (but maybe expected) that it was port 80 and the IP address is correct. So I ran the command again but this time added the expected 8989 for the port.
curl -vL http://sonarr.internal:8989
* Trying 192.168.1.242:8989...
* Connected to sonarr.internal (192.168.1.242) port 8989 (#0)
> GET / HTTP/1.1
> Host: sonarr.internal:8989
> User-Agent: curl/7.88.1
< HTTP/1.1 200 OK
< Content-Length: 1952
< Content-Type: text/html
< Date: Tue, 20 Aug 2024 10:55:59 GMT
< Server: Kestrel
< Cache-Control: no-cache, no-store
< Expires: -1
< Pragma: no-cache
<!doctype html><html lang="en"><head><meta charset="utf-8"/><meta name="viewport" content="width=device-width,initial-scale=1"/><meta name="theme-color" content="#3a3f51"/><meta name="msapplication-navbutton-color" content="#3a3f51"/><meta name="mobile-web-app-capable" content="yes"/><meta name="apple-mobile-web-app-capable" content="yes"/><meta name="apple-mobile-web-app-status-bar-style" content="black-translucent"/><meta name="format-detection" content="telephone=no"><meta name="description" content="Sonarr"/><link rel="apple-touch-icon" sizes="180x180" href="/Content/Images/Icons/apple-touch-icon.png?h=d+iS4xWxn2A2bjUwrERmSg"/><link rel="icon" type="image/png" sizes="32x32" href="/Content/Images/Icons/favicon-32x32.png?h=s64FHSxrh1sgZCiBBIVikQ"/><link rel="icon" type="image/png" sizes="16x16" href="/Content/Images/Icons/favicon-16x16.png?h=wksVbPqhKGB2B5P0O0h8IQ"/><link rel="manifest" href="/Content/Images/Icons/manifest.json?h=cUPA5242uyihHp+0wPd35A" crossorigin="use-credentials"/><link rel="mask-icon" href="/Content/Images/Icons/safari-pinned-tab.svg?h=00yLx0v47nGMoh9FRbDFkg" color="#00ccff"/><link rel="shortcut icon" type="image/ico" href="/favicon.ico"/><meta name="msapplication-config" content="/Content/Images/Icons/browserconfig.xml"/><link rel="stylesheet" href="/Content/Fonts/fonts.css?h=zGLiHXGOeD2wslXPvUJgKA"><script>window.Sonarr = {
urlBase: ''
};</script><script src="/index-f922a4ce2468b041d6e4.js"></script><link href="/Content/styles.css?h=zd/NtvlL8ktbpoBZYtb1Yw" rel="stylesheet"><title>Sonarr</title><style>.root {
overflow: hidden;
height: 100%; /* needed for proper layout */
@media only screen and (max-width: 768px) {
.root {
display: flex;
flex-direction: column;
min-height: 100%;
height: auto;
* Connection #0 to host sonarr.internal left intact
}</style></head><body><div id="portal-root"></div><div id="root" class="root"></div></body></html>
dig sonarr.internal
; <<>> DiG 9.18.24-1-Debian <<>> sonarr.internal
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 21731
;; flags: qr aa rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 1232
;; QUESTION SECTION:
;sonarr.internal. IN A
;; ANSWER SECTION:
sonarr.internal. 0 IN A 192.168.1.242
;; Query time: 1 msec
;; SERVER: 192.168.1.233#53(192.168.1.233) (UDP)
;; WHEN: Tue Aug 20 11:06:59 UTC 2024
;; MSG SIZE rcvd: 60
Generally speaking, there are no error messages / logs.
journalctl
Aug 19 13:03:07 caddy systemd[1]: Starting caddy.service - Caddy...
