Tri-state switch partially working
v2.4.0-beta.1.0.20210303171231-51f35ba03f78 h1:AoU1dxGv/75/Uw5LT+tNbVWvMPl6QSbCGkqeu/SQxJY=
FreeNAS 11.3 (a FreeBSD derivative)
service caddy start
n/a
Caddyfile Excerpt 1:
udance.com.au www.udance.com.au {
  import logging udance
  import authproxy /phpmyadmin*
  map {path} {backend} {online} {
#   PATH                BACKEND          ONLINE
    ~^/tautulli.*       10.1.1.26:8181   yes
    ~^/transmission.*   10.1.1.28:9091   yes
    ~^/.*               10.1.1.55:80     split
# Offline handling
  @offline expression `{online} == "no"`
  handle @offline {
    redir https://udance.statuspage.io temporary
  @split {
    expression `{online} == "split"`
    not remote_ip 10.1.1.0/24 10.1.2.0/24
  handle @split {
  reverse_proxy {backend}
Caddyfile Excerpt 2
(online) {
  @offline expression `"{args.0}" == "no"`
  handle @offline {
  @split {
    expression `"{args.0}" == "split"`
  handle @split {
www.xenografix.com.au, xenografix.com.au {
  import logging xenografix
  import online split
  reverse_proxy http://10.1.1.52
For completeness, here’s the top of the Caddyfile referring to other snippets used::
  email basil.hendroff@udance.com.au
  acme_dns cloudflare [REDACTED]
#  debug
(authproxy) {
  basicauth {args.0} {
    admin [REDACTED]
(logging) {
    format json
    output file /var/log/caddy/{args.0}.log {
      roll_keep 7
What I’m trying to do is create a tri-state switch:
online = {yes|no|split}
yes = site is online
no = site is offline
split = site in online on the local network, but offline from the internet.
Excerpt 1 works as expected; udance.com.au is available on the local network, but redirects when accessed from the internet.
Excerpt 2, which implements similar filters isn’t working though with import online split behaving the same as import online no.
For the local test, I used Chrome on a Windows 10 laptop connected to the WLAN. For the remote test, I used Chrome on an Android phone to access the sites via the internet.
Note: Existing logs were renamed and then Caddy restarted to generate fresh logs.
Caddy startup - cat /var/log/caddy.log
{"level":"info","ts":1616267232.7871149,"msg":"using provided configuration","config_file":"/usr/local/www/Caddyfile","config_adapter":"caddyfile"}
[WARNING][caddyfile] /usr/local/www/Caddyfile:2: input is not formatted with 'caddy fmt'
{"level":"info","ts":1616267232.8046198,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["localhost:2019","[::1]:2019","127.0.0.1:2019"]}
{"level":"info","ts":1616267232.8054595,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0003b8000"}
{"level":"info","ts":1616267232.8057923,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies;adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"info","ts":1616267232.8058767,"logger":"http","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}{"level":"info","ts":1616267245.6217442,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["www.xenografix.com.au","*.udance.com.au","caffigoalkeeping.com.au","readymcgetty.com.au","www.udance.com.au","xenografix.com.au","udance.com.au","www.caffigoalkeeping.com","caffigoalkeeping.com","www.caffigoalkeeping.com.au","www.readymcgetty.com.au"]}
{"level":"info","ts":1616267245.6490731,"logger":"tls","msg":"cleaned up storage units"}
{"level":"info","ts":1616267245.6790078,"msg":"autosaved config (load with --resume flag)","file":"/.config/caddy/autosave.json"}
{"level":"info","ts":1616267245.6790645,"msg":"serving initial configuration"}
Successfully started Caddy (pid=37423) - Caddy is running in the background
xenografix access log - cat/var/log/caddy/xenografix.log
