TLS handshake error...first record does not look like a TLS handshake
1. Output of caddy version:
On a dedicated Linux VM
As a gate from internet to 3 servers (4 services), with reverse proxy
Also a filter on some countries with caddy-maxmind-geolocation
ubuntu 20.04
systemd
sudo systemctl enable --now caddy
 sudo caddy run
# caddy.service
# for your installation.
Type=notify
PrivateDevices=yes
# Caddyfile
crios.bris.fr:6690 {
        reverse_proxy http://192.168.9.201:6690
the service on the back-end did not work
Question: how to get the port in input of Caddy, in that case 6690?
I didn’t find it in the log.
TLS handshake error from 192.168.9.1:63373: tls: first record does not look like a TLS handshake
remove http to use https:
reverse_proxy 192.168.9.201:6690
reverse_proxy defaults to HTTP, not HTTPS. Adding or removing http:// doesn’t do anything, since that’s already the default.
I don’t understand the question. What doesn’t work, exactly? Just saying “did not work” doesn’t give us any clues.
That looks like you’re making an HTTP request to an HTTPS server.
Sorry, I was not clear enough. I did it like this also with the same result
reverse_proxy https://192.168.9.201:6690
what I’d like is
Win Synology Drive 6690 → router → caddy → Synology 6690
and it doesn’t work as Synology is expected 6690
I’ve tried both with the same result
tls: first record does not look like a TLS handshake means you are connecting with TLS to a non-TLS peer (probably HTTP or some other protocol).
Please post the full logs, we’re only guessing with just that error message in isolation.
sure:
1/ with (http):
# Caddyfile
sudo caddy run
2023/01/05 12:48:36.973 INFO    using adjacent Caddyfile
2023/01/05 12:48:36.985 INFO    admin   admin endpoint started  {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2023/01/05 12:48:36.989 INFO    http    enabling automatic HTTP->HTTPS redirects        {"server_name": "srv0"}
2023/01/05 12:48:36.997 INFO    http    enabling HTTP/3 listener        {"addr": ":6690"}
2023/01/05 12:48:37.003 DEBUG   http    starting server loop    {"address": "[::]:6690", "tls": true, "http3": true}
2023/01/05 12:48:37.008 INFO    http.log        server running  {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2023/01/05 12:48:37.014 DEBUG   http    starting server loop    {"address": "[::]:80", "tls": false, "http3": false}
2023/01/05 12:48:37.018 INFO    http.log        server running  {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2023/01/05 12:48:37.023 INFO    http    enabling automatic TLS certificate management   {"domains": ["crios.bris.fr"]}
2023/01/05 12:48:36.993 INFO    tls.cache.maintenance   started background certificate maintenance  {"cache": "0xc000189340"}
2023/01/05 12:48:36.998 INFO    tls     cleaning storage unit   {"description": "FileStorage:/root/.local/share/caddy"}
2023/01/05 12:48:37.052 DEBUG   tls     loading managed certificate     {"domain": "crios.bris.fr", "expiration": "2023/03/12 16:44:05.000", "issuer_key": "acme-v02.api.letsencrypt.org-directory", "storage": "FileStorage:/root/.local/share/caddy"}
2023/01/05 12:48:37.148 INFO    tls     finished cleaning storage units
2023/01/05 12:48:37.275 DEBUG   tls.cache       added certificate to cache      {"subjects": ["crios.bris.fr"], "expiration": "2023/03/12 16:44:05.000", "managed": true, "issuer_key": "acme-v02.api.letsencrypt.org-directory", "hash": "a780dad0e16f4f95c1fa39d995aa6815e48cf68550b85e7243a08e3ad7293889", "cache_size": 1, "cache_capacity": 10000}
2023/01/05 12:48:37.282 DEBUG   events  event   {"name": "cached_managed_cert", "id": "f7f8f1ca-339e-4aac-8a69-338e4d8683a1", "origin": "tls", "data": {"sans":["crios.bris.fr"]}}
2023/01/05 12:48:37.291 INFO    autosaved config (load with --resume flag)      {"file": "/root/.config/caddy/autosave.json"}
2023/01/05 12:48:37.296 INFO    serving initial configuration
2023/01/05 12:49:13.193 DEBUG   http.stdlib     http: TLS handshake error from 192.168.9.1:54385: tls: first record does not look like a TLS handshake
2/ with (https):
sudo caddy run
