Translating nginx caching configuration to caddy (using caddyserver/cache-handler)
With the new 0.19.* releases of Lemmy, the server now returns proper Cache-Control headers, and it is recommended to enable caching in the reverse proxy. Here is the suggested way to do it with nginx.
I’m having a hard time finding the appropriate Caddy cache-handler directives that correspond to nginx’s.
Can someone help me translate this file, or at least point me to some good documentation (or perhaps another better-suited plugin)?
N/A
(built with xcaddy)
Docker, with the official caddy:2-alpine image.
To include cache-handler, I turned to the xcaddy example in the Docker image’s README:
FROM caddy:2-builder-alpine AS builder
RUN xcaddy build \
    --with github.com/caddyserver/cache-handler
FROM caddy:2-alpine
I do not change the command/entrypoint and just mount my caddyfile as a volume onto /etc/caddy/Caddyfile.
version: "2"
    hostname: ...
    expose:
      - ...  # this caddy is behind another wider proxy
      - ./volumes/caddy/data:/data
      - ./volumes/caddy/config:/config
    email admin@lemmy.pt
      format console
    servers {
      metrics
    http_port ...
(lemmycommon) {
        Strict-Transport-Security max-age=63072000
        # Various content security headers
        Referrer-Policy same-origin
        X-Frame-Options DENY
        # disable FLoC tracking
        Permissions-Policy interest-cohort=()
    # Enable compression for JS/CSS/HTML bundle, for improved client load times.
    # It might be nice to compress JSON, but leaving that out to protect against potential
    # compression+encryption information leak attacks like BREACH.
    @encode_mime {
        header Content-Type text/css
        header Content-Type application/javascript
        header Content-Type image/svg+xml
    encode @encode_mime gzip
    request_body {
        max_size 10MB
http://lemmy.pt {
    import lemmycommon
    @pictshare_regexp path_regexp pictshare_regexp \/pictshare\/(.*)
    redir @pictshare_regexp /pictrs/image/{re.pictshare_regexp.1} permanent
    @backend `
    path('/api/*', '/pictrs/*', '/feeds/*', '/nodeinfo/*', '/.well-known/*')
    || header({'Accept': 'application/*'})
    || method('POST')
    @backend_metrics `path('/metrics')`
    reverse_proxy @backend lemmy:8536
    reverse_proxy @backend_metrics lemmy:10002
    reverse_proxy lemmy-ui:1234
http://m.lemmy.pt {
    import lemmycommon
    reverse_proxy voyager:5314
http://old.lemmy.pt {
    import lemmycommon
    reverse_proxy mlmym:8080
http://a.lemmy.pt {
    import lemmycommon
    reverse_proxy alexandrite:3000
http://p.lemmy.pt {
    import lemmycommon
    reverse_proxy photon:3000
http://metricas.lemmy.pt {
    reverse_proxy netdata:19999
Suggested nginx config (on which I based my caddyfile)
Suggested nginx cache config
Hello @tmpod I’m on it to setup a working Caddyfile with HTTP cache.
@tmpod here is the minimal config I made to proxy and have cache on lemmy.pt
    order cache before rewrite
    cache {
        nuts {
            path ./test
localhost:80
route {
    cache {
        # Only if you want to prevent the Pragma: no-cache or the Cache-Control: no-cache being interpreted from the request headers
        mode bypass_request
    reverse_proxy https://lemmy.pt {
        header_up Origin lemmy.pt
        header_up Host lemmy.pt
I think you config may look like the following:
    cache {
        ttl 4h
        stale 24h
        nuts {
            path ./test
      format console
    servers {
      metrics
    http_port ...
(lemmycommon) {
    cache {
        mode bypass_request
    @encode_mime {
    request_body {
        max_size 10MB
http://lemmy.pt {
    import lemmycommon
    @backend `
    || method('POST')
http://m.lemmy.pt {
    import lemmycommon
    import lemmycommon
http://a.lemmy.pt {
    import lemmycommon
http://p.lemmy.pt {
    import lemmycommon
With that all your domains that import lemmycommon will use the cache directive for all routes.
With the given config the key will be considered as fresh for 4 hours, stale for 1d and won’t obey to the no-cache directive from the client.