{"level":"info","ts":1616267269.161587,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_addr":"162.158.2.216:46348","proto":"HTTP/1.1","method":"GET","host":"xenografix.com.au","uri":"/","headers":{"X-Forwarded-For":["124.171.242.68"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Sec-Ch-Ua-Mobile":["?0"],"Referer":["https://heimdall.udance.com.au/"],"Accept-Language":["en-AU,en-GB;q=0.9,en-US;q=0.8,en;q=0.7"],"Cookie":["__cfduid=de0759ee8c2360785ded23e4a3aa648271615617163"],"Cdn-Loop":["cloudflare"],"Cf-Ray":["633139bf781efe91-MEL"],"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36(KHTML, like Gecko) Chrome/89.0.4389.90 Safari/537.36"],"Sec-Fetch-Mode":["navigate"],"Cf-Request-Id":["08f2a26bac0000fe914c14c000000001"],"Connection":["Keep-Alive"],"Cf-Ipcountry":["AU"],"X-Forwarded-Proto":["https"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"89\", \"Chromium\";v=\"89\", \";Not A Brand\";v=\"99\""],"Sec-Fetch-Site":["cross-site"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"Accept-Encoding":["gzip"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Gpc":["1"],"Cf-Connecting-Ip":["124.171.242.68"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"xenografix.com.au"}},"common_log":"162.158.2.216 - - [21/Mar/2021:03:07:49 +0800] \"GET / HTTP/1.1\" 302 0","duration":0.00027509,"size":0,"status":302,"resp_headers":{"Server":["Caddy"],"Location":["https://udance.statuspage.io"],"Content-Type":[]}}
{"level":"info","ts":1616267296.0448396,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_addr":"162.158.165.236:10206","proto":"HTTP/1.1","method":"GET","host":"xenografix.com.au","uri":"/","headers":{"Sec-Ch-Ua-Mobile":["?1"],"Sec-Fetch-User":["?1"],"Connection":["Keep-Alive"],"Accept-Encoding":["gzip"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Cookie":["__cfduid=d82e38c6d5080847a3ec13ba0c189d3431614608414"],"Cdn-Loop":["cloudflare"],"Cf-Request-Id":["08f2a2d49a00005641ec2aa000000001"],"Cf-Ray":["63313a675c3a5641-SIN"],"Save-Data":["on"],"User-Agent":["Mozilla/5.0 (Linux; Android 11; Pixel 3 XL) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/89.0.4389.90 Mobile Safari/537.36"],"Sec-Fetch-Dest":["document"],"Sec-Fetch-Site":["none"],"Cf-Connecting-Ip":["49.196.25.226"],"Cf-Ipcountry":["AU"],"X-Forwarded-Proto":["https"],"Upgrade-Insecure-Requests":["1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"X-Forwarded-For":["49.196.25.226"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"89\", \"Chromium\";v=\"89\", \";Not A Brand\";v=\"99\""],"Sec-Fetch-Mode":["navigate"],"Accept-Language":["en-AU,en-GB;q=0.9,en-US;q=0.8,en;q=0.7"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"xenografix.com.au"}},"common_log":"162.158.165.236 - -[21/Mar/2021:03:08:16 +0800] \"GET / HTTP/1.1\" 302 0","duration":0.000202319,"size":0,"status":302,"resp_headers":{"Server":["Caddy"],"Location":["https://udance.statuspage.io"],"Content-Type":[]}}
{"level":"info","ts":1616267340.206511,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_addr":"162.158.79.217:54200","proto":"HTTP/1.1","method":"HEAD","host":"xenografix.com.au","uri":"/","headers":{"Cf-Visitor":["{\"scheme\":\"https\"}"],"Connection":["Keep-Alive"],"Accept-Encoding":["gzip"],"Cf-Ipcountry":["US"],"Cf-Ray":["63313b780af52ab8-IAD"],"X-Forwarded-Proto":["https"],"Cf-Request-Id":["08f2a37f0800002ab8de18d000000001"],"X-Forwarded-For":["192.0.101.226"],"User-Agent":["jetmon/1.0 (Jetpack Site Uptime Monitor by WordPress.com)"],"Cf-Connecting-Ip":["192.0.101.226"],"Cdn-Loop":["cloudflare"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"xenografix.com.au"}},"common_log":"162.158.79.217 - - [21/Mar/2021:03:09:00 +0800] \"HEAD / HTTP/1.1\" 302 0","duration":0.000292583,"size":0,"status":302,"resp_headers":{"Server":["Caddy"],"Location":["https://udance.statuspage.io"],"Content-Type":[]}}
