Tried hard to make route53 work and failed
I tried to setup a wildcard certificate for a subzone managed in route53 using the route53 module. I passed 2 aws key. I have verfied those keys work with a simple go program using libdns, and with those two keys a TXT record is crreate dcorrectly.
However when I try to setup it with Caddy nothing happens.
nothing happens
I tried to enable debug log and this is what I see - in specting the code more entries should happen
2024/06/22 12:43:33.718 INFO    tls.issuance.acme.acme_client   trying to solve challenge       {"identifier": "sciabarra.nuvtest.net", "challenge_type": "dns-01", "ca": "https://acme-v02.api.letsencrypt.org/directory"}
2024/06/22 12:43:33.743 ERROR   tls.issuance.acme.acme_client   cleaning up solver      {"identifier": "sciabarra.nuvtest.net", "challenge_type": "dns-01", "error": "no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
I even tried to customize the provide, addedd print and I was able to see the provider is provisioned correctly
caddy version
xcaddy build --with github.com/caddy-dns/route53
Linux Ubuntu 22
caddy run --config /etc/caddy/Caddyfile
Type=notify
*.sciabarra.nuvtest.net {
    dns route53 {
      access_key_id "..."
      secret_access_key "..."
Please share all your logs, not just two lines. Please share your entire config, not just the DNS part.
Please use the latest version, v2.8.4.
This is the full config:
        email michele@nuvolaris.io
        log debug
        respond "sciabarra.nuvtest.net" 200
                dns route53 {
                        access_key_id "...."
and this is the full log with debug enabled
Jun 23 09:34:16 sciabarra0 caddy[58868]: caddy.HomeDir=/var/lib/caddy
Jun 23 09:34:16 sciabarra0 caddy[58868]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Jun 23 09:34:16 sciabarra0 caddy[58868]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Jun 23 09:34:16 sciabarra0 caddy[58868]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Jun 23 09:34:16 sciabarra0 caddy[58868]: caddy.Version=v2.8.4 h1:q3pe0wpBj1OcHFZ3n/1nl4V4bxBrYoSoab7rL9BMYNk=
Jun 23 09:34:16 sciabarra0 caddy[58868]: runtime.GOOS=linux
Jun 23 09:34:16 sciabarra0 caddy[58868]: runtime.GOARCH=amd64
Jun 23 09:34:16 sciabarra0 caddy[58868]: runtime.Compiler=gc
Jun 23 09:34:16 sciabarra0 caddy[58868]: runtime.NumCPU=2
Jun 23 09:34:16 sciabarra0 caddy[58868]: runtime.GOMAXPROCS=2
Jun 23 09:34:16 sciabarra0 caddy[58868]: runtime.Version=go1.22.4
Jun 23 09:34:16 sciabarra0 caddy[58868]: os.Getwd=/
Jun 23 09:34:16 sciabarra0 caddy[58868]: LANG=en_US.UTF-8
Jun 23 09:34:16 sciabarra0 caddy[58868]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Jun 23 09:34:16 sciabarra0 caddy[58868]: NOTIFY_SOCKET=/run/systemd/notify
Jun 23 09:34:16 sciabarra0 caddy[58868]: HOME=/var/lib/caddy
Jun 23 09:34:16 sciabarra0 caddy[58868]: LOGNAME=caddy
Jun 23 09:34:16 sciabarra0 caddy[58868]: USER=caddy
Jun 23 09:34:16 sciabarra0 caddy[58868]: INVOCATION_ID=9c8caf9aa4514412b6c5fca8cf34018c
Jun 23 09:34:16 sciabarra0 caddy[58868]: JOURNAL_STREAM=8:322642
Jun 23 09:34:16 sciabarra0 caddy[58868]: SYSTEMD_EXEC_PID=58868
Jun
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8019536,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8044527,"msg":"adapted config to JSON","adapter":"caddyfile"}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"warn","ts":1719135256.8044927,"msg":"Caddyfile input is not formatted; run 'caddy fmt --overwrite' to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":3}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8079731,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8087919,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8088398,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8098207,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0005c6d00"}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.810095,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8105314,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8106,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8106093,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["*.sciabarra.nuvtest.net","sciabarra.nuvtest.net"]}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.81529,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8157332,"msg":"serving initial configuration"}
Jun 23 09:34:16 sciabarra0 systemd[1]: Started Caddy.
