Translating .htaccess RewriteRule to Caddyfile
I am moving a basic PHP site from Apache to Caddy. I had the following .htaccess file in a directory:
RewriteEngine on
RewriteRule ^example1\.json$ /app/v1/example1/index.php [NC,L]
RewriteRule ^example2\.json$ /app/v1/example2/index.php [NC,L]
I cannot figure out how this can be translated into a Caddyfile.
If I understand the rewrite correctly, it is basically rewriting these 2 .json files to separate index.php files so that end users can point to the .json but get the output of the .php files. There’s probably a better way of doing this, but this is the PHP application I’m working with currently.
No error message because Caddy is working. I just don’t know the correct incantation to get the rewrite to work in Caddy.
With the Cloudflare DNS module.
I used the following Dockerfile to create the Caddy image:
FROM caddy:2.6.4-builder-alpine AS build
RUN XCADDY_SKIP_CLEANUP=0 xcaddy build --with github.com/caddy-dns/cloudflare
FROM caddy:2.6.4-alpine AS final
COPY --from=build /usr/bin/caddy /usr/bin/caddy
  • Linode with Fedora 37 image—all software and security updates installed
  • AMD EPYC 7713 64-Core Processor
  • Podman: v4.4.2 w/ Go v1.19.6 for OS/Arch linux/amd64
I use Github actions to automatically build and tag my Docker images. This is the Github Action to build the image:
on:
  push:
    branches:
      - main
      - seed
    tags:
      - v*
  pull_request:
env:
  IMAGE_NAME: caddy-cf
jobs:
  push:
    runs-on: ubuntu-latest
    permissions:
      packages: write
      contents: read
    steps:
      - uses: actions/checkout@v3
      - name: Build image
        run: docker build . --file Dockerfile --tag $IMAGE_NAME --label "runnumber=${GITHUB_RUN_ID}"
      - name: Log in to registry
        run: echo "${{ secrets.GITHUB_TOKEN }}" | docker login ghcr.io -u $ --password-stdin
      - name: Push image
        run: |
          IMAGE_ID=ghcr.io/${{ github.repository_owner }}/$IMAGE_NAME
          IMAGE_ID=$(echo $IMAGE_ID | tr '[A-Z]' '[a-z]')
          VERSION=$(echo "${{ github.ref }}" | sed -e 's,.*/\(.*\),\1,')
          [[ "${{ github.ref }}" == "refs/tags/"* ]] && VERSION=$(echo $VERSION | sed -e 's/^v//')
          [ "$VERSION" == "main" ] && VERSION=latest
          echo IMAGE_ID=$IMAGE_ID
          echo VERSION=$VERSION
          docker tag $IMAGE_NAME $IMAGE_ID:$VERSION
          docker push $IMAGE_ID:$VERSION
This builds the image and then I pull and create a container. It runs great. Just curious about the file size differential.
podman pull ghcr.io/jaredhowland/caddy-cf:2.6.4
# Run with the following command:
Included above.
# domain name.
## TEMPLATE ###############################
(tls) {
	tls email@example.com {
    	dns cloudflare {env.CF_API_TOKEN}
(website) {
    root * /var/www/html/{args.0}/public_html
    # Compress files
    encode zstd gzip
    # Serve a PHP site through php-fpm:
    php_fastcgi php:9000 {
      try_files {path} {path}/index.php =404
    # Use a Caddy template to handle all errors
    handle_errors {
      rewrite * /error.html
      templates
## GET CERTIFICATES #######################
*.obscure.cc {
	import tls
## OBSCURE.CC #############################
obscure.cc {
    import tls
    import website "obscure.cc"
lib.obscure.cc {
    import website "obscure.cc/lib.obscure.cc"
    # SOME KIND OF REWRITE NEEDS TO HAPPEN HERE
Try this:
rewrite /example1.json /app/v1/example1/index.php
rewrite /example2.json /app/v1/example2/index.php
The modern way to do this is set up your PHP app with an index.php at the public webroot, then use a PHP router (for example GitHub - nikic/FastRoute: Fast request router for PHP) to route the request.
This is so simple. I woke up thinking this was going to be the solution but my brain couldn’t get it late last night. Thanks for the explanation. This app is not a priority so I don’t know if we will ever get around to using a PHP router for it but I’m sure we will eventually. In the meantime, this did the trick. Thanks for taking the time to help a noob—this community is amazing!