{"level":"info","ts":1616267816.2887716,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_addr":"162.158.78.160:15970","proto":"HTTP/1.1","method":"HEAD","host":"xenografix.com.au","uri":"/","headers":{"X-Forwarded-Proto":["https"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"User-Agent":["jetmon/1.0 (Jetpack Site Uptime Monitor by WordPress.com)"],"Cf-Connecting-Ip":["192.0.101.226"],"Accept-Encoding":["gzip"],"Cf-Ipcountry":["US"],"Cf-Ray":["633147178d1a2769-IAD"],"Cf-Request-Id":["08f2aac2b400002769b503c000000001"],"Connection":["Keep-Alive"],"X-Forwarded-For":["192.0.101.226"],"Cdn-Loop":["cloudflare"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"xenografix.com.au"}},"common_log":"162.158.78.160 - - [21/Mar/2021:03:16:56 +0800] \"HEAD / HTTP/1.1\" 302 0","duration":0.000241915,"size":0,"status":302,"resp_headers":{"Server":["Caddy"],"Location":["https://udance.statuspage.io"],"Content-Type":[]}}
{"level":"info","ts":1616268300.7422915,"logger":"http.log.access.log0","msg":"handled request","request":{"remote_addr":"172.69.63.19:20224","proto":"HTTP/1.1","method":"HEAD","host":"xenografix.com.au","uri":"/","headers":{"Cf-Ray":["633152eb5e3329ba-IAD"],"User-Agent":["jetmon/1.0(Jetpack Site Uptime Monitor by WordPress.com)"],"Cf-Connecting-Ip":["192.0.101.226"],"Cdn-Loop":["cloudflare"],"Connection":["Keep-Alive"],"Accept-Encoding":["gzip"],"X-Forwarded-For":["192.0.101.226"],"Cf-Request-Id":["08f2b22714000029ba042f3000000001"],"Cf-Ipcountry":["US"],"X-Forwarded-Proto":["https"],"Cf-Visitor":["{\"scheme\":\"https\"}"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"xenografix.com.au"}},"common_log":"172.69.63.19 - - [21/Mar/2021:03:25:00 +0800] \"HEAD / HTTP/1.1\" 302 0","duration":0.000147317,"size":0,"status":302,"resp_headers":{"Server":["Caddy"],"Location":["https://udance.statuspage.io"],"Content-Type":[]}}
udance access log - cat /var/log/caddy/udance.log
{"level":"info","ts":1616267260.6569395,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"10.1.1.136:64606","proto":"HTTP/2.0","method":"GET","host":"udance.com.au","uri":"/","headers":{"Referer":["https://heimdall.udance.com.au/"],"Authorization":["Basic YWRtaW46OXpTeTIjckM3Nnkq"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"89\", \"Chromium\";v=\"89\", \";Not A Brand\";v=\"99\""],"Sec-Fetch-User":["?1"],"Accept-Encoding":["gzip, deflate, br"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64)AppleWebKit/537.36 (KHTML, like Gecko) Chrome/89.0.4389.90 Safari/537.36"],"Sec-Fetch-Mode":["navigate"],"Cookie":["tk_or=%22https%3A%2F%2Fheimdall.udance.com.au%2F%22; __cfduid=d53583b316fd49796179aa61c11c12eb31615662656;jetpack_sso_wpcom_name_01ad53d5bf4f84d52a16c29bd439eb90=Basil%20Hendroff; jetpack_sso_wpcom_gravatar_01ad53d5bf4f84d52a16c29bd439eb90=https%3A%2F%2Fsecure.gravatar.com%2Favatar%2Fa6745e3de67b8d1898c9baf02b351786%3Fs%3D144%26d%3Dmm%26r%3Dg;wp-settings-1=libraryContent%3Dbrowse; wp-settings-time-1=1616215887; mailchimp_landing_site=https%3A%2F%2Fudance.com.au%2Fwp-json%2Fjetpack%2Fv4%2Fjitm%3Fmessage_path%3Dwp%253Adashboard%253Aadmin_notices%26query%3D%26full_jp_logo_exists%3Dfalse%26_wpnonce%3D70e17c2ae7;tk_r3d=%22https%3A%2F%2Fheimdall.udance.com.au%2F%22; tk_lr=%22%22"],"Sec-Gpc":["1"],"Sec-Ch-Ua-Mobile":["?0"],"Accept-Language":["en-AU,en-GB;q=0.9,en-US;q=0.8,en;q=0.7"],"Sec-Fetch-Site":["same-site"],"Sec-Fetch-Dest":["document"],"Upgrade-Insecure-Requests":["1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"udance.com.au"}},"common_log":"10.1.1.136 - - [21/Mar/2021:03:07:40 +0800] \"GET / HTTP/2.0\" 200 8936","duration":0.966044241,"size":8936,"status":200,"resp_headers":{"Date":["Sat, 20 Mar 2021 19:07:40 GMT"],"Server":["Caddy","Caddy"],"Content-Encoding":["gzip"],"Content-Type":["text/html; charset=UTF-8"],"Vary":["Accept-Encoding, Cookie","Accept-Encoding"],"X-Powered-By":["PHP/7.4.15"],"Cache-Control":["max-age=3, must-revalidate"]}}
