Too many failed authorizations recently
I have a domain hosting platform that has hundreds of domains. When renewing SSL certificates sometimes I get “too many failed authorizations recently” error message from let’s encrypt.
    "level": "error",
    "ts": 1690368347.5156703,
    "logger": "tls.obtain",
    "msg": "could not get certificate from issuer",
    "identifier": "www.#####.###",
    "issuer": "acme-v02.api.letsencrypt.org-directory",
    "error": "HTTP 429 urn:ietf:params:acme:error:rateLimited - Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/failed-validation-limit/"
AWS Fargate, Linux, ECS
It's a Fargate container so I don't need to run any command. I just have provided my docker image made out of caddy:2.4.5
local Dockerfile, using that I build my dcoker image
FROM caddy:2.4.5
ENV SslValidation ${SslValidation}
ENV ViewerEndpoint ${ViewerEndpoint}
ENV SitemapEndpoint ${SitemapEndpoint}
ENV DashboardEndpoint ${DashboardEndpoint}
EXPOSE 80
EXPOSE 443
  on_demand_tls {
    ask {env.SslValidation}
:443 {
  header Server "Server_name"
  header -x-powered-by
  @trailing_slash {
    path_regexp no_slash (.+)\/$
  @domain {
    header_regexp domain host ^www\.(.+)$
  redir @domain https://{http.regexp.domain.1}{uri}
  redir @trailing_slash {re.no_slash.1} 308
    on_demand
  handle_path /dashboard {
    reverse_proxy {env.DashboardEndpoint}
  handle_path /dashboard/* {
  reverse_proxy {env.ViewerEndpoint}
Are you persisting your certificate storage so Caddy can reuse the certs it obtains?
Let’s Encrypt has rate limits for how many certs they’ll issue repeatedly. Make sure to reuse certs you obtain the first time.
Our initial setup did not have persistence enabled from the container. Is the error happening because of this?
Yep, absolutely.
Correct me if I am wrong. Docker container will contain all the downloaded certs until the next restart, I haven’t restarted the container for quite a while. In that case, why is it a problem with persistency?
That’s a very old version. Please upgrade to the latest, v2.6.4.
I recommend using reverse_proxy {$DashboardEndpoint} instead which would make certain aspects of the proxy work better since the value won’t need to be replaced at runtime every time it’s read.
You don’t need both of these. Just do handle_path /dashboard* which covers both cases.
I recommend wrapping this in a handle (with no matcher) so it’s properly mutually exclusive from the other routes.
Both of these can be one-liners:
  @trailing_slash path_regexp no_slash (.+)\/$
  @domain header_regexp domain host ^www\.(.+)$
Make sure you persist the /data volume.
Thank you @matt and @francislavoie for your help.
