Caddy Version: 2.2.0
My family’s small Weight Loss & Health business was bombed out of the water because of Covid and ever since then we’ve been struggling to shift to an online business model.
We decided to cut costs and use free and open-source software for client interactions, CRM, office suite, and a cloud for backups. (saving a lot)
The plan was to get one cloud VM and on it run various services such as Moodle, Odoo, Nextcloud and so on - each connected to a sub-domain on our website, for which I’ve settled on using Caddy Reverse Proxy and Docker. This is where the struggle begins!
Docker on Debian 10 LTS
sudo docker-compose up -d
version: "3.7"
image: caddy:<version>
- $PWD/site:/srv
- caddy_data:/data
- caddy_config:/config
No caddyfile yet!
The first problem I’m having is simply getting caddy to run on docker because although I know how to use Linux and to Code, I cannot understand the errors I run into docker - but im doing my best to learn
ERROR: Named volume "caddy_data:/data:rw" is used in service "caddy" but no declaration was found in the volumes section.
Googling the error, related search terms, docker syntax - everything - 1000 times + looking for youtube tutorials or others people’s sample caddy docker-compose files (found none that would work).
I’ve even tried looking at nginx configs to try to figure it out but no luck yet, I just need more technical knowledge
Caddy Docker: Docker Hub
just didn’t know exactly how to contribute