{"level":"info","ts":1616267266.4529192,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"10.1.1.136:64606","proto":"HTTP/2.0","method":"POST","host":"udance.com.au","uri":"/?wc-ajax=get_refreshed_fragments","headers":{"Sec-Ch-Ua-Mobile":["?0"],"Origin":["https://udance.com.au"],"Sec-Gpc":["1"],"Sec-Fetch-Dest":["empty"],"Referer":["https://udance.com.au/"],"Accept":["*/*"],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/89.0.4389.90 Safari/537.36"],"Sec-Fetch-Mode":["cors"],"Authorization":["Basic YWRtaW46OXpTeTIjckM3Nnkq"],"X-Requested-With":["XMLHttpRequest"],"Accept-Language":["en-AU,en-GB;q=0.9,en-US;q=0.8,en;q=0.7"],"Sec-Fetch-Site":["same-origin"],"Accept-Encoding":["gzip, deflate, br"],"Cookie":["tk_or=%22https%3A%2F%2Fheimdall.udance.com.au%2F%22; __cfduid=d53583b316fd49796179aa61c11c12eb31615662656; jetpack_sso_wpcom_name_01ad53d5bf4f84d52a16c29bd439eb90=Basil%20Hendroff; jetpack_sso_wpcom_gravatar_01ad53d5bf4f84d52a16c29bd439eb90=https%3A%2F%2Fsecure.gravatar.com%2Favatar%2Fa6745e3de67b8d1898c9baf02b351786%3Fs%3D144%26d%3Dmm%26r%3Dg; wp-settings-1=libraryContent%3Dbrowse; wp-settings-time-1=1616215887; mailchimp_landing_site=https%3A%2F%2Fudance.com.au%2Fwp-json%2Fjetpack%2Fv4%2Fjitm%3Fmessage_path%3Dwp%253Adashboard%253Aadmin_notices%26query%3D%26full_jp_logo_exists%3Dfalse%26_wpnonce%3D70e17c2ae7; tk_r3d=%22https%3A%2F%2Fheimdall.udance.com.au%2F%22; tk_lr=%22https%3A%2F%2Fheimdall.udance.com.au%2F%22"],"Content-Length":["18"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"89\", \"Chromium\";v=\"89\", \";Not A Brand\";v=\"99\""],"Content-Type":["application/x-www-form-urlencoded; charset=UTF-8"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"udance.com.au"}},"common_log":"10.1.1.136 - - [21/Mar/2021:03:07:46 +0800] \"POST /?wc-ajax=get_refreshed_fragments HTTP/2.0\" 0 0","duration":5.013002729,"size":0,"status":0,"resp_headers":{"Server":["Caddy"]}}
{"level":"info","ts":1616267268.527062,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"10.1.1.55:51867","proto":"HTTP/1.1","method":"POST","host":"udance.com.au","uri":"/wp-cron.php?doing_wp_cron=1616267268.3857491016387939453125","headers":{"User-Agent":["WordPress/5.7; https://udance.com.au"],"Accept":["*/*"],"Accept-Encoding":["deflate, gzip"],"Referer":["https://udance.com.au/wp-cron.php?doing_wp_cron=1616267268.3857491016387939453125"],"Connection":["close"],"Content-Length":["0"],"Content-Type":["application/x-www-form-urlencoded"]},"tls":{"resumed":false,"version":771,"cipher_suite":49196,"proto":"http/1.1","proto_mutual":true,"server_name":"udance.com.au"}},"common_log":"10.1.1.55 - - [21/Mar/2021:03:07:48 +0800] \"POST /wp-cron.php?doing_wp_cron=1616267268.3857491016387939453125HTTP/1.1\" 200 0","duration":0.101429248,"size":0,"status":200,"resp_headers":{"Server":["Caddy","Caddy"],"Content-Length":["0"],"Cache-Control":["no-cache, must-revalidate, max-age=0"],"Content-Type":["text/html; charset=UTF-8"],"Expires":["Wed, 11 Jan 1984 05:00:00 GMT"],"X-Powered-By":["PHP/7.4.15"],"Date":["Sat, 20 Mar 2021 19:07:48 GMT"]}}