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8187838,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/var/lib/caddy/.local/share/caddy","instance":"bad72d13-d98c-4022-8a50-e53e2e4c3158","try_ag>
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8190255,"logger":"tls","msg":"finished cleaning storage units"}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8213267,"logger":"tls.obtain","msg":"acquiring lock","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8229082,"logger":"tls.obtain","msg":"lock acquired","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8234277,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8269284,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["*.sciabarra.nuvtest.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"michele@nuvolaris.>
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8269744,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["*.sciabarra.nuvtest.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"michele@nuvol>
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.827021,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-v02.api.letsencrypt.org/acme/acct/1798017827","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 09:34:17 sciabarra0 caddy[58868]: {"level":"info","ts":1719135257.7635295,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-v02.api.letsencrypt.org/directory"}
Jun 23 09:34:17 sciabarra0 caddy[58868]: {"level":"error","ts":1719135257.771594,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-chal>
Jun 23 09:34:17 sciabarra0 caddy[58868]: {"level":"error","ts":1719135257.931715,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] sol>
Jun 23 09:34:17 sciabarra0 caddy[58868]: {"level":"error","ts":1719135257.9327147,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sci>
Jun 23 09:35:17 sciabarra0 caddy[58868]: {"level":"info","ts":1719135317.9341779,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 09:35:17 sciabarra0 caddy[58868]: {"level":"info","ts":1719135317.9365237,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 09:35:18 sciabarra0 caddy[58868]: {"level":"info","ts":1719135318.965778,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/direc>
Jun 23 09:35:18 sciabarra0 caddy[58868]: {"level":"error","ts":1719135318.9661384,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-cha>
un 23 09:35:19 sciabarra0 caddy[58868]: {"level":"error","ts":1719135319.1401138,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] so>
Jun 23 09:35:19 sciabarra0 caddy[58868]: {"level":"error","ts":1719135319.140293,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"scia>
Jun 23 09:37:19 sciabarra0 caddy[58868]: {"level":"info","ts":1719135439.1419709,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 09:37:19 sciabarra0 caddy[58868]: {"level":"info","ts":1719135439.1459205,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 09:37:19 sciabarra0 caddy[58868]: {"level":"info","ts":1719135439.6880713,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/dire>
Jun 23 09:37:19 sciabarra0 caddy[58868]: {"level":"error","ts":1719135439.6892414,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-cha>
Jun 23 09:37:19 sciabarra0 caddy[58868]: {"level":"error","ts":1719135439.8616126,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] so>
Jun 23 09:37:19 sciabarra0 caddy[58868]: {"level":"error","ts":1719135439.8618336,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sci>
Jun 23 09:39:19 sciabarra0 caddy[58868]: {"level":"info","ts":1719135559.8628387,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 09:39:19 sciabarra0 caddy[58868]: {"level":"info","ts":1719135559.8650157,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 09:39:20 sciabarra0 caddy[58868]: {"level":"info","ts":1719135560.404908,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/direc>
Jun 23 09:39:20 sciabarra0 caddy[58868]: {"level":"error","ts":1719135560.4069884,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-cha>
Jun 23 09:39:20 sciabarra0 caddy[58868]: {"level":"error","ts":1719135560.5805037,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] so>
Jun 23 09:39:20 sciabarra0 caddy[58868]: {"level":"error","ts":1719135560.5806518,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sci>
l
the problem is it never creates the TXT record in route53
To check if there is some firewall or block on amazon from my ip, I also wrote a test in go using libdns to check this kind of problems:
package main
import (
	"context"
	"log"
	"github.com/libdns/route53"
	"github.com/libdns/libdns"
func main() {
	p := &route53.Provider{
		AccessKeyId: "...",
		SecretAccessKey: "...",
	domain := "sciabarra.nuvtest.net."
