I have a use case where a bunch of data is curated by a process which uses a markdown file to describe the data, collect notes, etc. We didn’t want to compilcate that process by requiring these to be part of a complex site or use templates, CSS or any other normal things a site might do, but did like the way Apache has been silently rendering the markdown files, which I think was like the v1 markdown functionality. I found this post: Markdown support in v2 which shows a solution that looks great for a formal website, but wasn’t a good fit for our use. So starting from the examples in that post and after a dive into the docs, or given my newbie caddy status, more like a drowning person splashing around, I came up with this config:
http://:8080 {
output stderr
level DEBUG
format console
encode zstd gzip
file_server browse
root * /home/griznog/webserver
templates
@markdown path *.md
header @markdown Content-Type text/html
respond @markdown "{{ include .OriginalReq.URL.Path | markdown }}"
Two goals from posting this: first while this is working great as far as I can tell, I’d appreciate feedback if I’m doing something wrong or inefficient here. Second, I wanted to share it in case someone else is looking to restore/recreate the previous v1 markdown functionality as this might be a worthwhile starting point.
caddy is pretty awesome, a big thanks to everyone working on it!
griznog