{"level":"info","ts":1616267268.5517943,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"10.1.1.136:64606","proto":"HTTP/2.0","method":"GET","host":"udance.com.au","uri":"/favicon.ico","headers":{"Cookie":["tk_or=%22https%3A%2F%2Fheimdall.udance.com.au%2F%22; __cfduid=d53583b316fd49796179aa61c11c12eb31615662656; jetpack_sso_wpcom_name_01ad53d5bf4f84d52a16c29bd439eb90=Basil%20Hendroff;jetpack_sso_wpcom_gravatar_01ad53d5bf4f84d52a16c29bd439eb90=https%3A%2F%2Fsecure.gravatar.com%2Favatar%2Fa6745e3de67b8d1898c9baf02b351786%3Fs%3D144%26d%3Dmm%26r%3Dg; wp-settings-1=libraryContent%3Dbrowse; wp-settings-time-1=1616215887; mailchimp_landing_site=https%3A%2F%2Fudance.com.au%2Fwp-json%2Fjetpack%2Fv4%2Fjitm%3Fmessage_path%3Dwp%253Adashboard%253Aadmin_notices%26query%3D%26full_jp_logo_exists%3Dfalse%26_wpnonce%3D70e17c2ae7; tk_r3d=%22https%3A%2F%2Fheimdall.udance.com.au%2F%22; tk_lr=%22https%3A%2F%2Fheimdall.udance.com.au%2F%22"],"Sec-Gpc":["1"],"Authorization":["Basic YWRtaW46OXpTeTIjckM3Nnkq"],"Sec-Ch-Ua-Mobile":["?0"],"Accept":["image/avif,image/webp,image/apng,image/svg+xml,image/*,*/*;q=0.8"],"Accept-Language":["en-AU,en-GB;q=0.9,en-US;q=0.8,en;q=0.7"],"Sec-Fetch-Dest":["image"],"Referer":["https://udance.com.au/"],"Accept-Encoding":["gzip, deflate, br"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"89\", \"Chromium\";v=\"89\", \";Not A Brand\";v=\"99\""],"User-Agent":["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/89.0.4389.90 Safari/537.36"],"Sec-Fetch-Site":["same-origin"],"Sec-Fetch-Mode":["no-cors"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"udance.com.au"}},"common_log":"10.1.1.136 - - [21/Mar/2021:03:07:48 +0800] \"GET /favicon.ico HTTP/2.0\"302 0","duration":6.963537804,"size":0,"status":302,"resp_headers":{"Date":["Sat, 20 Mar 2021 19:07:48 GMT"],"Content-Length":["0"],"X-Redirect-By":["WordPress"],"Link":["<https://udance.com.au/wp-json/>; rel=\"https://api.w.org/\""],"X-Powered-By":["PHP/7.4.15"],"Server":["Caddy","Caddy"],"Content-Type":["text/html; charset=UTF-8"],"Location":["https://udance.com.au/wp-includes/images/w-logo-blue-white-bg.png"],"Status":["302 Found"],"Vary":["Accept-Encoding, Cookie"]}}
{"level":"info","ts":1616267268.6475754,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"10.1.1.55:44343","proto":"HTTP/1.1","method":"POST","host":"udance.com.au","uri":"/wp-cron.php?doing_wp_cron=1616267268.3856561183929443359375","headers":{"Referer":["https://udance.com.au/wp-cron.php?doing_wp_cron=1616267268.3856561183929443359375"],"Connection":["close"],"Content-Length":["0"],"Content-Type":["application/x-www-form-urlencoded"],"User-Agent":["WordPress/5.7; https://udance.com.au"],"Accept":["*/*"],"Accept-Encoding":["deflate, gzip"]},"tls":{"resumed":false,"version":771,"cipher_suite":49196,"proto":"http/1.1","proto_mutual":true,"server_name":"udance.com.au"}},"common_log":"10.1.1.55 - - [21/Mar/2021:03:07:48 +0800] \"POST /wp-cron.php?doing_wp_cron=1616267268.3856561183929443359375 HTTP/1.1\" 200 0","duration":0.203968024,"size":0,"status":200,"resp_headers":{"Expires":["Wed, 11 Jan 198405:00:00 GMT"],"X-Powered-By":["PHP/7.4.15"],"Date":["Sat, 20 Mar 2021 19:07:48 GMT"],"Content-Length":["0"],"Server":["Caddy","Caddy"],"Cache-Control":["no-cache, must-revalidate, max-age=0"],"Content-Type":["text/html; charset=UTF-8"]}}
{"level":"info","ts":1616267283.5129042,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"172.69.134.177:33176","proto":"HTTP/1.1","method":"GET","host":"udance.com.au","uri":"/","headers":{"X-Forwarded-Proto":["https"],"Sec-Ch-Ua-Mobile":["?1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Purpose":["prefetch"],"Sec-Fetch-Site":["none"],"Cf-Connecting-Ip":["49.196.25.226"],"Accept-Encoding":["gzip"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Sec-Ch-Ua":["\"Google Chrome\";v=\"89\", \"Chromium\";v=\"89\", \";Not A