	ctx := context.Background()
	_, err := p.AppendRecords(ctx, domain, []libdns.Record{
			Value: `world`,
			Type:  "TXT",
	if err != nil {
		log.Fatalln(err)
	rs, err := p.GetRecords(ctx, domain)
	if err != nil {
		log.Fatalln(err)
	for _, r := range rs {
		log.Printf("type: %v, value: %v, ttl: %v", r.Type, r.Value, r.TTL)
and this works:
# go run test.go
2024/06/23 09:39:38 type: A, value: 89.233.107.210, ttl: 5m0s
2024/06/23 09:39:38 type: NS, value: ns-1206.awsdns-22.org., ttl: 48h0m0s
2024/06/23 09:39:38 type: NS, value: ns-1901.awsdns-45.co.uk., ttl: 48h0m0s
2024/06/23 09:39:38 type: NS, value: ns-714.awsdns-25.net., ttl: 48h0m0s
2024/06/23 09:39:38 type: NS, value: ns-26.awsdns-03.com., ttl: 48h0m0s
2024/06/23 09:39:38 type: SOA, value: ns-1206.awsdns-22.org. awsdns-hostmaster.amazon.com. 1 7200 900 1209600 86400, ttl: 15m0s
2024/06/23 09:39:38 type: TXT, value: world, ttl: 0s
So I am totally out of stem. Libdns works. I even tried with other providers, like hetzner, and this works.
Any hint?
Your logs are truncated, notice the > at the end of the lines, so we can’t see the actual problem. Please use the command here in the docs Keep Caddy Running — Caddy Documentation
If that’s the case, then it’s a bug with the route53 plugin I assume, and you’ll need to get help from its authors. I don’t use AWS so I can’t really help with that plugin in particular.
this is the complete log
Jun 23 09:34:16 sciabarra0 systemd[1]: Starting Caddy...
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8187838,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/var/lib/caddy/.local/share/caddy","instance":"bad72d13-d98c-4022-8a50-e53e2e4c3158","try_again":1719221656.8187666,"try_again_in":86399.999997749}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8269284,"logger":"tls.issuance.acme","msg":"waiting on internal rate limiter","identifiers":["*.sciabarra.nuvtest.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"michele@nuvolaris.io"}
Jun 23 09:34:16 sciabarra0 caddy[58868]: {"level":"info","ts":1719135256.8269744,"logger":"tls.issuance.acme","msg":"done waiting on internal rate limiter","identifiers":["*.sciabarra.nuvtest.net"],"ca":"https://acme-v02.api.letsencrypt.org/directory","account":"michele@nuvolaris.io"}
Jun 23 09:34:17 sciabarra0 caddy[58868]: {"level":"error","ts":1719135257.771594,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 09:34:17 sciabarra0 caddy[58868]: {"level":"error","ts":1719135257.931715,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-v02.api.letsencrypt.org/acme/order/1798017827/280936198777) (ca=https://acme-v02.api.letsencrypt.org/directory)"}
Jun 23 09:34:17 sciabarra0 caddy[58868]: {"level":"error","ts":1719135257.9327147,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-v02.api.letsencrypt.org/acme/order/1798017827/280936198777) (ca=https://acme-v02.api.letsencrypt.org/directory)","attempt":1,"retrying_in":60,"elapsed":1.109450188,"max_duration":2592000}
Jun 23 09:35:18 sciabarra0 caddy[58868]: {"level":"info","ts":1719135318.965778,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 09:35:18 sciabarra0 caddy[58868]: {"level":"error","ts":1719135318.9661384,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 09:35:19 sciabarra0 caddy[58868]: {"level":"error","ts":1719135319.1401138,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375100363) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 09:35:19 sciabarra0 caddy[58868]: {"level":"error","ts":1719135319.140293,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375100363) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":2,"retrying_in":120,"elapsed":62.317023408,"max_duration":2592000}
Jun 23 09:37:19 sciabarra0 caddy[58868]: {"level":"info","ts":1719135439.6880713,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 09:37:19 sciabarra0 caddy[58868]: {"level":"error","ts":1719135439.6892414,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 09:37:19 sciabarra0 caddy[58868]: {"level":"error","ts":1719135439.8616126,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375128733) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 09:37:19 sciabarra0 caddy[58868]: {"level":"error","ts":1719135439.8618336,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375128733) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":3,"retrying_in":120,"elapsed":183.038569001,"max_duration":2592000}
Jun 23 09:39:20 sciabarra0 caddy[58868]: {"level":"info","ts":1719135560.404908,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 09:39:20 sciabarra0 caddy[58868]: {"level":"error","ts":1719135560.4069884,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 09:39:20 sciabarra0 caddy[58868]: {"level":"error","ts":1719135560.5805037,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375153513) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 09:39:20 sciabarra0 caddy[58868]: {"level":"error","ts":1719135560.5806518,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375153513) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":4,"retrying_in":300,"elapsed":303.757387275,"max_duration":2592000}
