Potential bug because placeholder doesn’t return anything?
trying to access certificate details from webserver {http.request.tls.client.certificate_pem} but that one doesn’t return anything but der encoded and everything else from there works.
Also have suggestion to add more of those placeholders like how long cert is valid and valid from and valid to i seen other servers have these, and not sure is there issue adding extensions of certificate to be accessed? I’m using 3rd party library to access those so i can get oids from Certificate Policies would be neat if it was possible without 3rd party libraries.
Response Headers
content-encoding: zstd
content-type: text/html;charset=utf-8
date: Thu, 06 Mar 2025 07:59:44 GMT
etag: "16PlJV3r4JsyX3B5hBM7jY/scXLLBzWgcPyILUH1NQPr7czVi4/0r58Ey9uznkmNkmmAIBPBxF89nimlGfgvug==-zstd"
expires: Sun, 27 Jul 1997 13:00:00 GMT
issuercert: CN=Coreit Sub CA,O=Coreit,C=ME,2.5.4.97=#130e5641544d452d3032373735303138
pragma: no-cache
referrer-policy: strict-origin
serialcert: <REDACTED>
server: Caddy
subjectcert: <REDACTED>
vary: Accept-Encoding
x-content-type-options: nosniff
x-frame-options: SAMEORIGIN
x-xss-protection: 1; mode=block
2025/03/06 07:59:42.698 e[33mWARNe[0m http.handlers.reverse_proxy aborting with incomplete response {"upstream": "127.0.0.1:8080", "duration": 0.0834991, "request": {"remote_ip": "::1", "remote_port": "34969", "client_ip": "::1", "proto": "HTTP/2.0", "method": "GET", "host": "localhost", "uri": "/ords/r/test/100/files/static/v13/forge.min.js.map", "headers": {"Accept-Language": ["en-US,en;q=0.9"], "X-Forwarded-Host": ["localhost"], "Priority": ["u=4, i"], "Sec-Fetch-Dest": ["empty"], "Pragma": ["no-cache"], "User-Agent": ["Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/133.0.0.0 Safari/537.36"], "Sec-Fetch-Mode": ["no-cors"], "X-Forwarded-For": ["::1"], "X-Forwarded-Proto": ["https"], "Cookie": ["REDACTED"], "Cache-Control": ["no-cache"], "Sec-Fetch-Site": ["same-origin"], "Accept-Encoding": ["gzip, deflate, br, zstd"]}, "tls": {"resumed": false, "version": 772, "cipher_suite": 4865, "proto": "h2", "server_name": "localhost", "client_common_name": "<REDACTED>", "client_serial": "<REDACTED>"}}, "error": "writing: http2: stream closed"}
Just downloaded binary from GitHub
Windows 10 Enterprise, x64
caddy.exe run
localhost {
reverse_proxy 127.0.0.1:8080
redir / /ords/r/test/sample-reporting/login
encode zstd gzip
tls "C:\Caddy\server.csr" "C:\Caddy\server.key" {
protocols tls1.3
client_auth {
mode require_and_verify
trust_pool file "C:\Caddy\ca.pem"
IssuerCert {http.request.tls.client.issuer}
SubjectCert {http.request.tls.client.subject}
SerialCert {http.request.tls.client.serial}
PemCert {http.request.tls.client.certificate_pem}