Brand\";v=\"99\""],"Upgrade-Insecure-Requests":["1"],"Sec-Fetch-Mode":["navigate"],"Cookie":["remember_web_59ba36addc2b2f9401580f014c7f58ea4e30989d=eyJpdiI6Ill1eFAyM3BjbUxoNE5Bclo3THFSNGc9PSIsInZhbHVlIjoidmwwQ09wMlZ4UFhwUVFmZk91aWdya1cwaXdMaUp5akhYNmNrNmlscktCVkg3NzBTdUpEcEU2elZQR3plYUJCUlFBeDhOa1JETGtNUkN0V2ZlNDMydVdUdmFVV1NRK1dJK29rZEg2NU5sK2ZzdWJONVlJdGE5WTNYTnkwZnY5RzNoR1VzZVJjbk5xS0JDMFQyTUQ0SW5JaVo3cm82dHN0Y1wvZVM3VGF3dlVVVT0iLCJtYWMiOiI2Njk0ZWFmOGYwMDk2YmQ0NjdjZTg2NzVhNzJmNWRkMDI1YjRiNjU2ZmVmNGNiNjQ5ZjUwYWY4N2MyMTZhOGYwIn0%3D; tk_or=%22%22; tk_lr=%22%22; __cfduid=d83da845010722cacda30a640f07cc43e1615636239;tk_r3d=%22%22"],"Cdn-Loop":["cloudflare"],"Cf-Ray":["63313a1908ef18ca-SIN"],"Connection":["Keep-Alive"],"X-Forwarded-For":["49.196.25.226"],"User-Agent":["Mozilla/5.0 (Linux; Android 11; Pixel 3 XL) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/89.0.4389.90 Mobile Safari/537.36"],"Sec-Fetch-User":["?1"],"Cf-Request-Id":["08f2a2a3a5000018caf0254000000001"],"Save-Data":["on"],"Sec-Fetch-Dest":["document"],"Accept-Language":["en-AU,en-GB;q=0.9,en-US;q=0.8,en;q=0.7"],"Cf-Ipcountry":["AU"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"udance.com.au"}},"common_log":"172.69.134.177 - - [21/Mar/2021:03:08:03 +0800] \"GET / HTTP/1.1\"302 0","duration":0.000246931,"size":0,"status":302,"resp_headers":{"Server":["Caddy"],"Location":["https://udance.statuspage.io"],"Content-Type":[]}}
{"level":"info","ts":1616267617.8977606,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"162.158.62.75:47824","proto":"HTTP/1.1","method":"HEAD","host":"udance.com.au","uri":"/","headers":{"User-Agent":["jetmon/1.0 (Jetpack Site Uptime Monitor byWordPress.com)"],"Cf-Request-Id":["08f2a7bbb0000055666b3a5000000001"],"Connection":["Keep-Alive"],"Accept-Encoding":["gzip"],"X-Forwarded-Proto":["https"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Cf-Connecting-Ip":["192.0.102.40"],"Cdn-Loop":["cloudflare"],"Cf-Ipcountry":["US"],"X-Forwarded-For":["192.0.102.40"],"Cf-Ray":["6331423f78625566-EWR"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"udance.com.au"}},"common_log":"162.158.62.75 - - [21/Mar/2021:03:13:37 +0800] \"HEAD / HTTP/1.1\" 302 0","duration":0.000386336,"size":0,"status":302,"resp_headers":{"Server":["Caddy"],"Location":["https://udance.statuspage.io"],"Content-Type":[]}}
{"level":"info","ts":1616268098.9600768,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"173.245.52.65:17154","proto":"HTTP/1.1","method":"HEAD","host":"udance.com.au","uri":"/","headers":{"Connection":["Keep-Alive"],"Accept-Encoding":["gzip"],"X-Forwarded-For":["192.0.102.40"],"Cf-Connecting-Ip":["192.0.102.40"],"Cdn-Loop":["cloudflare"],"Cf-Request-Id":["08f2af12ce0000f005c2220000000001"],"Cf-Ipcountry":["US"],"Cf-Ray":["63314dfe1bccf005-EWR"],"X-Forwarded-Proto":["https"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"User-Agent":["jetmon/1.0 (Jetpack Site Uptime Monitor by WordPress.com)"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"udance.com.au"}},"common_log":"173.245.52.65 - - [21/Mar/2021:03:21:38 +0800] \"HEAD / HTTP/1.1\" 302 0","duration":0.000291197,"size":0,"status":302,"resp_headers":{"Location":["https://udance.statuspage.io"],"Content-Type":[],"Server":["Caddy"]}}
{"level":"info","ts":1616268539.6450713,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"162.158.62.229:39650","proto":"HTTP/1.1","method":"HEAD","host":"udance.com.au","uri":"/","headers":{"Connection":["Keep-Alive"],"Accept-Encoding":["gzip"],"Cf-Ipcountry":["US"],"X-Forwarded-For":["192.0.102.40"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"User-Agent":["jetmon/1.0(Jetpack Site Uptime Monitor by WordPress.com)"],"Cdn-Loop":["cloudflare"],"Cf-Request-Id":["08f2b5cc420000f03d021bc000000001"],"Cf-Ray":["633158c06c85f03d-EWR"],"X-Forwarded-Proto":["https"],"Cf-Connecting-Ip":["192.0.102.40"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"udance.com.au"}},"common_log":"162.158.62.229 - - [21/Mar/2021:03:28:59+0800] \"HEAD / HTTP/1.1\" 302 0","duration":0.000322037,"size":0,"status":302,"resp_headers":{"Server":["Caddy"],"Location":["https://udance.statuspage.io"],"Content-Type":[]}}