Jun 23 09:44:20 sciabarra0 caddy[58868]: {"level":"info","ts":1719135860.5817893,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 09:44:20 sciabarra0 caddy[58868]: {"level":"info","ts":1719135860.5847723,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 09:44:21 sciabarra0 caddy[58868]: {"level":"info","ts":1719135861.3417778,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 09:44:21 sciabarra0 caddy[58868]: {"level":"error","ts":1719135861.3423355,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 09:44:21 sciabarra0 caddy[58868]: {"level":"error","ts":1719135861.492532,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375227843) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 09:44:21 sciabarra0 caddy[58868]: {"level":"error","ts":1719135861.4932914,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375227843) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":5,"retrying_in":600,"elapsed":604.670025978,"max_duration":2592000}
Jun 23 09:54:21 sciabarra0 caddy[58868]: {"level":"info","ts":1719136461.494582,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 09:54:21 sciabarra0 caddy[58868]: {"level":"info","ts":1719136461.4982219,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 09:54:22 sciabarra0 caddy[58868]: {"level":"info","ts":1719136462.2658386,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 09:54:22 sciabarra0 caddy[58868]: {"level":"error","ts":1719136462.2667327,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 09:54:22 sciabarra0 caddy[58868]: {"level":"error","ts":1719136462.4196646,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375348683) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 09:54:22 sciabarra0 caddy[58868]: {"level":"error","ts":1719136462.4204106,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375348683) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":6,"retrying_in":600,"elapsed":1205.59714613,"max_duration":2592000}
Jun 23 10:04:22 sciabarra0 caddy[58868]: {"level":"info","ts":1719137062.423984,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 10:04:22 sciabarra0 caddy[58868]: {"level":"info","ts":1719137062.4281912,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 10:04:23 sciabarra0 caddy[58868]: {"level":"info","ts":1719137063.2133155,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 10:04:23 sciabarra0 caddy[58868]: {"level":"error","ts":1719137063.2138646,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 10:04:23 sciabarra0 caddy[58868]: {"level":"error","ts":1719137063.3761764,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375458773) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 10:04:23 sciabarra0 caddy[58868]: {"level":"error","ts":1719137063.3769991,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375458773) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":7,"retrying_in":600,"elapsed":1806.553733656,"max_duration":2592000}
Jun 23 10:14:23 sciabarra0 caddy[58868]: {"level":"info","ts":1719137663.3783538,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 10:14:23 sciabarra0 caddy[58868]: {"level":"info","ts":1719137663.3807352,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 10:14:24 sciabarra0 caddy[58868]: {"level":"info","ts":1719137664.2191465,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 10:14:24 sciabarra0 caddy[58868]: {"level":"error","ts":1719137664.2201085,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 10:14:24 sciabarra0 caddy[58868]: {"level":"error","ts":1719137664.3842583,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375599163) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 10:14:24 sciabarra0 caddy[58868]: {"level":"error","ts":1719137664.3854356,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375599163) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":8,"retrying_in":1200,"elapsed":2407.562169859,"max_duration":2592000}
Jun 23 10:34:24 sciabarra0 caddy[58868]: {"level":"info","ts":1719138864.3868587,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 10:34:24 sciabarra0 caddy[58868]: {"level":"info","ts":1719138864.3915083,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 10:34:25 sciabarra0 caddy[58868]: {"level":"info","ts":1719138865.2792165,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 10:34:25 sciabarra0 caddy[58868]: {"level":"error","ts":1719138865.280415,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 10:34:25 sciabarra0 caddy[58868]: {"level":"error","ts":1719138865.4570708,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375799573) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 10:34:25 sciabarra0 caddy[58868]: {"level":"error","ts":1719138865.4573488,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17375799573) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":9,"retrying_in":1200,"elapsed":3608.634082598,"max_duration":2592000}