Aug 19 13:03:07 caddy caddy[30053]: caddy.HomeDir=/var/lib/caddy
Aug 19 13:03:07 caddy caddy[30053]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Aug 19 13:03:07 caddy caddy[30053]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Aug 19 13:03:07 caddy caddy[30053]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Aug 19 13:03:07 caddy caddy[30053]: caddy.Version=v2.8.4 h1:q3pe0wpBj1OcHFZ3n/1nl4V4bxBrYoSoab7rL9BMYNk=
Aug 19 13:03:07 caddy caddy[30053]: runtime.GOOS=linux
Aug 19 13:03:07 caddy caddy[30053]: runtime.GOARCH=amd64
Aug 19 13:03:07 caddy caddy[30053]: runtime.Compiler=gc
Aug 19 13:03:07 caddy caddy[30053]: runtime.NumCPU=1
Aug 19 13:03:07 caddy caddy[30053]: runtime.GOMAXPROCS=1
Aug 19 13:03:07 caddy caddy[30053]: runtime.Version=go1.22.1
Aug 19 13:03:07 caddy caddy[30053]: os.Getwd=/
Aug 19 13:03:07 caddy caddy[30053]: LANG=C
Aug 19 13:03:07 caddy caddy[30053]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Aug 19 13:03:07 caddy caddy[30053]: NOTIFY_SOCKET=/run/systemd/notify
Aug 19 13:03:07 caddy caddy[30053]: HOME=/var/lib/caddy
Aug 19 13:03:07 caddy caddy[30053]: LOGNAME=caddy
Aug 19 13:03:07 caddy caddy[30053]: USER=caddy
Aug 19 13:03:07 caddy caddy[30053]: INVOCATION_ID=f7645ad4e1f34ea493d10d6e16c2cc27
Aug 19 13:03:07 caddy caddy[30053]: JOURNAL_STREAM=8:197702557
Aug 19 13:03:07 caddy caddy[30053]: SYSTEMD_EXEC_PID=30053
Aug 19 13:03:07 caddy caddy[30053]: {"level":"info","ts":1724072587.0775619,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Aug 19 13:03:07 caddy caddy[30053]: {"level":"info","ts":1724072587.0795665,"msg":"adapted config to JSON","adapter":"caddyfile"}
Aug 19 13:03:07 caddy caddy[30053]: {"level":"warn","ts":1724072587.0795727,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' t
o fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":50}
Aug 19 13:03:07 caddy caddy[30053]: {"level":"info","ts":1724072587.0806556,"msg":"redirected default logger","from":"stderr","to":"/var/log/caddy
/debug.log"}
Aug 19 13:03:07 caddy caddy[30053]: {"level":"info","ts":1724072587.0818315,"msg":"failed to sufficiently increase receive buffer size (was: 208 k
iB, wanted: 7168 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Buffer-Sizes for details."}
Aug 19 13:03:07 caddy systemd[1]: Started caddy.service - Caddy.
Aug 20 10:51:21 caddy systemd[1]: Stopping caddy.service - Caddy...
Aug 20 10:51:21 caddy systemd[1]: caddy.service: Deactivated successfully.
Aug 20 10:51:21 caddy systemd[1]: Stopped caddy.service - Caddy.
Aug 20 10:51:21 caddy systemd[1]: caddy.service: Consumed 15.173s CPU time.
Aug 20 10:51:21 caddy systemd[1]: Starting caddy.service - Caddy...
Aug 20 10:51:22 caddy caddy[38710]: caddy.HomeDir=/var/lib/caddy
Aug 20 10:51:22 caddy caddy[38710]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Aug 20 10:51:22 caddy caddy[38710]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Aug 20 10:51:22 caddy caddy[38710]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Aug 20 10:51:22 caddy caddy[38710]: caddy.Version=v2.8.4 h1:q3pe0wpBj1OcHFZ3n/1nl4V4bxBrYoSoab7rL9BMYNk=
Aug 20 10:51:22 caddy caddy[38710]: runtime.GOOS=linux
Aug 20 10:51:22 caddy caddy[38710]: runtime.GOARCH=amd64
Aug 20 10:51:22 caddy caddy[38710]: runtime.Compiler=gc
Aug 20 10:51:22 caddy caddy[38710]: runtime.NumCPU=1
Aug 20 10:51:22 caddy caddy[38710]: runtime.GOMAXPROCS=1
Aug 20 10:51:22 caddy caddy[38710]: runtime.Version=go1.22.1
Aug 20 10:51:22 caddy caddy[38710]: os.Getwd=/
Aug 20 10:51:22 caddy caddy[38710]: LANG=C
Aug 20 10:51:22 caddy caddy[38710]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
Aug 20 10:51:22 caddy caddy[38710]: NOTIFY_SOCKET=/run/systemd/notify
