TLS wildcard + Tailscale approach
I followed the directions here to configure TLS for my domain. Everything worked on my internal network and all of my services use a wildcard certificate.
Next I wanted to add Tailscale into the mix in case I was away on travel or wanted to share some of my services with family members. So I built caddy with the caddy-tailscale module.
I was curious if the Caddyfile (below) could be improved at all or if this was a decent/sane approach? Thank you.
No problems; everything works. I just want some feedback on the approach.
v2.10.2
TrueNAS Scale (Debian GNU/Linux 12 bookworm)
docker compose up -d
# Dockerfile
FROM caddy:2.10.2-builder AS builder
RUN xcaddy build \
    --with github.com/tailscale/caddy-tailscale
FROM caddy:2.10.2
# compose file
    build: .
    hostname: caddy
      - MY_DOMAIN
      - TS_DOMAIN
      - CLOUDFLARE_API_TOKEN
      - ./caddy_data:/data
      - ./caddy_config:/config
      - /mnt/tank/certs:/certs
  default:
    external: true
# Caddyfile
	acme_dns cloudflare {$CLOUDFLARE_API_TOKEN}
	auto_https prefer_wildcard
	tailscale {
		auth_key tskey-auth-XXXX
jelly.{$MY_DOMAIN} {
	reverse_proxy jellyfin:8096
jelly.{$TS_DOMAIN} {
	bind tailscale/jelly