Jun 23 10:54:25 sciabarra0 caddy[58868]: {"level":"info","ts":1719140065.4625812,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 10:54:25 sciabarra0 caddy[58868]: {"level":"info","ts":1719140065.464761,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 10:54:26 sciabarra0 caddy[58868]: {"level":"info","ts":1719140066.3572361,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 10:54:26 sciabarra0 caddy[58868]: {"level":"error","ts":1719140066.3582587,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 10:54:26 sciabarra0 caddy[58868]: {"level":"error","ts":1719140066.5326543,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17376051443) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 10:54:26 sciabarra0 caddy[58868]: {"level":"error","ts":1719140066.5327802,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17376051443) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":10,"retrying_in":1200,"elapsed":4809.709515629,"max_duration":2592000}
Jun 23 11:14:26 sciabarra0 caddy[58868]: {"level":"info","ts":1719141266.5367897,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 11:14:26 sciabarra0 caddy[58868]: {"level":"info","ts":1719141266.5389607,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 11:14:27 sciabarra0 caddy[58868]: {"level":"info","ts":1719141267.3892717,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 11:14:27 sciabarra0 caddy[58868]: {"level":"error","ts":1719141267.3905208,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 11:14:27 sciabarra0 caddy[58868]: {"level":"error","ts":1719141267.564107,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17376291233) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 11:14:27 sciabarra0 caddy[58868]: {"level":"error","ts":1719141267.5653276,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17376291233) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":11,"retrying_in":1200,"elapsed":6010.742060554,"max_duration":2592000}
Jun 23 11:34:27 sciabarra0 caddy[58868]: {"level":"info","ts":1719142467.566602,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 11:34:27 sciabarra0 caddy[58868]: {"level":"info","ts":1719142467.5692852,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 11:34:28 sciabarra0 caddy[58868]: {"level":"info","ts":1719142468.429281,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 11:34:28 sciabarra0 caddy[58868]: {"level":"error","ts":1719142468.4645402,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 11:34:28 sciabarra0 caddy[58868]: {"level":"error","ts":1719142468.6373036,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17376509893) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 11:34:28 sciabarra0 caddy[58868]: {"level":"error","ts":1719142468.6384463,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17376509893) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":12,"retrying_in":1800,"elapsed":7211.815180914,"max_duration":2592000}
Jun 23 12:04:28 sciabarra0 caddy[58868]: {"level":"info","ts":1719144268.6399853,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 12:04:28 sciabarra0 caddy[58868]: {"level":"info","ts":1719144268.6427,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 12:04:29 sciabarra0 caddy[58868]: {"level":"info","ts":1719144269.5295537,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 12:04:29 sciabarra0 caddy[58868]: {"level":"error","ts":1719144269.5308797,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 12:04:29 sciabarra0 caddy[58868]: {"level":"error","ts":1719144269.7047775,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17376896483) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 12:04:29 sciabarra0 caddy[58868]: {"level":"error","ts":1719144269.7063808,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17376896483) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":13,"retrying_in":1800,"elapsed":9012.883113573,"max_duration":2592000}
Jun 23 12:34:29 sciabarra0 caddy[58868]: {"level":"info","ts":1719146069.7078788,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 12:34:29 sciabarra0 caddy[58868]: {"level":"info","ts":1719146069.7101398,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 12:34:30 sciabarra0 caddy[58868]: {"level":"info","ts":1719146070.6098726,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 12:34:30 sciabarra0 caddy[58868]: {"level":"error","ts":1719146070.6109128,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 12:34:30 sciabarra0 caddy[58868]: {"level":"error","ts":1719146070.7841089,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17377288613) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 12:34:30 sciabarra0 caddy[58868]: {"level":"error","ts":1719146070.7852094,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17377288613) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":14,"retrying_in":1800,"elapsed":10813.961944034,"max_duration":2592000}