Aug 20 10:51:22 caddy caddy[38710]: HOME=/var/lib/caddy
Aug 20 10:51:22 caddy caddy[38710]: LOGNAME=caddy
Aug 20 10:51:22 caddy caddy[38710]: USER=caddy
Aug 20 10:51:22 caddy caddy[38710]: INVOCATION_ID=34db0359ed7a4e67b00a676acd864e7f
Aug 20 10:51:22 caddy caddy[38710]: JOURNAL_STREAM=8:203362687
Aug 20 10:51:22 caddy caddy[38710]: SYSTEMD_EXEC_PID=38710
Aug 20 10:51:22 caddy caddy[38710]: {"level":"info","ts":1724151082.032852,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Aug 20 10:51:22 caddy caddy[38710]: {"level":"info","ts":1724151082.0342128,"msg":"adapted config to JSON","adapter":"caddyfile"}
Aug 20 10:51:22 caddy caddy[38710]: {"level":"warn","ts":1724151082.0342188,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' t
o fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":48}
Aug 20 10:51:22 caddy caddy[38710]: {"level":"info","ts":1724151082.0353272,"msg":"redirected default logger","from":"stderr","to":"/var/log/caddy
/debug.log"}
Aug 20 10:51:22 caddy caddy[38710]: {"level":"info","ts":1724151082.037223,"msg":"warning: \"certutil\" is not available, install \"certutil\" wit
h \"apt install libnss3-tools\" or \"yum install nss-tools\" and try again"}
Aug 20 10:51:22 caddy caddy[38710]: {"level":"info","ts":1724151082.0372734,"msg":"define JAVA_HOME environment variable to use the Java trust"}
Aug 20 10:51:22 caddy caddy[38710]: {"level":"info","ts":1724151082.0513105,"msg":"failed to sufficiently increase receive buffer size (was: 208 k
Aug 20 10:51:22 caddy systemd[1]: Started caddy.service - Caddy.
Note: I saw the comment about the format and ran the command as recommended.
Specific sonarr.log
cat /var/log/caddy/sonarr.log
cat: /var/log/caddy/sonarr.log: No such file or directory
Debug log
{"level":"warn","ts":1724151082.0654244,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [sonarr.internal]: no OCSP server specified in certificate","identifiers":["sonarr.internal"]}
{"level":"debug","ts":1724151082.065438,"logger":"tls.cache","msg":"added certificate to cache","subjects":["sonarr.internal"],"expiration":1724046172,"managed":true,"issuer_key":"local","hash":"3aebe1f542d632077320a4e2f6e7745841ae98b65da1ebfc56794e213e583c17","cache_size":12,"cache_capacity":10000}
{"level":"debug","ts":1724151082.0654519,"logger":"events","msg":"event","name":"cached_managed_cert","id":"835026c5-3ce6-4179-bd6d-4b10d82a15e5","origin":"tls","data":{"sans":["sonarr.internal"]}}
{"level":"info","ts":1724151082.0675695,"logger":"tls","msg":"certificate is in configured renewal window based on expiration date","subjects":["sonarr.internal"],"expiration":1724046172,"ari_cert_id":"","next_ari_update":null,"renew_check_interval":600,"window_start":-6795364578.8713455,"window_end":-6795364578.8713455,"remaining":-104910.067569193}
{"level":"info","ts":1724151082.0677338,"logger":"tls.renew","msg":"acquiring lock","identifier":"sonarr.internal"}
{"level":"info","ts":1724151082.068569,"logger":"tls.renew","msg":"lock acquired","identifier":"sonarr.internal"}
{"level":"info","ts":1724151082.0687044,"logger":"tls.renew","msg":"renewing certificate","identifier":"sonarr.internal","remaining":-104910.068702798}
{"level":"debug","ts":1724151082.0687244,"logger":"events","msg":"event","name":"cert_obtaining","id":"792ba694-aede-4844-9992-a85131e2341b","origin":"tls","data":{"forced":false,"identifier":"sonarr.internal","issuer":"local","remaining":-104910068702798,"renewal":true}}
{"level":"info","ts":1724151082.0693057,"logger":"tls.renew","msg":"certificate renewed successfully","identifier":"sonarr.internal","issuer":"local"}
