Translating LibrePhoto's nginx.conf
Ubuntu 20.10
paste command here
:7680 {
    reverse_proxy * :7682 {
    reverse_proxy /api/* :7681 {
        header_up Host backend
        header_up X-Real-IP {http.request.remote}
        header_up X-Forwarded-Proto {http.request.scheme}
    reverse_proxy /media/* :7681 {
    file_server /protected_media* {
        root /var/lib/librephotos/protected_media/
    file_server /original* {
        root /var/lib/librephotos/data/
    file_server /nextcloud_original* {
        root /var/lib/librephotos/data/nextcloud_media/
LibrePhotos will load but it’s not allowing access to any of the images. I think maybe I’m missing something from my translation? The given nginx.conf is linked below. I couldn’t figure out how to translate include uwsgi_params; or internal;
Mar 30 21:11:59 Yamato librephotos-backend[3428]: Forbidden: /media/avatars/avatar_9OrpE1t.png
Mar 30 21:12:10 Yamato librephotos-backend[3428]: Forbidden: /media/avatars/avatar_9OrpE1t.png
Mar 30 21:12:11 Yamato librephotos-backend[3428]: Forbidden: /media/avatars/avatar_cNj6PoI.png
I tried translating the .conf myself
https://github.com/LibrePhotos/librephotos-linux/blob/main/ressources/etc/nginx/nginx.conf
You don’t need this line, it gets set by Caddy automatically:
When looking for files on disk, Caddy takes the root then appends the current request path to it. This means that you’ll be looking in /var/lib/librephotos/protected_media/protected_media.
You can combine these with a named matcher:
@api path /api/* /media/*
reverse_proxy @api localhost:7681 {
Ok so I rewrote it as the following but I still have the same issue:
:7680 {
    reverse_proxy @api :7681 {
    handle_path /original* {
        uri strip_prefix /original
        file_server {
    handle_path /nextcloud_original* {
        uri strip_prefix /nextcloud_original
        file_server {
Oh and this:
I tried to download a Caddy executable with the NGINX adapter but it still says unrecognized. Tried to download this: https://caddyserver.com/api/download?os=linux&arch=amd64&p=github.com%2Fcaddyserver%2Fnginx-adapter&idempotency=51926895223959
And run this: ./caddy-nginx adapt --config nginx.conf --adapter nginx
I think this’ll account for internal?
:7680 {
    @protected_media {
        remote_ip 127.0.0.1
        path /protected_media*
    file_server @protected_media {
    @original {
        remote_ip 127.0.0.1
        path /original*
    handle @original {
        file_server {
    @nextcloud_original {
        remote_ip 127.0.0.1
    handle @nextcloud_original {
        file_server {
Edit: This doesn’t work
Edit^2: It does work I’m just an idiot. Was testing from my server with its LAN IP. It worked with localhost
I tried accessing :7680 via localhost but that didn’t work.
Oh that isn’t what internal means- Content-disposition and internal (nginx to caddy) - #8 by lecris
@francislavoie Would I be able to set up a NGINX server alongside caddy and have Caddy redirect to it?
Yes, run it on a specific port, and then you can just reverse_proxy to there. E.g.
your.site.url {
   # Assuming nginx server is exposed on port 8080
   # If you serve multiple sites you would need to specify the url as well,
   # otherwise localhost or 127.0.0.1 or any appropriate IP will suffice.
   reverse_proxy nginx.site.url:8080
I’m curious if in order to get an internal like behaviour, you have to specify all of the web-server’s IP or would 127.0.0.1 in remote_ip suffice.