Jun 23 13:04:30 sciabarra0 caddy[58868]: {"level":"info","ts":1719147870.786984,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 13:04:30 sciabarra0 caddy[58868]: {"level":"info","ts":1719147870.7916336,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 13:04:31 sciabarra0 caddy[58868]: {"level":"info","ts":1719147871.5636158,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 13:04:31 sciabarra0 caddy[58868]: {"level":"error","ts":1719147871.5641541,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 13:04:31 sciabarra0 caddy[58868]: {"level":"error","ts":1719147871.7187774,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17377669903) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 13:04:31 sciabarra0 caddy[58868]: {"level":"error","ts":1719147871.7189934,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17377669903) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":15,"retrying_in":1800,"elapsed":12614.895727481,"max_duration":2592000}
Jun 23 13:34:31 sciabarra0 caddy[58868]: {"level":"info","ts":1719149671.7229235,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 13:34:31 sciabarra0 caddy[58868]: {"level":"info","ts":1719149671.7331252,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 13:34:32 sciabarra0 caddy[58868]: {"level":"info","ts":1719149672.5976446,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 13:34:32 sciabarra0 caddy[58868]: {"level":"error","ts":1719149672.6574504,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 13:34:32 sciabarra0 caddy[58868]: {"level":"error","ts":1719149672.833,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17378039793) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 13:34:32 sciabarra0 caddy[58868]: {"level":"error","ts":1719149672.8342116,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17378039793) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":16,"retrying_in":1800,"elapsed":14416.010946641,"max_duration":2592000}
Jun 23 14:04:32 sciabarra0 caddy[58868]: {"level":"info","ts":1719151472.8352838,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 14:04:32 sciabarra0 caddy[58868]: {"level":"info","ts":1719151472.8406792,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 14:04:33 sciabarra0 caddy[58868]: {"level":"info","ts":1719151473.7312894,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 14:04:33 sciabarra0 caddy[58868]: {"level":"error","ts":1719151473.7320454,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 14:04:33 sciabarra0 caddy[58868]: {"level":"error","ts":1719151473.9086223,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17378403793) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 14:04:33 sciabarra0 caddy[58868]: {"level":"error","ts":1719151473.908844,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17378403793) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":17,"retrying_in":1800,"elapsed":16217.085579086,"max_duration":2592000}
Jun 23 14:34:33 sciabarra0 caddy[58868]: {"level":"info","ts":1719153273.9106653,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 14:34:33 sciabarra0 caddy[58868]: {"level":"info","ts":1719153273.9137528,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 14:34:34 sciabarra0 caddy[58868]: {"level":"info","ts":1719153274.7603877,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 14:34:34 sciabarra0 caddy[58868]: {"level":"error","ts":1719153274.7616694,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 14:34:34 sciabarra0 caddy[58868]: {"level":"error","ts":1719153274.9320934,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17378783813) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 14:34:34 sciabarra0 caddy[58868]: {"level":"error","ts":1719153274.9322398,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17378783813) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":18,"retrying_in":3600,"elapsed":18018.108974889,"max_duration":2592000}
Jun 23 15:34:17 sciabarra0 caddy[58868]: {"level":"info","ts":1719156857.2591696,"logger":"tls.issuance.acme.acme_client","msg":"got renewal info","names":["sciabarra.nuvtest.net"],"window_start":1724229957.3333333,"window_end":1724402757.3333333,"selected_time":1724392032,"recheck_after":1719178457.259124,"explanation_url":""}
Jun 23 15:34:17 sciabarra0 caddy[58868]: {"level":"info","ts":1719156857.2609308,"logger":"tls.cache.maintenance","msg":"updated ACME renewal information","identifiers":["sciabarra.nuvtest.net"],"cert_hash":"c30052ca1cf30dd47d1a7bc8a9d407c5e67b835ec676c25b209629835aca5433","ari_unique_id":"kydGmAOpUWiOmNbEQkjbI79YlNI.BFB96_IgYeYzq6P9sUVkVtvt","cert_expiry":1726907157,"selected_time":1724346572,"next_update":1719178457.259124,"explanation_url":""}