2023/01/05 12:51:25.423 INFO    using adjacent Caddyfile
2023/01/05 12:51:25.450 INFO    admin   admin endpoint started  {"address": "localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2023/01/05 12:51:25.454 INFO    http    enabling automatic HTTP->HTTPS redirects        {"server_name": "srv0"}
2023/01/05 12:51:25.462 INFO    tls.cache.maintenance   started background certificate maintenance  {"cache": "0xc00036d340"}
2023/01/05 12:51:25.465 DEBUG   http    starting server loop    {"address": "[::]:80", "tls": false, "http3": false}
2023/01/05 12:51:25.468 INFO    http.log        server running  {"name": "remaining_auto_https_redirects", "protocols": ["h1", "h2", "h3"]}
2023/01/05 12:51:25.471 INFO    http    enabling HTTP/3 listener        {"addr": ":6690"}
2023/01/05 12:51:25.475 DEBUG   http    starting server loop    {"address": "[::]:6690", "tls": true, "http3": true}
2023/01/05 12:51:25.478 INFO    http.log        server running  {"name": "srv0", "protocols": ["h1", "h2", "h3"]}
2023/01/05 12:51:25.485 INFO    http    enabling automatic TLS certificate management   {"domains": ["crios.bris.fr"]}
2023/01/05 12:51:25.496 DEBUG   tls     loading managed certificate     {"domain": "crios.bris.fr", "expiration": "2023/03/12 16:44:05.000", "issuer_key": "acme-v02.api.letsencrypt.org-directory", "storage": "FileStorage:/root/.local/share/caddy"}
2023/01/05 12:51:25.505 DEBUG   tls.cache       added certificate to cache      {"subjects": ["crios.bris.fr"], "expiration": "2023/03/12 16:44:05.000", "managed": true, "issuer_key": "acme-v02.api.letsencrypt.org-directory", "hash": "a780dad0e16f4f95c1fa39d995aa6815e48cf68550b85e7243a08e3ad7293889", "cache_size": 1, "cache_capacity": 10000}
2023/01/05 12:51:25.509 DEBUG   events  event   {"name": "cached_managed_cert", "id": "1e2bc15e-a2d4-446e-9fc6-e6fb992b3396", "origin": "tls", "data": {"sans":["crios.bris.fr"]}}
2023/01/05 12:51:25.483 INFO    tls     cleaning storage unit   {"description": "FileStorage:/root/.local/share/caddy"}
2023/01/05 12:51:25.530 INFO    autosaved config (load with --resume flag)      {"file": "/root/.config/caddy/autosave.json"}
2023/01/05 12:51:25.533 INFO    serving initial configuration
2023/01/05 12:51:25.540 INFO    tls     finished cleaning storage units
2023/01/05 12:51:31.472 DEBUG   http.stdlib     http: TLS handshake error from 192.168.9.1:54534: tls: first record does not look like a TLS handshake
Thanks for your reply!
I have to say that the Synology support has just answered that this service is not working with a reverse proxy, but should work directly:
After consulting with our specialists, I confirm that a reverse proxy rule would be applicable for Synology Drive web interface operation (or Synology Drive for Android), but it does not work for Synology Drive client synchronization (port 6690).
Even though I don’t understand why, so perhaps you should not spend too much time…
Regards
Pascal
PS: perhaps you know Win and Andoid sync open source software that work well with Caddy reverse-proxy and basic_auth…
To be clear, the problem is not with reverse_proxy, the problem is that your client (app/browser/whatever) is making HTTP requests when Caddy is expecting HTTPS requests.
Caddy is not even reaching the point of running the reverse_proxy handler because the connection failed at the TLS handshake before it could start handling the request.
Why are you using that port number? If you intended to use HTTPS for incoming traffic, why not omit the port number in your site address to use port 443, the default HTTPS port?
If you intended to accept HTTP traffic from your app/browser/client then prefix the site address with http:// to disable HTTPS (but obviously that turns off encryption and any device in between the client and server can see or manipulate the traffic if they wanted to).
I don’t have the choice of the port in Synology app
If I understand that’s between the client (the app on the PC) and caddy. I only could uncheck SSL
And it’s the same result
I think I’m going to change to other tools…
Thanks for the explanation!