{"level":"info","ts":1616268678.8744345,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"172.69.33.85:31366","proto":"HTTP/1.1","method":"POST","host":"udance.com.au","uri":"/wp-login.php","headers":{"Connection":["Keep-Alive"],"X-Forwarded-For":["69.12.66.251"],"Cf-Request-Id":["08f2b7ecb1000042b748b17000000001"],"Cf-Ipcountry":["US"],"User-Agent":["Mozilla/5.0 (Windows NT 6.1; WOW64)AppleWebKit/537.36 (KHTML, like Gecko) Chrome/41.0.2272.101 Safari/537.36"],"Content-Type":["application/x-www-form-urlencoded"],"Cookie":["wordpress_test_cookie=WP+Cookie+check"],"Cf-Connecting-Ip":["69.12.66.251"],"Cdn-Loop":["cloudflare"],"Accept-Encoding":["gzip"],"Cf-Ray":["63315c278bf142b7-LAX"],"Content-Length":["94"],"X-Forwarded-Proto":["https"],"Cf-Visitor":["{\"scheme\":\"https\"}"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"udance.com.au"}},"common_log":"172.69.33.85 - -[21/Mar/2021:03:31:18 +0800] \"POST /wp-login.php HTTP/1.1\" 302 0","duration":0.000219143,"size":0,"status":302,"resp_headers":{"Content-Type":[],"Server":["Caddy"],"Location":["https://udance.statuspage.io"]}}
{"level":"info","ts":1616269022.8934393,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"172.69.62.31:12640","proto":"HTTP/1.1","method":"HEAD","host":"udance.com.au","uri":"/","headers":{"Accept-Encoding":["gzip"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"User-Agent":["jetmon/1.0 (Jetpack Site Uptime Monitor by WordPress.com)"],"Cdn-Loop":["cloudflare"],"Cf-Ipcountry":["US"],"X-Forwarded-For":["192.0.102.40"],"Cf-Ray":["6331648ccc8e3878-IAD"],"X-Forwarded-Proto":["https"],"Cf-Connecting-Ip":["192.0.102.40"],"Cf-Request-Id":["08f2bd2bfe00003878ef991000000001"],"Connection":["Keep-Alive"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"udance.com.au"}},"common_log":"172.69.62.31 - - [21/Mar/2021:03:37:02 +0800] \"HEAD / HTTP/1.1\" 302 0","duration":0.000232243,"size":0,"status":302,"resp_headers":{"Content-Type":[],"Server":["Caddy"],"Location":["https://udance.statuspage.io"]}}
{"level":"info","ts":1616269493.6135175,"logger":"http.log.access.log3","msg":"handled request","request":{"remote_addr":"173.245.54.211:26532","proto":"HTTP/1.1","method":"HEAD","host":"udance.com.au","uri":"/","headers":{"X-Forwarded-For":["192.0.102.40"],"Cf-Ray":["6331700ac93c3848-IAD"],"X-Forwarded-Proto":["https"],"Cf-Visitor":["{\"scheme\":\"https\"}"],"Cdn-Loop":["cloudflare"],"Cf-Request-Id":["08f2c45abf00003848c4be5000000001"],"Connection":["Keep-Alive"],"Accept-Encoding":["gzip"],"Cf-Ipcountry":["US"],"User-Agent":["jetmon/1.0 (Jetpack Site Uptime Monitor by WordPress.com)"],"Cf-Connecting-Ip":["192.0.102.40"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"","proto_mutual":true,"server_name":"udance.com.au"}},"common_log":"173.245.54.211 - - [21/Mar/2021:03:44:53 +0800]\"HEAD / HTTP/1.1\" 302 0","duration":0.000325979,"size":0,"status":302,"resp_headers":{"Content-Type":[],"Server":["Caddy"],"Location":["https://udance.statuspage.io"]}}
I’m not sure there’s anything wrong with the filters. What I did notice is that there’s evidence of local access in the udance access log, but none in the xenografix log. This, I’m not able to explain.
  1. Using Caddy for incident management in a home network
I’m confused. The caddy adapt output for your example with the import looks fine:
"expression": "\"split\" == \"no\""
"expression": "\"split\" == \"split\""
:thinking:
I know, right! It’s weird.