Jun 23 15:34:34 sciabarra0 caddy[58868]: {"level":"info","ts":1719156874.9336612,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 15:34:34 sciabarra0 caddy[58868]: {"level":"info","ts":1719156874.935682,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 15:34:35 sciabarra0 caddy[58868]: {"level":"info","ts":1719156875.8061514,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 15:34:35 sciabarra0 caddy[58868]: {"level":"error","ts":1719156875.8666105,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 15:34:36 sciabarra0 caddy[58868]: {"level":"error","ts":1719156876.0379732,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17379566873) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 15:34:36 sciabarra0 caddy[58868]: {"level":"error","ts":1719156876.0381427,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17379566873) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":19,"retrying_in":3600,"elapsed":21619.214878428,"max_duration":2592000}
Jun 23 16:34:36 sciabarra0 caddy[58868]: {"level":"info","ts":1719160476.03911,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 16:34:36 sciabarra0 caddy[58868]: {"level":"info","ts":1719160476.0413904,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 16:34:36 sciabarra0 caddy[58868]: {"level":"info","ts":1719160476.9104,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 16:34:36 sciabarra0 caddy[58868]: {"level":"error","ts":1719160476.9113076,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 16:34:37 sciabarra0 caddy[58868]: {"level":"error","ts":1719160477.082484,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17380295953) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 16:34:37 sciabarra0 caddy[58868]: {"level":"error","ts":1719160477.0836828,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17380295953) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":20,"retrying_in":3600,"elapsed":25220.260416429,"max_duration":2592000}
Jun 23 17:34:37 sciabarra0 caddy[58868]: {"level":"info","ts":1719164077.0879276,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"*.sciabarra.nuvtest.net"}
Jun 23 17:34:37 sciabarra0 caddy[58868]: {"level":"info","ts":1719164077.1001077,"logger":"tls.issuance.acme","msg":"using ACME account","account_id":"https://acme-staging-v02.api.letsencrypt.org/acme/acct/153178293","account_contact":["mailto:michele@nuvolaris.io"]}
Jun 23 17:34:37 sciabarra0 caddy[58868]: {"level":"info","ts":1719164077.9751537,"logger":"tls.issuance.acme.acme_client","msg":"trying to solve challenge","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Jun 23 17:34:38 sciabarra0 caddy[58868]: {"level":"error","ts":1719164078.015837,"logger":"tls.issuance.acme.acme_client","msg":"cleaning up solver","identifier":"*.sciabarra.nuvtest.net","challenge_type":"dns-01","error":"no memory of presenting a DNS record for \"_acme-challenge.sciabarra.nuvtest.net\" (usually OK if presenting also failed)"}
Jun 23 17:34:38 sciabarra0 caddy[58868]: {"level":"error","ts":1719164078.1897461,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"*.sciabarra.nuvtest.net","issuer":"acme-v02.api.letsencrypt.org-directory","error":"[*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17381023173) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)"}
Jun 23 17:34:38 sciabarra0 caddy[58868]: {"level":"error","ts":1719164078.1898737,"logger":"tls.obtain","msg":"will retry","error":"[*.sciabarra.nuvtest.net] Obtain: [*.sciabarra.nuvtest.net] solving challenges: presenting for challenge: adding temporary record for zone \"sciabarra.nuvtest.net.\": not found, ResolveEndpointV2 (order=https://acme-staging-v02.api.letsencrypt.org/acme/order/153178293/17381023173) (ca=https://acme-staging-v02.api.letsencrypt.org/directory)","attempt":21,"retrying_in":7200,"elapsed":28821.366609245,"max_duration":2592000}
Actually I tried both to use the the libdns plugin for and to change the adapter that is super simple: https://github.com/sciabarracom/route53: it does nothing more than copying the values in the libdns.
I tried hard to debug even the caddy code and found from here:
to here:
It is missing the whole processing.
I cannot track down the details of the caddy fully but look at the code, with debugging triggered we should see the logger.Debug("creating DNS record",
and we don’t, so something happens in the middle and never reaches the Present line.
I suspect it is related to the dns or the fact it is a subzone but I am unable to track further…
as a follow up I made the system to work
first thing I had to increate the wait time otherwise you do not get any error
then finally an error showed up and it was about a missing zone, so the problem was solved adding also the zone to the the configuration
