Too many requests. Cant get cert. used to work,
Cannot get a cert. Used to work. Used to have about 10 sites in caddyfile. All was fine. Now only 3. Changed a subdomain today and cloudflare gives 525 because there’s no cert.
on my last reload, I got this log output (see below).
i’m using Tomcat on a Windows 2022 server.
this has worked for over a year - no changes.
In the past, I could duplicate a section and save, then reload and it would go get the cert for the new domain. No problem.
But I’m missing something here.
No way the ‘.well-known’ method is going to work. there’s no way a file is being written to my file system.
And if Cloudfare can’t come to my site because the SSL cert isn’t there, then how is zerossl/letsencrypt getting in to see if the site is real.
Is something supposed to be setup in Cloudflare? I’ve searched the forum and don’t see what I’m supposed to do.
‘Too many requests’ error is all I see - I don’t know how to fix that.
Apr 22 22:57:57 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"info","ts":1713826677.0144684,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"medstar.oemmed.com"}
Apr 22 22:57:57 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"info","ts":1713826677.2592108,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"medstar.oemmed.com","challenge_type":"tls-alpn-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Apr 22 22:57:57 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"info","ts":1713826677.2723067,"logger":"tls.obtain","msg":"obtaining certificate","identifier":"etdemo.oemmed.com"}
Apr 22 22:57:57 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"info","ts":1713826677.4250717,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"etdemo.oemmed.com","challenge_type":"tls-alpn-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Apr 22 22:57:57 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"error","ts":1713826677.5893095,"logger":"http.acme_client","msg":"challenge failed","identifier":"medstar.oemmed.com","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge","instance":"","subproblems":[]}}
Apr 22 22:57:57 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"error","ts":1713826677.5894494,"logger":"http.acme_client","msg":"validating authorization","identifier":"medstar.oemmed.com","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge","instance":"","subproblems":[]},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/90348824/16090140654","attempt":1,"max_attempts":3}
Apr 22 22:57:57 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"error","ts":1713826677.7549567,"logger":"http.acme_client","msg":"challenge failed","identifier":"etdemo.oemmed.com","challenge_type":"tls-alpn-01","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge","instance":"","subproblems":[]}}
Apr 22 22:57:57 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"error","ts":1713826677.7552779,"logger":"http.acme_client","msg":"validating authorization","identifier":"etdemo.oemmed.com","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"Cannot negotiate ALPN protocol \"acme-tls/1\" for tls-alpn-01 challenge","instance":"","subproblems":[]},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/90348824/16090140704","attempt":1,"max_attempts":3}
Apr 22 22:57:58 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"error","ts":1713826678.7051382,"logger":"http.acme_client","msg":"validating authorization","problem":{"type":"urn:ietf:params:acme:error:malformed","title":"","detail":"No such authorization","instance":"","subproblems":[]},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/90348824/16090140884","attempt":2,"max_attempts":3}
Apr 22 22:57:58 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"error","ts":1713826678.7056148,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"medstar.oemmed.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 404 urn:ietf:params:acme:error:malformed - No such authorization"}
Apr 22 22:57:58 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"error","ts":1713826678.7080092,"logger":"http.acme_client","msg":"validating authorization","problem":{"type":"urn:ietf:params:acme:error:malformed","title":"","detail":"No such authorization","instance":"","subproblems":[]},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/90348824/16090140894","attempt":2,"max_attempts":3}
Apr 22 22:57:58 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"info","ts":1713826678.8714244,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"etdemo.oemmed.com","challenge_type":"http-01","ca":"https://acme-staging-v02.api.letsencrypt.org/directory"}
