Too many redirects occurred
2.3.0
Caddy start
macOS Big Sur
Caddy start
N/A
social.nofftopia.com, nofftopia.com, noff.co, www.nofftopia.com, www.noff.co, social.noff.co {
        root * /users/glen/public/www/mastodon/public*
        @try_masto file
        handle @try_masto {
        handle /api/v1/streaming* {
                reverse_proxy localhost:4000
                reverse_proxy localhost:3000
        header Strict-Transport-Security "max-age=31536000;"
        header /emoji* Cache-Control "public, max-age=31536000, immutable"
        header /packs* Cache-Control "public, max-age=31536000, immutable"
        header /system/accounts/avatars* Cache-Control "public, max-age=31536000, immutable"
        header /system/media_attachments/files* Cache-Control "public, max-age=31536000, immutable"
        handle_errors {
                rewrite 500.html
Fuzarooms.com, www.fuzarooms.com {
        reverse_proxy 10.0.0.30
                output file /Users/glen/var/log/caddy/fuzarooms.log
fuzavue.com, www.fuzavue.com {
Filez.noff.co {
                output file /Users/glen/var/log/caddy/NoffFiles.log
naughty.noff.co {
                output file /Users/glen/var/log/caddy/naughty.log
Discord.noff.co {
                output file /Users/glen/var/log/caddy/discord.log
fuzabeast.com, www.fuzabeast.com {
                output file /Users/glen/var/log/caddy/fuzabeast.log
Madame.noff.co/mastodon {
Madame.noff.co/donate {
Music.noff.co {
Madame.noff.co {
                output file /Users/glen/var/log/caddy/madamenof.log
And on the second server, Caddyfile is
http://www.fuzavue.com, http://fuzavue.com {
            on_demand
    root * /users/glen/public/www/fuzavue
            output file /Users/glen/var/log/caddy/fuzavue.log
    #push {
    php_fastcgi 127.0.0.1:9000
    @static {
            file
            path *.ico *.css *.js *.gif *.jpg *.jpeg *.png *.svg *.woff
            # enable HSTS
            # clickjacking protection
            X-Frame-Options DENY
            Content-Security-Policy "upgrade-insecure-requests"
            X-XSS-Protection: 1
            @static Cache-Control "max-age=5184000"
http://www.fuzarooms.com, http://fuzarooms.com {
    root * /users/glen/public/www/fuzarooms
    #push {
    @static {
            file
            # enable HSTS
            #X-Content-Type-Options nosniff
            #X-Frame-Options DENY
            #X-XSS-Protection: 1
http://amphp.noff.co {
root * /users/glen/public/www/AMPHP
    #push {
    @static {
            file
            # enable HSTS
            X-XSS-Protection: 1
http://discord.noff.co {
redir Discord
http://fuzabeast.com, http://www.fuzabeast.com {
redir https://fuzavue.com/index.php/fitness/
http://madame.noff.co/mastodon {
redir https://social.nofftopia.com/@seaham
http://madame.noff.co/donate {
redir https://donorbox.org/madamenof
http://music.noff.co {
redir mubo
http://madame.noff.co {
root * /users/glen/public/www/madamenof
    push {
    @static {
            file
            # enable HSTS
            X-XSS-Protection: 1
Not sure what to do
N/A
Problem I’m having is that when I attempt to go to fuzarooms.com, I get an error saying too many redirects have occurred. Not sure how to fix this. Thanks in advance!
You seem to have an extra * at the end there, that doesn’t seem right. The root directive doesn’t set a matcher, it’s a path prefix specifying the location of your files.
That said, don’t macs use case-sensitive filesystems? I think you need /Users instead of /users. Might be wrong though.
On-Demand TLS isn’t useful for you here, because you’re in an http:// site, and you’re not in a site that allows for custom domains. You can remove that tls block.
This isn’t right, you can’t use a matcher inside of the header directive block. You’ll need to split that out into its own header @static line, outside of that header block.
This isn’t right, it’ll attempt to set a header called X-XSS-Protection: (note the :). Remove the :.
With all that said, please try again and next time, post your configs with ``` on the lines before and after your config, to properly use code formatting on the forums. It’s hard to read your config because of the messy formatting. Some parts of your config were transformed because they were parsed by the forum as links.
I appreciate the suggestions and will make the changes, though that doesn’t address the issue I’m having. All other sites work, only issue I’m having is too make redirections with https://fuzarooms.com :confused:
Surprisingly, the website loads the 404 page if I do not have the ‘*’ at the end of root
You mean it works when you use the above, but not when you use the following?
That doesn’t make any sense.
Like I said, please fix your original post, the config formatting is still quite messy and hard to read, so I’ll have trouble tracking down the problem.
I think he means root * /users/glen/public/www/mastodon/public yields a 404. This makes sense if there is no index file in the directory.
I will work on reformatting the post when I get off work.
Yeah, sorry i worded that poorly, you interpreted my reply correctly about the 404 page
