I want to map human readable URLS that may include filesystem characters to valid HTML pages. So I create HTML files with path hashed/<hex encoded name>. There is a mapping file with the route -> hex encoded name called prettyurls in the root directory.
Most routes do not need to be mapped, only the ones with problematic characters.
prettyurls could contain eg
"/routine/==>" "/hashed/1a2b3c4d"
In the Caddyfile I have
root * /usr/share/caddy
map {path} {npath} {
import /usr/share/caddy/assets/prettyurls
try_files {npath}.html {path}.html {path}
This all works.
But now I want to send a 403 response if there is a URL /hashed/1a2b3c4d from a user. The /hashed/* routines are an internal implementation detail.
So I add the following to the Caddy file
error /hashed* 403
The problem is that the external /hashed/1a2b3c4d route is rejected (as desired) but the internal /hashed/1a2b3c4d which is generated from /routine/==> using the map directive is also rejected (not desired).
Is there a way to achieve both of these aims?
I think that somehow the mapped routes should be made internal using rewrite but its not clear to me from V2 docs how only mapped routes are made internal.
v2.6.4
docker
output stdout
error /hashed* 403
uri /type/* replace :: /
handle_errors {
@404 {
expression {http.error.status_code} == 404
@403 {
expression {http.error.status_code} == 403
rewrite @404 /404.html
rewrite @403 /403.html