Apr 22 22:57:58 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"info","ts":1713826678.9781578,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"medstar.oemmed.com","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
Apr 22 22:57:59 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"info","ts":1713826679.2582805,"logger":"http","msg":"served key authentication","identifier":"etdemo.oemmed.com","challenge":"http-01","remote":"172.69.135.58:39904","distributed":false}
Apr 22 22:57:59 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"error","ts":1713826679.4919605,"logger":"http.acme_client","msg":"challenge failed","identifier":"etdemo.oemmed.com","challenge_type":"http-01","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"During secondary validation: 2606:4700:20::681a:f5c: Invalid response from http://etdemo.oemmed.com/.well-known/acme-challenge/e8oqWro-HULRfqutBCqMs4gpb1_EpyuLObPsA02kSgU: 403","instance":"","subproblems":[]}}
Apr 22 22:57:59 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"error","ts":1713826679.492212,"logger":"http.acme_client","msg":"validating authorization","identifier":"etdemo.oemmed.com","problem":{"type":"urn:ietf:params:acme:error:unauthorized","title":"","detail":"During secondary validation: 2606:4700:20::681a:f5c: Invalid response from http://etdemo.oemmed.com/.well-known/acme-challenge/e8oqWro-HULRfqutBCqMs4gpb1_EpyuLObPsA02kSgU: 403","instance":"","subproblems":[]},"order":"https://acme-staging-v02.api.letsencrypt.org/acme/order/90348824/16090140914","attempt":2,"max_attempts":3}
Apr 22 22:57:59 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"error","ts":1713826679.4923775,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"etdemo.oemmed.com","issuer":"acme-v02.api.letsencrypt.org-directory","error":"HTTP 403 urn:ietf:params:acme:error:unauthorized - During secondary validation: 2606:4700:20::681a:f5c: Invalid response from http://etdemo.oemmed.com/.well-known/acme-challenge/e8oqWro-HULRfqutBCqMs4gpb1_EpyuLObPsA02kSgU: 403"}
Apr 22 22:57:59 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"error","ts":1713826679.499146,"logger":"tls.obtain","msg":"could not get certificate from issuer","identifier":"medstar.oemmed.com","issuer":"acme.zerossl.com-v2-DV90","error":"[medstar.oemmed.com] solving challenges: initiating challenge with server: attempt 1: https://acme.zerossl.com/v2/DV90/chall/fY6ZqSoyrzqiFXrjng_lUg: HTTP 429: <html>\r\n<head><title>429 Too Many Requests</title></head>\r\n<body>\r\n<center><h1>429 Too Many Requests</h1></center>\r\n<hr><center>nginx</center>\r\n</body>\r\n</html>\r\n (order=https://acme.zerossl.com/v2/DV90/order/crxs9FXy_YHc2sOcLGJDwQ) (ca=https://acme.zerossl.com/v2/DV90)"}
Apr 22 22:57:59 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"error","ts":1713826679.4993193,"logger":"tls.obtain","msg":"will retry","error":"[medstar.oemmed.com] Obtain: [medstar.oemmed.com] solving challenges: initiating challenge with server: attempt 1: https://acme.zerossl.com/v2/DV90/chall/fY6ZqSoyrzqiFXrjng_lUg: HTTP 429: <html>\r\n<head><title>429 Too Many Requests</title></head>\r\n<body>\r\n<center><h1>429 Too Many Requests</h1></center>\r\n<hr><center>nginx</center>\r\n</body>\r\n</html>\r\n (order=https://acme.zerossl.com/v2/DV90/order/crxs9FXy_YHc2sOcLGJDwQ) (ca=https://acme.zerossl.com/v2/DV90)","attempt":2,"retrying_in":120,"elapsed":65.210222554,"max_duration":2592000}
Apr 22 22:57:59 ubuntu-1cpu-1gb-us-chi1 caddy[1932869]: {"level":"info","ts":1713826679.9242055,"logger":"http.acme_client","msg":"trying to solve challenge","identifier":"etdemo.oemmed.com","challenge_type":"http-01","ca":"https://acme.zerossl.com/v2/DV90"}
been over a year. not really sure. not docker.
ubuntu server at Upcloud
sudo systemctl reload  caddy
medstar.oemmed.com {
		output file /var/lib/caddy/.local/share/caddy/market3_hopkins.log
		format json
	reverse_proxy * {
		to http://209.50.59.202
exchangedemo.oemmed.com {
		output file /var/lib/caddy/.local/share/caddy/market0_demo.log
		format json
	reverse_proxy * {
etdemo.oemmed.com {
		output file /var/lib/caddy/.local/share/caddy/expertech_demo.log
		format json
	reverse_proxy * {
That’s quite an old version. Please upgrade to the latest, v2.7.6.
Make sure to use our official installation instructions Install — Caddy Documentation
This implies you have somekind of proxy in front of Caddy which is intercepting the requests, so ACME issuance can’t successfully complete.
If you’re using Cloudflare, you need to use DNS-only mode (grey-cloud) because otherwise ACME requests don’t reach Caddy directly.
Or, you can use the DNS challenge instead (build Caddy with the cloudflare plugin) to issue certs without ACME servers connecting directly to your server.
@Jaymer be aware of Let’s Encrypt limits as well.
And when possible test with