Here’s selected output from caddy adapt --pretty for Excerpt 2:
                                                        "match": [
        "host": [
        "xenografix.com.au"
                                                        "handle": [
        "handler": "subroute",
        "routes": [
        "handle": [
        "handler": "authentication",
        "providers": {
        "http_basic": {
        "accounts": [
        "password": [REDACTED},
        "username": "admin"
        "hash": {
        "algorithm": "bcrypt"
        "hash_cache": {}
        "match": [
        "path": [
        "/phpmyadmin*"
        "handle": [
        "encodings": {
        "gzip": {}
        "handler": "encode"
        "group": "group11",
        "handle": [
        "routes": [
        "handle": [
        "handler": "static_response",
        "headers": {
        "Location": [
        "status_code": 302
        "match": [
        "group": "group11",
        "handle": [
        "routes": [
        "handle": [
        "headers": {
        "Location": [
        "status_code": 302
        "match": [
        "expression": "\"split\" == \"split\"",
        "not": [
        "remote_ip": {
        "ranges": [
        "10.1.1.0/24",
        "10.1.2.0/24"
        "handle": [
        "handler": "reverse_proxy",
        "upstreams": [
        "dial": "10.1.1.52:80"
                                                        "terminal": true
For comparison, here’s selected output from caddy adapt --pretty for Excerpt 1.
                                                        "match": [
        "host": [
        "udance.com.au",
        "www.udance.com.au"
                                                        "handle": [
        "routes": [
        "handle": [
        "destinations": [
        "{backend}",
        "{online}"
        "handler": "map",
        "mappings": [
        "input_regexp": "^/tautulli.*",
        "outputs": [
        "10.1.1.26:8181",
        "yes"
        "input_regexp": "^/transmission.*",
        "outputs": [
        "10.1.1.28:9091",
        "yes"
        "input_regexp": "^/.*",
        "outputs": [
        "10.1.1.55:80",
        "split"
        "source": "{http.request.uri.path}"
        "handle": [
        "providers": {
        "http_basic": {
        "accounts": [
        "password": [REDACTED],
        "username": "admin"
        "hash": {
        "hash_cache": {}
        "match": [
        "path": [
        "/phpmyadmin*"
        "handle": [
        "encodings": {
        "gzip": {}
        "handler": "encode"
        "group": "group13",
        "handle": [
        "routes": [
        "handle": [
        "headers": {
        "Location": [
        "status_code": 302
        "match": [
        "expression": "{online} == \"no\""
        "group": "group13",
        "handle": [
        "routes": [
        "handle": [
        "headers": {
        "Location": [
        "status_code": 302
        "match": [
        "expression": "{online} == \"split\"",
        "not": [
        "remote_ip": {
        "ranges": [
        "10.1.1.0/24",
        "10.1.2.0/24"
        "handle": [
        "upstreams": [
        "dial": "{backend}"
                                                        "terminal": true
Try to reduce the problem to as minimal of a config as you can to replicate the issue. If it can be shown to be a bug with a simple reproducible case, it’ll be easier to track down where the problem is.
I’ll have to try this overnight when there’ll be minimal local traffic.
In the interim, what I did was temporarily switch back to the official Caddy release and try the online snippet there, however, the problem persisted.
# caddy version
This confirms that a bug hasn’t crept in since Caddy 2.3.0. So, this leaves three possibilities:
  1. A bug was always there. Unlikely, as someone would have stumbled across it already.
  2. I’m doing something stupid. Likely.
  3. There’s something else in the environment going on that I’m presently oblivious to. Possible.
You don’t necessarily need to try it on your live server.
I’m not sure how I would test it otherwise? :thinking: I was thinking I’d switch out the current Caddyfile with a minimal Caddyfile on the live server. I just need to do this out-of-hours. The alternative would be to change the forwarding rule and internal DNS resolver to point to a test Caddy instance. This seems more of a hassle.
Looks like the third scenario is in play here. It has something to do with how Caddy and my WordPress instances interact together. The way I confirmed it was to try the online snippet with a non-WordPress instance and it worked first time.
What’s still not clear is why Caddy and WordPress work well together where the tri-state switch uses the map directive, but will falter when the tri-state switch is implemented using the online snippet.
It was scenario 2. I feel very sheepish atm.
The issue had to do with the split-DNS. The local DNS server resolved udance,com.au to the Caddy IP, but did not do so for other supported domains e.g. xenografix.com.au. When a local device attempted to contact one of those domains, the local DNS resolver, unable to resolve the domain name, would forward the request to an external upstream DNS server, which would then return the request back into the local network. Caddy would, correctly, see the request as originating externally. Therefore, for the split filter, Caddy would always redirect as it was being presented with remote addresses. Once I defined those domains in the local DNS server, the split filter began to work as expected as requests from local devices would be sent directly to Caddy and not routed out and and back into the network.
The issue remained dormant for a long time and under ordinary circumstances caused no visible problems. It took the remote_ip matcher to bring the problem to the fore.
Glad you figured it out :smiley:
