Need help to create logic for the TLS ask
endpoint. Here I am blindly accepting all (see respond 200
), but I want to allow certain domains only:
myapp.mydomain.com
myapp.eastus.azurecontainer.io
I was troubleshooting TLS On Demand. If you want to log what is arriving to the ask
endpoint, do the following:
http://localhost:5555 {
trace tag="tls-on-demand"
respond 200
I am hosting my app eastus.azurecontainer.io
. The setup resembles (not 100%) the one listed here: Secure Deployment of Application with Azure Container Instances and Caddy | AuthCrunch aka Caddy Security Documentation
Here is what I got when I browsed to https://auth.myfiosgateway.com
{"level":"debug","time":"2024-03-26T10:07:55.545-0400","msg":"debugging request","request_id":"bc742f10-e1e9-420d-964c-d934caef4949","direction":"incoming","tag":"tls-on-demand","method":"GET","proto":"HTTP/1.1","host":"localhost:5555","uri":"/?domain=auth.myfiosgateway.com","remote_addr_port":"127.0.0.1:43018","remote_addr":"127.0.0.1","remote_port":43018,"content_length":0,"cookie_count":0,"user_agent":"Go-http-client/1.1","referer":"","cookies":[],"query_params":{"domain":"auth.myfiosgateway.com"},"headers":{"Accept-Encoding":"gzip","User-Agent":"Go-http-client/1.1"},"form":{}}
And this is for https://localhost/
{"level":"debug","time":"2024-03-26T10:07:55.544-0400","msg":"debugging request","request_id":"4e6ce777-b661-465f-90af-5a71d5d23709","direction":"incoming","tag":"tls-on-demand","method":"GET","proto":"HTTP/1.1","host":"localhost:5555","uri":"/?domain=localhost","remote_addr_port":"127.0.0.1:43018","remote_addr":"127.0.0.1","remote_port":43018,"content_length":0,"cookie_count":0,"user_agent":"Go-http-client/1.1","referer":"","cookies":[],"query_params":{"domain":"localhost"},"headers":{"Accept-Encoding":"gzip","User-Agent":"Go-http-client/1.1"},"form":{}}
As you can see the query parameters are in play. Specifically, domain
How would you implement the logic of allowing specific domains provided via domain
query parameter.