{"level":"debug","ts":1724151082.0693412,"logger":"events","msg":"event","name":"cert_obtained","id":"04ba4596-d6e5-434c-894a-73875041b05a","origin":"tls","data":{"certificate_path":"certificates/local/sonarr.internal/sonarr.internal.crt","csr_pem":"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","identifier":"sonarr.internal","issuer":"local","metadata_path":"certificates/local/sonarr.internal/sonarr.internal.json","private_key_path":"certificates/local/sonarr.internal/sonarr.internal.key","remaining":-104910068702798,"renewal":true,"storage_path":"certificates/local/sonarr.internal"}}
{"level":"info","ts":1724151082.0693502,"logger":"tls.renew","msg":"releasing lock","identifier":"sonarr.internal"}
{"level":"info","ts":1724151082.0693958,"logger":"tls","msg":"reloading managed certificate","identifiers":["sonarr.internal"]}
{"level":"warn","ts":1724151082.0695336,"logger":"tls","msg":"stapling OCSP","error":"no OCSP stapling for [sonarr.internal]: no OCSP server specified in certificate","identifiers":["sonarr.internal"]}
{"level":"debug","ts":1724151082.0695467,"logger":"tls.cache","msg":"removed certificate from cache","subjects":["sonarr.internal"],"expiration":1724046172,"managed":true,"issuer_key":"local","hash":"3aebe1f542d632077320a4e2f6e7745841ae98b65da1ebfc56794e213e583c17","cache_size":11,"cache_capacity":10000}
{"level":"debug","ts":1724151082.0695555,"logger":"tls.cache","msg":"added certificate to cache","subjects":["sonarr.internal"],"expiration":1724194283,"managed":true,"issuer_key":"local","hash":"74619680d61fe6506820b62c5fc05696a89ba6167e746e84f348692958351f1d","cache_size":12,"cache_capacity":10000}
{"level":"info","ts":1724151082.0695624,"logger":"tls.cache","msg":"replaced certificate in cache","subjects":["sonarr.internal"],"new_expiration":1724194283}
I attempted to install the certificate on my Mac, but I get an error -26276 indicating that the certificate is not valid.
When I go to http://sonarr.internal in the browser, I just get a can’t connect.
I then used Postman and did a GET
GET http://sonarr.internal/
Error: connect ECONNREFUSED 192.168.1.242:80
Request Headers
User-Agent: PostmanRuntime/7.30.0
Accept: */*
Postman-Token: 9e27d16c-b4fc-4fe0-8765-0198f4f4a46c
Accept-Encoding: gzip, deflate, br
Connection: keep-alive
Again, I added the PORT
GET http://sonarr.internal:8989/
200
11 ms
Network
addresses: {…}
local: {…}
address: "192.168.1.2"
family: "IPv4"
port: 49497
remote: {…}
address: "192.168.1.242"
family: "IPv4"
port: 8989
Request Headers
Accept: */*
Postman-Token: 2d3dd1b5-09b9-4aa6-92da-4cebfcac6789
Response Headers
Date: Tue, 20 Aug 2024 11:02:08 GMT
Server: Kestrel
Content-Encoding: br
Expires: -1
Pragma: no-cache
Transfer-Encoding: chunked
Vary: Accept-Encoding
Response Body
urlBase: ''
overflow: hidden;
.root {
display: flex;
min-height: 100%;
height: auto;
caddy version
Because I am using Cloudflare, I did the xcaddy following the following --with Cloudflare
https://caddyserver.com/docs/build#xcaddy
and when I am restarting
systemctl restart caddy
Caddy is in a Debian 12 Proxmox LXC. PiHole and Unbound are on the same Proxmox node and are also in LXCs. Sonarr is also on the same Proxmox node.
While referring to the url in the help text, I saw section about Local HTTS (Keep Caddy Running — Caddy Documentation). I ran that command in the process of writing this post. I went back and checked to see if things changed, nothing did.
I am really not comfortable pasting the entire Caddyfile when it contains entries for things that work. If that means I can't get help based on everything else, then that is fine.
The only other thing that I can think of that might be relevant is that I did attempt to use the IP address, but it didn’t work either.
sonarr.internal {
tls internal
reverse_proxy 192.168.1.242:8989
